POV-Ray : Newsgroups : povray.unofficial.patches : My personal wishlist Server Time
15 Sep 2025 16:12:07 EDT (-0400)
  My personal wishlist (Message 18 to 27 of 77)
Subject: Re: My personal wishlist
Date: 25 Feb 2000 15:45:23
Message: <chrishuff_99-CC5674.15464725022000@news.povray.org>
In article <38B6E4BC.977FD8A0@merlin.net.au>, PoD <pod### [at] merlinnetau>
wrote:
> > This might be a good idea. On the other hand, it would reinforce the bad
> > habit of using bounded_by as a kind of CSG...(remember that with some
> > settings POV can override this statement and use it's own bounding)
> No no no... bounding has nothing to do with CSG and should'nt be
> confused with it.
That is what I was trying to get at-if bounding boxes chop off pieces of
the object instead of behaving as they currently do, people will mistake
them for a type of CSG more often. This is a bad thing. I don't want it
to happen.
> > If the "use_depth_for_z"(somebody please come up with a better keyword!)
> > feature is turned on, the angles of the initial emission from the light
> > source will be used for the x and y axis, and the distance the ray has
> > travelled for the z axis. This should make things like interference
> > patterns possible.(I wonder what this would look like combined with
> > scattering media and photons!)
> Interesting, but I think it should be done the same as sky_sphere
> i.e. the colour comes from the intersection of the ray and a unit
> sphere.
But that would make it a lot less flexible...you wouldn't be able to
simulate the wave-like characteristics of light, for example. It would
be the same as placing a small-scaled sphere around the light source.
Hmm, you could even do a cheap imitation of laser beams without photons:
use the object pattern with two cylinders meeting at a mirror as the
pigment for the light, and use scattering media with isotropic
scattering(this would be important, because although the light would
seem to be constrained to the two cylinders, it's direction would still
be away from the light_source). This would be messed up by shadows, but
it is an interesting possible use.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 25 Feb 2000 18:34:27
Message: <38B711FF.1E959678@peak.edu.ee>
Some wishes arising from my current projects:
Dynamic arrays. In POV, arrays are the best way to acces large datasets, but the
size of the array has to be declared before any data is inserted. The thing is,
you often don't know how much data will be generated. And manually resising a
100,000 element array is inefficient, to say the least.
Better I/O support, such as read/write offset, insertion etc.
Margus
Peter Popov wrote:
> With time I've compiled a list of features I would be happy to see in
> POV-Ray. I think it wouldn't hurt if I posted it here.
Date: 25 Feb 2000 19:29:12
Message: <chrishuff_99-591A71.19303925022000@news.povray.org>
In article <38B711FF.1E959678@peak.edu.ee>, Margus Ramst
> datasets, but the size of the array has to be declared before any
> data is inserted. The thing is, you often don't know how much data
> will be generated. And manually resising a 100,000 element array is
Or list and maybe binary tree structures. I actually started on a list
patch, but realized it was out of my range after looking at the array
code. Append, resize, and insert functions for an array should be fine,
but how would multiple dimensions be handled? Maybe a dynamic_array
which behaves like a C++ STL vector.(If you are not familiar with this,
it is an object type, a container class which is basically a dynamic
one-dimensional array. It includes functions for appending, inserting,
etc)
Maybe also a kind of "pointer". With the appropriate saveguards against
accessing memory it shouldn't, of course.
Chris Huff
Date: 26 Feb 2000 10:51:54
Message: <38B7FCCF.A533B213@merlin.net.au>
> > confused with it.
> to happen.
Oh OK it looks like we agree on this.
> > sphere.
I didn't mean not to include the z-depth option, just that using planar
mapping would make a lot of uses difficult.  Maybe reuse the mapping
keyword here, I could see at least spherical, planar and cylindrical
being useful.
Here's something if you had z-depth.  Use a density file as the pattern
and project 'solid' holograms into media with shadowing from intervening
objects :)
PoD.
Date: 26 Feb 2000 11:23:36
Message: <chrishuff_99-FBFD91.11250426022000@news.povray.org>
In article <38B7FCCF.A533B213@merlin.net.au>, PoD <pod### [at] merlinnetau>
> being useful.
Not planar mapping, spherical mapping. Distance would be z, and
vertical/horizontal angle would be x and y, and the center would be the
light_source position. It would be like wrapping the pigment around the
sphere, except the color also varies depending on it's distance from the
center of the sphere. You would have to tile it in some cases(many times
the tiling wouldn't be visible), but I don't see any other way of
mapping 3D space around a point. Maybe also cylinderical mapping.
> objects :)
That is an idea...although I guess it could also be done with scattering
media using the density file and a plain colored light, at least as long
as no other lights interact with it.
Chris Huff
Date: 26 Feb 2000 12:26:11
Message: <kfK3OIjBjxu=lEMtvnZip=3GMUqx@4ax.com>
On Thu, 24 Feb 2000 21:01:48 -0500, Chris Huff
<chr### [at] yahoocom> wrote:
>In article <bCW1OIjrykoVBR6nY5iI6VMKZ3UL@4ax.com>, Peter Popov
><pet### [at] usanet> wrote:
>> : df3 output, dfc file
>> My idea is that a new file type triggered by a comman-line (or INI)
>> option is introduced. An additional depth parameter to output
>> resolution has to be introduced, too. The program would then sample
>> the unit cube at width*height*depth points and save the clipped
>> brightness directly to a density file. Brightness should only be
>> affected by pigments and media density.
>Maybe something could be added to my object pattern...my proximity
>pattern might also benefit from this(compute the density pattern once
>using high settings for proximity, then use the density pattern instead
>of the proximity).
Actually this is one of the major benefits of this idea. The proximity
is dreadfully slow in media (and probably isosurfaces). If it could be
calculated only once, render times would be greatly cut down.
Significant reduction of render times can be achieved if complex media
statements are replaced with precomputed density patterns. My current
project involves the usage of 200 scattering media statements in a
single blob container. It takes more than nine hours to render at
640x480. If it were a single df3 media, render times could be
dramatically decreased (by an order of ten to a hundred, depending on
the scene)
>> A new type of density file (for example dfc), one that stores
>> three-dimentional RGB data, would also be of use. The RGB data could
>> then be used as a default color map for the density_file pattern based
>> on this file if no color map is specified. Combined with df3 or dfc
>> output one could easily render a glowing media version of any object,
>> while preserving the colors.
>Where would you get the color data from a CSG with multiple textures?
>Just add the color contribution from every object? And you would have to
>restrict yourself to the pigment, since the other features(normal,
>finish) kind of depend on having a surface.
The problem with overlapping interiors may or may not be possible to
be solved by proper CSG. Maybe if the objects are tested in a specific
order (for example the order they appear in the CSG) and the first
match is returned, the problem would go away. And yes, only pigments
would be used, but that should be enough to model things such as
>> : polygonal spotlight
>> Although unrealistic, these have their applications. Combined with an
>> area light, they can be used to simulate, for example, light passing
>> through a window or keyhole or similar.
>This is an interesting idea, but couldn't it be done with the
>projected_through patch?
No, because the falloff (for spotlights) would still be circular and
not polygonal.
>> : chop pieces off with bounding
>> If a bounding object is smaller than what it bounds, the results are
>> unpredictable. I think a more logical behaviour would be the one seen
>> in isosurfaces, i.e. the bounding object should restrict the bounded
>> object, exposing the intersection surface and texture. Of course, it
>> would still bound the object for ray-shape intersection tests.
I admit it is probably a bad idea anyway, especially because it would
duplicate the functionality of the CSG texture patch if it gets
implemented. The idea for both modifications came to me when I had a
complex CSG of objects with their own textures and I wanted to make a
cross-section of it. Although I succeeded to do it with bounding,
rotating the object or camera lead to unpredictable results. So I am
proposing both patches because I can't tell right now which one would
be easier/simlper/safer to possibly implement.
>> : leave original textures when CSGing
>> When performing a CGS difference or intersection, any object with a
>> non-specified texture is assumed to have a black pigment and ambient
>> 0. I think a more reasonable behaviour would be to ignore its texture
>> and use the texture of whatever object the intersection point is in.
>> Of course this could lead to "coincident interiors" problems but I
>> think with proper CGSing they can be avoided.
>Actually, I am pretty sure it uses the default texture, which you can
>set with the #default keyword.
I guess so, but it still poses the same problem.
>And I think it would be extremely
>difficult to determine which object to choose the texture from...what if
>the point is enclosed in more than one object?
If more then one objects enclose the point, use the texture of that
one which appears first (or last) in the CSG.
>> : seeded randomness for area_light and aa jitter
>> This one is pretty straight-forward. It would make animation people's
>> lives easier.
>I don't think this is possible. Providing a seed would allow you to
>specify the sequence of random numbers used, but you still can't decide
>when they are used. If a point gets covered up doesn't need a random
>number computed or if something causes a pixel to need more numbers than
>it did before, everything get unsynchronized and you end up with the
>same "flying pixels" or static.
I didn't mean the user should specify the seed, rather that the seed
should be constant for each pixel (for example X+Y). This would
eliminate the "flying pixels" static.
>I will have to look at those sites...
My heart fills with hope... :)
>Other features I can think of:
>Simple shaders: really just an extended isosurface function capable of
>handling vectors and colors. Not necessarily as full-featured as "real"
>shaders, but potentially quite useful.
Ditto. Combine this with custom BRDFs and you have infinite
possibilities.
>Patterned light_source's: Have the ability to apply a patterned
>color_map to a light source, with the option to use ray direction and
>depth instead of point position.(which would kind of simulate light
>coming through a colored, transparent sphere surrounding the light
>source, but with depth)
>light_source {blah, blah
>   PATTERN
>   color_map {...}
>   use_depth_for_z on/off
I've raised the question of simulating wave properties (wavelength,
phase and polarization) a couple of times myself but it was
overlooked. Your idea is certainly more versatile and I see good uses
for it already.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 26 Feb 2000 12:26:12
Message: <kge4OC18QaRIBS8wsrWMYSZKpa9E@4ax.com>
>confused with it.
I know, I know, but there are certain limitations in the current CSG
model that could be avoided this way.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 26 Feb 2000 12:26:30
Message: <5we4OFqs+4Dl3UdLMdfIlHVIiN86@4ax.com>
On Fri, 25 Feb 2000 10:16:09 +0200, "Gail Shaw" <gsh### [at] monotixcoza>
>Isn't that better done with clipped by? Or do you want to merge the two?
Neither. I want to see the texture of an arbitraty object where it
intersects its (manual!) bounding object. Chris and PoD (and probably
others) already pointed out the major problem, that some users might
be lead into believing that bounding is a type of CSG, and this is a
Real Bad Thing(tm). I am giving up this idea in favour of the next one
(which duplicates this functionality anyway).
>That would make my life SO much easier. Difficult to
>implement though (Think of the following:
>difference {
> union {
>  sphere {
>    <0,0.5,0>,1
>    pigment {Red}
>   sphere {
>    <0,-0.5,0>,1
>    pigment {Blue}
>  box {
>   <0,-2,-2>,<2,2,2>
>What colour should the overlapped area of the spheres be?
>Red, Blue or Purple?
Replace it with this:
difference {
 union {
  intersection { sphere { 0.5*y, 1 } plane { -y, 0 } pigment { Red } }
  intersection { sphere { -0.5*y, 1 } plane { y, 0 } pigment { Red } }
 box { <0,-2,-2>, <2,2,2> }
and you'll see what I mean by "proper CSG" :)
>Another I would like :
> The ability to layer a texture over a complex CSG when each
>part has its own texture (If this is possible without using two copies of
>the object, please let me know)
This would certainly be useful. It can be done without a separate copy
of the object if each piece of the CSG has the desired texture layered
over its own.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 26 Feb 2000 12:26:32
Message: <fAq4OOaezNjs7k2x7JyUJuMX7ct9@4ax.com>
On 25 Feb 2000 08:13:05 -0500, Nieminen Juha
<war### [at] sarakerttunencstutfi> wrote:
>: If a bounding object is smaller than what it bounds, the results are
>: unpredictable.
>  Nope. They are very predictable. Only a ray hitting the bounding object
>can hit the bounded object.
>  A bounding box is a bounding box, not a clipping box. The current
>implementation is the correct one. It should be documented better to
>avoid confusion, but it's correct.
Suppose the bounding box is smaller than the object itself. If and
only if a ray hits the box, it will look for the first intersection
with the object itself _along_the_ray_ and that intersection could
easily be outside the bounding box! So if you have a sphere bounded by
a smalled box, the result would look as if you've rendered the sphere
and then applied to the resulting image an alpha channel based on the
box. This, in my dictionary, is not correct.
Of course specifying a bounding box smaller than the bounded object is
incorrect in the first place :) but there are a few trick (besides
vampires and anti-vampires) that can be done with it.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 26 Feb 2000 12:35:54
Message: <38B80F59.9FB6022E@istar.ca>
> : Additional BRDF models
> I recently used a rendered which supported 11 differend BRDF
> (highlights) models. Now that's cool! The authors were kind enough to
> share some of their sources with me:
> http://www-graphics.stanford.edu/~smr/cs348c/surveypaper.html
> http://www.cs.columbia.edu/CAVE/curet/
> http://www.ciks.nist.gov/appmain.htm
> Some of them have properties very useful for specific tasks, such as
> anisotropy (for a brushed metal look).
I just took a quick look at the site. The velvet rendering is incredible!
