POV-Ray : Newsgroups : povray.unofficial.patches : vectors.inc Attn: Tor Olav (povr branch work) Server Time
20 Jun 2025 18:40:59 EDT (-0400)
  vectors.inc Attn: Tor Olav (povr branch work) (Message 1 to 5 of 5)
Subject: vectors.inc Attn: Tor Olav (povr branch work)
Date: 28 May 2021 09:16:07
Message: <60b0ed17$1@news.povray.org>
OK, I think I've gotten your vectors.inc merged into - and alongside -
the core includes of my povr branch. With vectors.inc becoming one of
the core include files.
Ended up... Sometimes wrapping macros in transforms.inc and math.inc to
call your versions. Sometimes leaving the existing, roughly-equivalent
macros but recommending your version in comments - and using yours over
the old versions otherwise in the core include files.
As anticipated some minor changes in declared IDs due povr's lower case
checking.
Added basic self testing of all the macros as a block appended to the
bottom.
Turned out well. Thank you!
Only suggestion I'll make has to do with the documentation on your
github page at: ttps://github.com/t-o-k/Useful-POV-Ray-macros.
With the VectorsFromTransform() and VectorsFromTransformFunction(),
where you are showing the initialization of v_X, v_Y, v_Z and p_T, ahead
of the macro calls; you could use the, new to v3.8, tuple initialization
syntax. For example:
#declare (v_X,v_Y,v_Z,p_T) = (<0,0,0>,<0,0,0>,<0,0,0>,<0,0,0>);
Bill P.
Subject: Re: vectors.inc Attn: Tor Olav (povr branch work)
Date: 28 May 2021 18:55:00
Message: <web.60b172f7633c4bc4306a434089db30a9@news.povray.org>
Good =)
I'm a bit worried about the wrapping solution. That is because I'm contemplating
a minor change in either the OrthogonalVector() macro or the
AltOrthogonalVector() macro.
If one pass the same vector to both of these, I want the resulting vectors to
always be orthogonal to each other in addition to being orthogonal to the
vector passed to the macros.
Right now it is mostly so. But if if all the components in the passed vector are
equal, this will not be the case (except for the case were the passed vector is
the zero vector).
To fix this I would prefer to change the order of the "ifs" in the
If the old VPerp_To_Vector() macro is changed to call (wrap) the new
OrthogonalVector() with reordered "ifs", it will break scenes using the
VPerp_To_Vector() macro.
So now I'm not sure what to do...
> checking.
> bottom.
Thank you too !
I tried to look for your new core include files at your github pages, but I
could not find them there. Are they visible somewhere else ?
I had forgotten about this new initialization type. I've now changed the
examples to use it.
I've also changed the parameter names of the AccurateAngleBetweenVectors()
macro, so that are in line with the names in the other macros.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 28 May 2021 21:45:00
Message: <web.60b19bba633c4bc41f9dae3025979125@news.povray.org>
2 things here:
1.  I may be wrong, but I was under the impression that povr is a fork, and it's
purpose is to improve and fix some longstanding issues with the official povray
source code.  So breaking older scenes is probably not the primary concern.
2.  I thought that this was what the #version directive was for.  Can't you
sniff the scene version and include a fork in the wrapper?   If the version is
old, use the old way, and if it's new, use the new way?
-Bill
Date: 28 May 2021 23:07:58
Message: <60b1b00e$1@news.povray.org>
> Good =)
> the zero vector).
Change your code as you'd most like.
Indeed, I now have in math.inc:
// Returns a vector perpendicular to V
// Author: Tor Olav Kristensen
// See: OrthogonalVector() and AltOrthogonalVector() in vectors.inc
#macro VPerp_To_Vector(v0)
   //#error "VPerp_To_Vector in math.inc called. Use OrthogonalVector()"
     OrthogonalVector(v0)
If need be, I can restore the old code. However, I think you are talking
about differences 'only' with <1,1,1>, <-1,-1,-1> and the like - yes?
And given I suspect folks might occasionally use OrthogonalVector() with
AltOrthogonalVector(), maybe the OrthogonalVector() as the
VPerp_To_Vector result is ultimately better too even changed.
What kind of trouble might we get into if we leave the wrap post your
changes... My gut says nothing practically, but I guess the ultra safe
approach would be to revert VPerp_To_Vector() - but then povr has three...
In any case, I think doing what's ultimately best in vectors.inc is the
way to go for the future.
I've been releasing occasional tarballs in povray.binaries.programming,
but none of this work is posted as yet.
I'm under code control locally, but I don't yet want to put what I have
out there as code controlled until my code is closer to I have in mind
for the final form. I plan to initialize it anew at some point. An
issues we have with the current POV-Ray git repositories is they are
carrying around a huge history for what the povr core code base is.
> examples to use it.
Cool.
Something I forgot to say explicitly is povr is v3.8 parsing + povr
changes. That said, often, straight v3.8 stuff runs and once I had all
the test cases in place, I did run the testing with a pure v3.8 compile
and all was OK.
Ya know... I was thinking only v3.8 when mentioning the tuple feature
new to v3.8. I think you were aiming for v3.7 and v3.8 with vectors.inc
and, if so, might be worth a footnote where you've used the tuple syntax
saying that it's a v3.8 feature. Or go back to the v3.7 example. Always
the details...
Bill P.
Date: 28 May 2021 23:21:03
Message: <60b1b31f$1@news.povray.org>
> 2 things here:
Yes, the povr branch breaks what it needs to break to fix longstanding
issues - and to evolve more radically(1). It's a big part of the aim of
of it.  So yep, the change likely doesn't matter even if it does break
something...
(1) - So I can try more of what I want to try... :-)
I suppose, but I'm trying to avoid as much of that sort of thing as
possible with povr. I've been ripping out backward compatibility stuff
as I can for a long time now and there is still lots of it in there...
Rambling. At a high level I think about the ever backward comparability
in POV-Ray proper and it's kind of amazing it's been kept up. I mean it
all more or less works! For what I'm doing it's just not possible in
many cases - hammer in hand, I'm  breaking stuff.
Bill P.
