POV-Ray : Newsgroups : povray.unofficial.patches : Help with normal returned by trace() Server Time
14 Jan 2026 02:41:15 EST (-0500)
  Help with normal returned by trace() (Message 1 to 6 of 6)
Subject: Help with normal returned by trace()
Date: 7 Feb 2001 16:48:08
Message: <Xns904196F2795B7spammindspringcom@204.213.191.228>
I'm trying to apply shapes to the surface of an object to make the object
look larger...  Anyway, I'm using the trace function to find the
intersection and normal, but the normal is expressed in 0..1 format instead
of the 0-360 format needed for rotations.  I've tried multiplying the
returned normal with 360, and I tried seperate rotates for each part of the
normal multiplied by 360, but the shape isn't rotated the way I'm expecting
it to.  I am expecting the flattened boxes to lie flat against the sphere.
I need to be able to rotate the object, as I will eventually be using
fairly complex shapes in place of the box.  Any help appreciated, sample
code is below.
Rich
#version unofficial MegaPov 0.7;
  location  <5.0, 5.0, -15.0>
  direction 1.5*z
  right     4/3*x
  look_at   <0.0, 0.0,  0.0>
light_source {<-300,100,-200> color rgb 2}
light_source {<300,100,200> color rgb <0,0,.8>}
#declare MySphere = sphere {<0, 0, 0>, 4}
#declare Norm = <0, 0, 0>;
#declare R1 = seed(0);
#declare lp = 0;
#while (lp < 500)
  #declare Start = <(rand(R1) -.5)*10,
                    (rand(R1) -.5)*10,
                    (rand(R1) -.5)*10>;
  #declare Inter=trace(MySphere, Start, <0, 0, 0>-Start, Norm);
  box {
    <-.2,0,-.2> <.2,.1,.2>
    //rotate Norm*360
    rotate Norm.x*360
    rotate Norm.y*360
    rotate Norm.z*360
    translate Inter
    texture {pigment {color red 1}}
  #declare lp = lp + 1;
object {
  MySphere
  texture {pigment {rgb 1}}
Rich Allen
(Remove SPAM from my address to reply by e-mail)
Subject: Re: Help with normal returned by trace()
Date: 7 Feb 2001 16:51:36
Message: <slrn983gri.5lm.ron.parker@fwi.com>
>code is below.
The normal is nothing like a rotation vector.  You need John VanSickle's
Reorient macro, but of course I've forgotten the URL.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 7 Feb 2001 16:53:35
Message: <3A81C489.A19DA76F@pacbell.net>
http://users4.50megs.com/enphilistor/index.htm
Date: 7 Feb 2001 16:56:18
Message: <slrn983h4c.5lm.ron.parker@fwi.com>
On Wed, 07 Feb 2001 13:56:25 -0800, Ken wrote:
>Date: Wed, 07 Feb 2001 13:56:25 -0800
>X-Trace: 7 Feb 2001 16:53:35 -0500, 64.165.148.49
That was fast, but it would have looked faster if you'd fixed your clock.
Date: 7 Feb 2001 16:58:08
Message: <3A81C4D8.E7D9C547@pacbell.net>
I'll see what I can do. :)
Ken Tyler
Date: 7 Feb 2001 17:17:09
Message: <Xns90419BDDD6498spammindspringcom@204.213.191.228>
Ken <tyl### [at] pacbellnet> wrote in <3A81C4D8.E7D9C547@pacbell.net>:
  Thanks for the quick response guys!
Rich Allen
