POV-Ray : Newsgroups : povray.unofficial.patches : My personal wishlist Server Time
17 Nov 2025 08:14:41 EST (-0500)
  My personal wishlist (Message 38 to 47 of 77)
Subject: Re: My personal wishlist
Date: 26 Feb 2000 20:02:24
Message: <38b877a0@news.povray.org>
In article <O1+4OE0dCXqQafXKqfXLL1aqGEUo@4ax.com> , Peter Popov
<pet### [at] usanet>  wrote:
>>Therefore, I would probably just add integer types (maybe char, but most
>>likely not).  And I'm pretty sure I'd totally avoid any unsigned types.
> These should suffice, really. And at first I didn't realize the
> problems a person with no programming background might run into when
> working with unsigned types. You're right, leave'em out.
When using only integer types, I think the whole thing can be hidden from
the user and POV-Ray automatically determines the type (floating-point or
integer). This allows for hiding the type from the user, and in loop, etc
even new users would get the benefit without ever having to deal with
variable types.
For a #declare (of a so far undefined variable) just check if the value is
an integer and then store it as such.  I.e. "#declare MyFoo = 1" is an
integer, but neither would be "#declare MyFoo = 1.0" or "#declare MyFoo =
1.8542".  Now, whenever a floating-point result is to be assigned to this
integer, promote "MyFoo" to floating-point (for backward compatibility!).
User control can still be available, i.e. introducing two functions to
eliminate the common operations that should create floating-point results:
For division offer a Pascal style "div" function (or even operator), and to
still allow mixing integer and floating-point math without forcing promotion
to floating-point for the result, an "int" function which can be placed
around any section of a function, for example "#declare MyFoo = 1; #declare
MyFoo = 8084 div 7 + MyFoo - (int(sin(45) * 10) * MyFoo;" would still give
in an integer result.
During evaluation this should still be possible with (nearly?) no runtime
penalty.
     Thorsten
Date: 27 Feb 2000 01:09:41
Message: <38b8bfa5@news.povray.org>
Margus Ramst wrote in message <38B711FF.1E959678@peak.edu.ee>...
>Some wishes arising from my current projects:
>Dynamic arrays. In POV, arrays are the best way to acces large datasets,
but the
>size of the array has to be declared before any data is inserted. The thing
is,
>you often don't know how much data will be generated. And manually resising
a
>100,000 element array is inefficient, to say the least.
I've been working on "malloc", "realloc", and "free" macros.  However, the
current version of "realloc" is very slow, since it works by creating a new
array and copying the old one into it.
Mark
Date: 27 Feb 2000 07:55:20
Message: <38b91eb8@news.povray.org>
Peter Popov <pet### [at] usanet> wrote:
: I have not either. Perhaps you have missed my main point, and it is
: textures. Imagine you have this:
: intersection
: { union
:   { sphere { -x, 1 pigment { Red } }
:     sphere { x, 1 pigment { Blue } }
:   box { <-3,0,-2>, <3,2,2> }
  But that's not possible. Suppose that the radiuses of the spheres are
a bit larger (so that the spheres overlap). What's the color of the
overlapping part?
  On the other hand, even in your example: How can povray know which one
is the right sphere to get the color from? It only has knowledge of the
intersection of the ray with the box. It would have to somehow decide which
sphere is the right one. I don't know how povray works in this matter, but
it might be difficult to see which sphere is the right one. It's more difficult
if the spheres overlap or one sphere is completely inside the other.
  And besides, bounding is not intended for that kind of functionality.
Boundind is intended only for speeding up the rendering.
Date: 27 Feb 2000 09:01:41
Message: <chrishuff_99-30DB49.09030927022000@news.povray.org>
In article <38b877a0@news.povray.org>, "Thorsten Froehlich"
> to eliminate the common operations that should create floating-point
> results: For division offer a Pascal style "div" function (or even
> operator), and to still allow mixing integer and floating-point math
> without forcing promotion to floating-point for the result, an "int"
> function which can be placed around any section of a function, for
> example "#declare MyFoo = 1; #declare MyFoo = 8084 div 7 + MyFoo -
> (int(sin(45) * 10) * MyFoo;" would still give in an integer result.
Those functions already exist in POV. :-)
Section 4.1.3.6  Float Functions
div(A,B) Integer division. The integer part of (A/B) .
int(A) Integer part of A . Returns the truncated integer part of A .
Rounds towards zero.
Now all that has to be done is add code for deciding whether to use
integer or floating point...btw, I think the precision should be
specified instead of being left to the implementation of "int", it would
make the language more consistant across platforms and compilers. Or
maybe just have it decide depending on the size of the number-but I
think the overhead of that(some conditionals, comparisons, and type
conversions?) would outweigh any possible benefits.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 27 Feb 2000 21:12:27
Message: <slrn8bjmfc.v8.ron.parker@parkerr.fwi.com>
On Fri, 25 Feb 2000 19:30:39 -0500, Chris Huff wrote:
Maybe a dynamic_array
>which behaves like a C++ STL vector.(If you are not familiar with this,
>it is an object type, a container class which is basically a dynamic
>one-dimensional array. It includes functions for appending, inserting,
>etc)
I want an array that acts like a C++ STL map, too.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 28 Feb 2000 03:02:18
Message: <38ba2b89@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: I want an array that acts like a C++ STL map, too.
  I think it's technically called "associative array".
  And yes, povray versions of the STL vectors and maps would be very handy.
  With maps there may be need for iterators.
Subject: C++ (was:Re: My personal wishlist)
Date: 28 Feb 2000 03:24:06
Message: <qqmd7phhh09.fsf_-_@schlatt.fmi.uni-konstanz.de>
Nieminen Juha <war### [at] sarakerttunencstutfi> writes:
It appears to me, that the time for the complete rewrite in C++
(i.e. POV-Ray 4.0) has come. Does somebody know, whether the
POV-Team has already started? (I'm looking forward to discuss
design and implementation issues.)
http://thomas.willhalm.de/ (includes pgp key)
Date: 28 Feb 2000 08:24:11
Message: <38ba76fb$1@news.povray.org>
Actually, I knew that, since I actually use them in Perl rather than
in C++.  I was just trying for the parallelism with the original comment. :)
Perl doesn't have what you'd call "iterators" per se.  To iterate over an
associative array in Perl, you do:
  for $index ( keys( %assoc_array ) ) {
    do_stuff_with( $assoc_array{$index} )
Subject: Re: C++ (was:Re: My personal wishlist)
Date: 28 Feb 2000 12:43:59
Message: <38bab3df$1@news.povray.org>
In article <qqmd7phhh09.fsf_-_@schlatt.fmi.uni-konstanz.de> , Thomas
povray.announce.frequently-asked-questions:  "POV-Ray plans for v3.1 and
beyond..."
        Thorsten
Date: 28 Feb 2000 18:13:51
Message: <38BB01AA.936C948F@peak.edu.ee>
Yes, I've done that too, out of necessity.
It's slow, plus you want to resize it as seldom as possible so you must waste
memory on unnecessarily large arrays.
Margus
