POV-Ray : Newsgroups : povray.unofficial.patches : Initial povr branch keywords id_type() and id_types_match() Server Time
20 Jun 2025 23:13:04 EDT (-0400)
  Initial povr branch keywords id_type() and id_types_match() (Message 11 to 20 of 20)
Subject: Re: Initial povr branch keywords id_type() and id_types_match()
Date: 28 May 2021 03:50:00
Message: <web.60b0a043827c6b0779819d986cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 5/27/21 2:08 AM, jr wrote:
> >> As implemented it's a stand alone bit of code.
> > that is good.  (afaict)  so it could be issued as a patch to the 3.8.0-alpha?
> Could be. Yes.
nice.
> > supported by a similar function which returns an 'array mixed' with the various
> > "properties"/categories broken out?
> What I've not done for arrays vs mixed arrays as yet is look for a
> method 'like' that employed to break out a few of the object types like
> light sources(1). The object flags popped into my head on Tor Olav's
> question.
I put this badly.  meant that 'is_type()' probably "will do" for most use cases,
and so perhaps a complementary function (eg) 'is_type_details()' which returns
an array mixed, where the various flags are used to distinguish one ("390")
object from another.
> Even without getting different type ids for arrays vs mixed arrays today
> from id_type, you can walk a mixed array asking about the types for each
> element and in that way via SDL looping (or your foreach work) build up
> what types in total are seen for any given the mixed array.
not sure I really understand.  if some macro expects an array mixed parameter,
say {3-vect, string, bool}, I do not know of a "safe" way to check all three.
for instance, whether I use 'strlen(string)' or similar, if it's not a string,
POV-Ray will "intervene".  (did I misread?)
(and the (snipped) macro examples too, while safe to use, would not allow me to
catch (as in handle with own error message) the eventual "odd" value, I think)
regards, jr.
Date: 28 May 2021 07:00:34
Message: <60b0cd52$1@news.povray.org>
On 5/28/21 3:48 AM, jr wrote:
> hi,
>> question.
Yes, is_type_details(), a possibility, but it would be work creeping
well past "easy."
Aside: For the details which could be provided as strings of text as to
type, my thought was this work would be pushed onto users - or some
include file maintainer - in the form of a macro containing a big switch
kicking out text or setting up an array with, say, response strings:
"The is type passed to MagicMacro24 is a light_source."
You understood. What I coded up there is checking on the cheap; POV-Ray
does it and the result is an internal parser error. What I had in mind
for what I think you want to do - using id_type() - is something like
the attached test case. Yes/No?
Bill P.
Download 'utf-8' (3 KB)
Date: 28 May 2021 08:30:00
Message: <web.60b0e0d4827c6b0779819d986cde94f1@news.povray.org>
hi,
> >> question.
> well past "easy."
I was about to suggest (almost) the opposite.  :-)
thinking that if one (you :-)) were to set up an enum, covering the basics
(float, bool, vector, macro, function, array, string, such[*]), then changing
(in the parser, between versions) ids could be "contained" in one mapping.  then
'is_type()', and later perhaps its companion func, would always provide
consistent "numbers".  and yes, some include file to turn the numbers back into
human speak would be v useful (will collaborate if thought helpful).
[*] off the top of my head.  in most ("95%") situations, I think, just knowing
it's "an array", say, without the "fall out" from using 'dimensions(foo)' when
it isn't, will suffice.
thanks.  will look at code tonight/tomorrow.
regards, jr.
Date: 28 May 2021 09:12:26
Message: <60b0ec3a$1@news.povray.org>
On 5/28/21 8:23 AM, jr wrote:
> hi,
>>>> question.
>> well past "easy."
Suppose it could be done by running a script to build such a cross index
as a check in hook or something.
There is today a basic enum to cross reference in the code that gets
used when reporting messages and such. We're basically talking about
some parallel ID enum to locked integer index I guess - which
is_type_details() or similar could use... I'll think about it, but at
the moment it all feels a bit clunky /ugly given the minor value to end
users.
Bill P.
Date: 29 May 2021 02:55:00
Message: <web.60b1e474827c6b0779819d986cde94f1@news.povray.org>
hi,
> > thinking that if one (you :-)) were to set up an enum, ...
> used when reporting messages and such. ...
if that implies that the enumeration is sort of stable, perhaps it can be
"pressed into service"?
re the 'is_type()' code -- SDL user me says "Yes".  :-)  fwiw, I like this:
  #if (id_type(_mary[1]) != Mcr_id_type("Star dust falls"))
"idiom" a lot.
(also made me wonder what was playing on your radio while you wrote that code.
UFO's "Prince Kajuku"??  "Catch a falling star put it in your pocket..."
<https://www.youtube.com/watch?v=KSBIDIZ6ySc> :-))
regards, jr.
Date: 29 May 2021 07:54:53
Message: <60b22b8d$1@news.povray.org>
It is in service with is_type(), but is itself not stable as keywords
and keyword groupings change. Could an 'intended stable' form be created
/ maintained - sure. Is it worth the trouble - ehhh...
> re the 'is_type()' code -- SDL user me says "Yes".:-)   fwiw, I like this:
> "idiom" a lot.
References to 'radio' will lead the kids reading to think we're ancient.
The youtube link was perhaps enough to fool em - that we're playing with
POV-Ray won't help. ;-)
As for what's playing in my head... A storm, always about three beats
from incoherence. When I listen to music while coding, it's
meaningful-vocal-less. Thinking, reading, coding in a public place where
the sounds are a vibration, where only an occasional word or two pops to
the surface, is best.
Anyhow. Let me know when I've gone over the edge - another one. I'm
still upright - I think.
Bill P.
Date: 29 May 2021 08:05:00
Message: <web.60b22d81827c6b071f9dae3025979125@news.povray.org>
Just call it "wireless".  A term so old, its new again.
"More than just a pixel shader...."
Don't call them "edges" - call them "new frontiers".
Date: 29 May 2021 09:17:05
Message: <60b23ed1$1@news.povray.org>
Ah! We just have to apply enough spin... :-)
Date: 29 May 2021 11:45:00
Message: <web.60b26123827c6b0779819d986cde94f1@news.povray.org>
hi,
so.  an include with one macro and version specific data, then?
:-)  recognise the preference (?) for instrumentals.  (cannot usually relax
enough in a public place to .. let my mind wander)
regards, jr.
Date: 29 May 2021 16:48:47
Message: <60b2a8af$1@news.povray.org>
Yeah, one could have a  macro - include which sets up an array of the
values as they sit each version of code . Basically a bunch of calls to:
#macro Mcr_id_type(_id) id_type(_id) #end
setting up an array (or dictionary) which you'd then reference in
compares to id_type() instead of calls to Mcr_id_type().
Bill P.
