POV-Ray : Newsgroups : povray.unofficial.patches : Initial povr branch keywords id_type() and id_types_match() Server Time
13 May 2025 04:18:49 EDT (-0400)
  Initial povr branch keywords id_type() and id_types_match() (Message 1 to 10 of 20)
Subject: Initial povr branch keywords id_type() and id_types_match()
Date: 24 May 2021 12:42:37
Message: <60abd77d$1@news.povray.org>
In povray.general we recently discussed implementing some limited type
checking. Attached is an include files showing testing for two new
keywords in the povr branch called id_type() and id_types_match().
Note. Though the id values often change from release to release I found
an id_type() works in a switch statement making the id_type() worthwhile
too, I thought.
#include "id_types.inc"
Mcr_ID_type(ID_type_float)
Mcr_ID_type(ID_type_string)
Mcr_ID_type("Hello")
Mcr_ID_type_test()
#error "\nTesting. Stop early\n"
An excerpt of the output follows showing the current povr values for
certain types. Notably the parser treats some things we might think of
as separate as the same internal ID.
float       = 27.0
string      = 527.0
vector2D    = 584.0
vector3D    = 71.0
vector4D    = 592.0
vector5D    = 95.0
dictionary  = 209.0
array       = 121.0
array_mixed = 121.0
sphere      = 390.0
box         = 390.0
object      = 390.0
merge       = 390.0
union       = 390.0
color       = 95.0
finish      = 247.0
normal      = 381.0
pigment     = 420.0
texture     = 542.0
Bill P.
Download 'id_types.inc.txt' (5 KB)
Subject: Re: Initial povr branch keywords id_type() and id_types_match()
Date: 24 May 2021 13:06:49
Message: <XnsAD34C26E9EB42seed7@news.povray.org>
Very useful. Thanks,
Ingo
Date: 24 May 2021 14:20:00
Message: <web.60abedc3827c6b078e52cc8789db30a9@news.povray.org>
> too, I thought.
Nice !
Can it also be used with different functions types, splines, matrices,
transforms, materials, file descriptors, light sources, cameras, color maps, and
other maps ?
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 24 May 2021 23:22:40
Message: <60ac6d80$1@news.povray.org>
>> too, I thought.
> other maps ?
Played with these more tonight and I'm now leaning toward dropping
id_types_match(). As with most things the more I played the more the
hidden gotchas popped out, and the more complex the code got.
Answers to your category/type questions are mostly yes. Functions come
in two types depending on whether they return doubles or vectors. Light
sources I've not tested as yet, but I think those have always been
considered objects and so will likely get lumped with spheres et al(1).
In some oddness, there is a MACRO_ID_TOKEN, but it's impossible to
evaluate macro names because once they exist the parser attempts to run
them. I don't see a way to work around it - excepting maybe via some
very messy methods.
Bill P.
(1) - It's only code, as an old friend used to say to my enhancement
requests. :-) Likely some way to tell the object is really a light and
we could then set some bogus, large value maybe - or negative values.
There are, I know, some object type 'flags' that get set when objects
are created. We'll see.
Date: 25 May 2021 04:45:00
Message: <web.60acb7fd827c6b0779819d986cde94f1@news.povray.org>
hi,
this looks v promising.  am  a little confused by the sample output posted,
expected, for example, the four vector types to have (somewhat) related ids.
> very messy methods.
testing via 'defined(macroname)'?  (not tried it with macroname as string, but
maybe Parse_String could help then).
regards, jr.
Date: 25 May 2021 06:30:37
Message: <60acd1cd$1@news.povray.org>
This is partly because internally the vector types are:
UV_ID_TOKEN, VECTOR_ID_TOKEN, VECTOR_4D_ID_TOKEN and COLOUR_ID_TOKEN.
The token enums are also sometimes also ordered into sections -
internally called catagories. The VECTOR_ID_TOKEN is in a vector
category grouping while the others are not for other reasons of parsing
code I guess. The COLOUR_ID_TOKEN is exempt from the color category too(1).
I think it's because there is, for example, color/colour keywords and so
to color IDs. I don't think there is a 'vector' keyword, so vector ids
can be lumped with other generic vector stuff like vcross.
I'm not completely sure of all of it, there isn't a uv keyword, but
maybe because we have uv_vectors? I don't know.
>> very messy methods.
I found a solution using the new to v3.8 global dictionary. You have to
code macros with the 'global.' prefix...
Supposing I have a macro wrapping id_type():
#macro Mcr_id_type(_id)
     id_type(_id)
so I can create IDs on the fly as in:
#debug concat("float id = ",str(Mcr_id_type(1.2*(1/3)),4,1),"\n")
I can then grab the Mcr_id_type macro's id type number with:
#debug concat("macro = ",str(id_type(global.Mcr_id_type),4,1),"\n")
Bill P.
Date: 25 May 2021 08:45:00
Message: <web.60acf04e827c6b0779819d986cde94f1@news.povray.org>
hi,
>      id_type(_id)
> #end
neat.  (lucky there's a non-"messy" way :-))  question: does 'id_type()' rely on
any 'povr' branch only features, or could it be implemented as-easily in POV-Ray
too?  (and if yes, when??  :-))
regards, jr.
Date: 26 May 2021 06:47:00
Message: <60ae2724$1@news.povray.org>
> too?
You, and that concept of easy... ;-) As implemented it's a stand alone
bit of code.
Aside: I did manage to use some of the object flags to break out
light_sources, csg (merge,union,difference,intersection), light unions
and light groups from the object id category. The id sub-catagories Left
in as probably more useful than not, but there is the nagging thought it
might somewhere be the wrong thing to do.
Bill P.
Date: 27 May 2021 02:10:00
Message: <web.60af3771827c6b0779819d986cde94f1@news.povray.org>
hi,
> > too?
my ignorance wrt POV-Ray source stands me in good stead..  :-)
> As implemented it's a stand alone bit of code.
that is good.  (afaict)  so it could be issued as a patch to the 3.8.0-alpha?
forgot to thank you for the vector id background info.  read in conjunction with
the above, I'm thinking a two function approach perhaps, 'id_type' much as is,
supported by a similar function which returns an 'array mixed' with the various
"properties"/categories broken out?
regards, jr.
Date: 27 May 2021 05:50:17
Message: <60af6b59$1@news.povray.org>
On 5/27/21 2:08 AM, jr wrote:
> hi,
>>> too?
:-) Me alongside. Nobody understands the whole of the code base.
Could be. Yes.
What I've not done for arrays vs mixed arrays as yet is look for a
method 'like' that employed to break out a few of the object types like
light sources(1). The object flags popped into my head on Tor Olav's
question.
Even without getting different type ids for arrays vs mixed arrays today
from id_type, you can walk a mixed array asking about the types for each
element and in that way via SDL looping (or your foreach work) build up
what types in total are seen for any given the mixed array.
(1) - Strictly, the information isn't needed for code safety sake. We
can today (v3.8) employ the back door type checking I mentioned
'somewhere' to be sure types coming in via mixed arrays are consistent -
when then need to be. I used the technique while adopting Tor Olav's
array statics macro suggestions. Let me see, as two examples, I used the
trick with his Mean and Minimum macros which now look like:
#macro Mean(Values)
     #local N = dimension_size(Values, 1);
     #local Sum = array[1] // Fixed array types cannot change.
     #local Sum[0] = Values[0];
     #for (I, 1, N - 1)
         #local Sum[0] = Sum[0] + Values[I];
     #end // for
     (Sum[0]/N)
#end // macro Mean
#macro Minimum(Values)
     #local Min = array[2] {1,1} // Fixed array types cannot change.
     #local Min[0] = Values[0];  // Better err msg - min() floats only.
     #for (I, 1, N - 1)
         #local Min[1] = Values[I]; // Better err msg.
         #local Min[0] = min(Min[0], Min[1]);
     #end // for
     Min[0]
#end // macro Minimu
Bill P.
