POV-Ray : Newsgroups : povray.unofficial.patches : #declares and memory management Server Time
25 Dec 2025 04:03:47 EST (-0500)
  #declares and memory management (Message 1 to 10 of 50)
Subject: #declares and memory management
Date: 18 May 2001 12:41:40
Message: <MPG.156f6f504b27c9c29896b3@news.povray.org>
Hi all,
I know, when #declaring a mesh, it is only loaded only once, so you can
use many instances of it, without running out of memory.
Why isn't this possible with all objects, like a union of 10000 cones for
example?
Maybe there is already a patch out there wich implements this and I just
don't know?
Lutz-Peter
Subject: Re: #declares and memory management
Date: 18 May 2001 14:05:28
Message: <3b056468@news.povray.org>
In article <MPG.156f6f504b27c9c29896b3@news.povray.org> , Lutz-Peter Hooge
> example?
Because it is an implementation feature of the mesh code, not the object
storage code.  There are some side effects how render speed of some other
objects is improved that would be incompatible with such a method, so it is
non-trivial to implement.
> don't know?
I am not aware of any patch that can do this.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 18 May 2001 17:08:27
Message: <MPG.156fade524e59e4a9896b5@news.povray.org>
In article <3b056468@news.povray.org>, tho### [at] trfde says...
Too bad :-( It would be a very useful feature for making large amounts of
plants etc.
What does "non-trivial" mean? Thats it's not possible in, say, 3 hours,
or a day, or two, or so? Or that it is (nearly) impossible?
Lutz-Peter
Date: 18 May 2001 17:56:11
Message: <3b059a7b@news.povray.org>
In article <MPG.156fade524e59e4a9896b5@news.povray.org> , Lutz-Peter Hooge
More than a week to get it into a working state, plus a few month of testing
because it would change something in almost every object, the parser, etc...
   Thorsten
Date: 21 May 2001 06:13:49
Message: <3b08ea5d@news.povray.org>
Lutz-Peter Hooge wrote in message ...
> example?
Becouse you can treat set of triangles as property of object as well as radius
and center for sphere or normal and distance for plane.
Look at summary of sphere definition in megapov 0.7;
- pointers
(Methods,Sibling,Texture,Interior,Interior,Bound,Clip,UV_Trans,Label,Interior_Te
xture,glowList,Trans
- ints (Type,Ph_Flags,No_Shadow_Group, Light_Group,Flags,TimeStamp)
- sngl (BBOX,Ph_Density)
- dbl (Radius,Center)
you can save space for radius where you copy object{MySphere OBJECT_MODS} but
nearly all other properities you reserve for child becouse they can be
overwritten.
this way you get another level of abstract but instead of 4 dbl you must
remember pointer to parent - is it worth ?
#macro Sig(A,B,X)_(A,B)_(B,X)_(X,A)#end#macro _(A,B)cylinder{<A.x,A.y,3>,<B.u,
B.v,3>.1,9}#end global_settings{max_trace_level 9}light_source{0 1}camera{up y
*4right-3*x}blob{_(<3,1>,<1,-5>)_(<2,-2>,<4,-2>)Sig(x,<-1,1.5>,<1,3>)_(z-1,z-4
)pigment{rgb 1}}box{-3 3pigment{rgb 0}finish{reflection 1}hollow} // POV-Ray31
Date: 21 May 2001 07:22:17
Message: <3B08FAAA.71D1F86D@gmx.de>
Probably not in this case, but for a complex CSG it could be useful, just
imagine a lot of macro generated trees...
I know this is probably quite difficult to implement, but NTL it would
offer interesting possibilities.
Date: 21 May 2001 07:49:30
Message: <3b0900c9@news.povray.org>
Lutz-Peter Hooge <lpv### [at] gmxde> wrote:
: Why isn't this possible with all objects, like a union of 10000 cones for
: example?
  Most objects are optimized when certain transformations are applied to
them (in order to eliminate those transformations).
  For example, if you have this:
#declare MySphere = sphere { 0,1 }
object { MySphere scale 10 translate x*20 }
object { Mysphere translate -x*20 }
the result will be internally exactly the same as if you had written:
sphere { x*20, 10 }
sphere { -x*20, 1 }
  The idea is to eliminate the transformations where possible and thus
speed up the rendering. When the ray doesn't have to be transformed, the
intersection test will be faster.
  This same optimization is applied to objects inside CSG groups.
  This is why declared CSG groups can't be used as they are, but they have
to be copied in order to perform the optimizations to the copy.
  This is what I have understood. I might be wrong in some details.
Date: 21 May 2001 08:00:10
Message: <3b09034a@news.povray.org>
I know adventages of this and even curently play with such macros but I think
(it's only personal opinion) that this support in current state of povray is not
worth at level of every object but perhaps it is worth at level of CSG engine.
I just had idea that there could be another kind of object named Clone which
remember only transform and base object. Well... I'll try and check this.
Perhaps whole forest could fit into cache of processor ;)
Date: 21 May 2001 08:18:16
Message: <3B0907CB.80D50255@gmx.de>
Just about what i thought of, i only would use 'reference' rather than
'clone', because a clone is actually a real copy of the original.
Date: 21 May 2001 11:54:05
Message: <MPG.157358c48954dba79896b6@news.povray.org>
In article <3b059a7b@news.povray.org>, tho### [at] trfde says...
Then it would probably not make much sense to start working on this
before 3.5 is available...
Lutz-Peter
