POV-Ray : Newsgroups : povray.unofficial.patches : Isosurface mod Server Time
2 Jun 2024 01:55:24 EDT (-0400)
  Isosurface mod (Message 1 to 8 of 8)
Subject: Isosurface mod
Date: 27 Oct 2004 23:07:43
Message: <MPG.1bea10575f2e0627989bfb@news.povray.org>
Has anyone else seen the article in Linux Journal about using POV-Ray for
visualizing large data sets? The patch stuff is here:
http://staff.aist.go.jp/r-suzuki/e/povray/iso/df_body.htm
I seem to remember people talking about something similar on some posts,
but not actually implementing anything directly in POV-Ray. Apparently,
one thing this does is extend the file parser for density files to deal
with some stuff it couldn't, including supporting decimal data, instead
of requiring it be imported as ranges between 0 and 255. Looks
interesting for anyone that has data they can use with it, not to mention
complex isosurfaces from data you could generate programmatically to take
advantage of it.
If someone on here did create this and already mentioned it, then
"Ooops!". ;) All I can say is - too many dang posts to keep track of and
'search' only works if they know for sure what to look for.
void main () {
    call functional_code()
  else
    call crash_windows();
Subject: Re: Isosurface mod
Date: 28 Oct 2004 03:45:33
Message: <4180a39d$1@news.povray.org>
In article <MPG.1bea10575f2e0627989bfb@news.povray.org> , Patrick Elliott
Apart from intentionally not supporting decimal data, did you look at
POV-Ray 3.6 lately?
    Thorsten
e-mail: tho### [at] trfde
Date: 29 Oct 2004 17:02:50
Message: <MPG.1beb1350c94266cd989c01@news.povray.org>
In article <4180a39d$1@news.povray.org>, tho### [at] trfde says...
> POV-Ray 3.6 lately?
At that specific feature? No. I just thought it was an interesting
article and wondered if anyone had seen the patch.
I tend to agree with the author of the patch though. We have enough
situations where we have to convert real world data into the artificial
limits POV-Ray often imposes for data. It doesn't make a lot of sense to
'intentionally' introduce yet another situation where the data has to be
converted from decimal to integer. How exactly does placing such
artificial limits on the data help anyone use POV-Ray for visualizing
data that *cannot* be collapsed into such a limited and rigid set of
values? Why not also limit color output to 8-bit? After all, producing
the image is so much more important than making sure it is accurate...
Yeah, I understand why, but this is an extension specifically for HDF. It
doesn't supercede or change the existing limited system, it is
specifically designed for the specialized import and use of data that
cannot and does not conform to the limits imposed by the existing density
file format. This includes the amount of data available:
"...each HDF file is a snapshot of the model state at a given time and
contains 12 3-D variables per file. It often is illustrative to look at
multiple variables, such as cloud, rain, hail and snow."
Basically, his format lets you retrieve individual surfaces in a single
file to by name, like this:
density_file hdf "blah.hdf", "foo"
This would read in only the data for the 'foo' section of the hdf file.
Not only can you use raw data from a simulation source that isn't
artificially scaled to an integer range, which would make his simulation
of complex supercell thunderstorms impossible, but the data for all
aspects of it, including rain and the rest, can be rendered from a single
source. A similar patch could be made for say DXF, so allow each sub
object to be read in as its own object, without the currently insane
method of relying on some third party application to misconvert the data
or collapse the entire thing into one object you then can't bloody do
anything with. Forgive me for thinking that this 'might' be a better idea
that forcing artificial and questionable limits on the data, while
requiring everyone to rely on the often incomplete support for POV-Ray
exporting in the applications to use other 3D formats. I personally think
it is a brilliant solution.
Maybe you where trying to make some other point though? For that matter,
if it does include something for HDF, what would I look for and how
versatile is the feature? I suspect already, from your statement about
intentionally limiting it to integer, that the answer is 'not very'.
void main () {
  else
Date: 29 Oct 2004 17:22:57
Message: <4182b4b1@news.povray.org>
  So you did not read the 3.6 documentation?
  Besides, the patches over patches over patches technology of the
current POV-Ray has more or less come to an end. A patch is seldom
a good solution to anything (except features which can't be done
in any other way, but this is not such a feature), and adding more
and more patches to POV-Ray is only making worse the problem which
is currently overwhelming it.
  When suggesting a new feature, think first if it's *really* necessary
to implement as a patch (eg. because of speed and/or memory issues),
or if it could be done as a script (assuming POV-Ray had a powerful
scripting language). Most patches written in C++ will probably die
with POV-Ray 4 because they will then be possible to be implemented
with the scripting language instead.
  Patches are only good for one thing: Speed. Basically everything else
in a patch is a burden: Patches are rigid (their feature set is usually
limited and fixed), not easily modifiable and they add potential bugs
and maintenance nightmares to the source code.
  "Plugins" made with a powerful scripting language have many advantages:
They can be made versatile and easily modifiable (without having to
recompile anything) and they do not introduce bugs nor maintenance
problems to the POV-Ray source code. In fact, quite many of the current
features in POV-Ray could be removed from the source code and implemented
as scripts.
  Of course POV-Ray 4 is in the very distant future and for now patches
are usually the only way to go. However, you have to be aware that
patches are usually not the answer in the long run.
Date: 29 Oct 2004 17:25:37
Message: <4182b551@news.povray.org>
In article <MPG.1beb1350c94266cd989c01@news.povray.org> , Patrick Elliott
I think you posted the wrong link then.  The link you posted does not point
to a page containing that statement nor does that website mention the word
"hdf" anywhere.  So I am rather confused now.  Is that Linux Journal article
available online somewhere, or could you at least provide the issue
number/month/year?
    Thorsten
Date: 29 Oct 2004 18:11:28
Message: <MPG.1bec6dbaafab7df7989c05@news.povray.org>
In article <4182b551@news.povray.org>, tho### [at] trfde says...
> number/month/year?
>     Thorsten
Sorry.. Not sure if the article is online anyplace. The only link I
know of is the one for the resources used to make the patch:
http://www.linuxjournal.com/article.php?sid=7754
It is November 2004, issue #127, pp. 66
Hmm. I did screw up. I copied the link to someone else's patch. The one
for the articles author, Leigh Orf, is here:
http://research.orf.cx/
Oops! I shouldn't have been quite so enthusiastic about posting and
double checked which link I was posting. Many, many apologies.
void main () {
  else
Date: 29 Oct 2004 18:25:32
Message: <MPG.1bec710a6dbc86cb989c06@news.povray.org>
In article <4182b4b1@news.povray.org>, war### [at] tagpovrayorg says...
I barely use it, though I keep fiddling now and then. The last time I
read the docs cover to cover was 3.1. But I got the wrong link anyway, so
trying to tell me I missed something that already exists is my fault for
confusing the issue. The correct link is:
True, but we are more or less stuck with it for now.
How am I suggesting a new feature? Someone else already did, I just
tried, and do to excessive enthusiasm, screwed up point people to it.
> as scripts.
Oh I agree, I use a plugin system with my telnet client that supports
pretty much any language that has an ActiveScript component, in theory
anyway. Some script engines don't seem to want to start correctly using
the same standard code... Having that later would be very nice. Not
having it now, I wouldn't mind seeing some attempt to unmuddle some of
the frustration with 3D formats anyway. The interface would change when a
plugin system became available and inclusion in an official version would
become irrelevant, but it would be nice to see some of the more common
formats we deal with dealt with more easily. It might even encourage me
to actually read the 3.6 docs and make something with POV-Ray... The
overall lack of money, talent and software I have discourages me to even
attempt most of the time.
Yes. As I said, it is nice that it will be possible in the future, but
for now we are stuck with an insane hodgepodge of stuff that only half
works. It might be nice to see a few basic file types handled a bit more
directly, not to mention gracefully in the mean time.
void main () {
  else
Date: 5 Nov 2004 17:49:51
Message: <MPG.1bf48927a5053f73989c16@news.povray.org>
Ok, so now that I have the correct link, no one wants to comment? Sigh...
void main () {
  else
