POV-Ray : Newsgroups : povray.unofficial.patches : On the long unfinished normal related warps in warp.cpp. Server Time
12 Nov 2026 19:42:41 EST (-0500)
  On the long unfinished normal related warps in warp.cpp. (Message 1 to 6 of 6)
Subject: On the long unfinished normal related warps in warp.cpp.
Date: 17 May 2021 09:00:10
Message: <60a268da$1@news.povray.org>
The warp.cpp source code has long had some unfinished normal related
warp and unwarp hooks. Those of us working on the code of late haven't
really understood them - as far as I know.
Patterns today work in the normal block with all sorts of transforms and
warps, so those hooks are aimed at...?
While working of late on normal block patterns it hit me we don't warp
the incoming normal, but rather the perturbation patterns/methods via
the unwarped / warped EPoint(1). We cannot today warp the incoming raw
normals with warp{}s.
So, I started to play with an idea for new normal pattern which
allows/enables this. It's currently working with the difference between
the intersection location and the warp{} / turbulence affected EPoint.
In other words, there isn't an actual specific perturbation method /
pattern - it's whatever your warp{}s create.
Attached are a couple of images. One uses three repeat warps and a touch
of turbulence. The second a spiral -> turbulence -> spiral combination.
Still playing / thinking, but looks promising.
Bill P.
Download 'nrmlpertbywarps.jpg' (77 KB) Download 'nrmlpertbywarps1.jpg' (85 KB)
Preview of image 'nrmlpertbywarps.jpg'
Preview of image 'nrmlpertbywarps1.jpg'
Subject: Re: On the long unfinished normal related warps in warp.cpp.
Date: 17 May 2021 14:30:00
Message: <web.60a2b54ee71bfb471f9dae3025979125@news.povray.org>
So, when I was coding some C++ stuff, I had to puzzle out passing things by
pointer, reference, or value.  Some of the code in the section we're talking
about I can read just fine - the stuff with the "->", notsomuch.
I have read that 4 or 5 times, and I think I understand it and agree.  :)
So it would be much like doing normal {null warp repeat x turbulence 0.3}
where "null" is just sort of like an identity matrix - no change.
That second one seems like it has real potential.  Given that one of the mothods
for arranging things "evenly" on the surface of a sphere is using a spiral /
loxodrome, then accomplishing a very close approximation to that using only a
simple normal statement would be a really powerful and welcome development.
This reminds me of my unsolved problem applying normals to bezier patches:
http://news.povray.org/web.5f6a91889d9b31d91f9dae300%40news.povray.org
regarding
https://news.povray.org/povray.binaries.images/message/%3Cweb.5f45adba5d69181b1f9dae300%40news.povray.org%3E/#%3Cweb.5f
Do you have any inkling if the uv-mapping coordinates affect the application of
the normal pattern, and where in the code that factors in?  Because I see that
as being another thing that's hiding in there that we might not be fully aware
of.
So I guess maybe what I'm asking is, do the uv-mapping vectors override the
global POV-space location vectors, in essence (locally/temporarily) redefining
the EPoint?  And with regard to applying a global normal pattern that is
dependent upon an object's location in POV-space, is this desirable, expected,
and can it be overridden?
Date: 18 May 2021 06:53:08
Message: <60a39c94$1@news.povray.org>
(1) - I forgot to add the planned footnote in my original post. :-) Was
just some ramble about options and complications.
Yes, that's a good way to think about it. Might even add 'null" as the
normal pattern name in the end(2) - it's currently the default option in
the normal bevy "collection."
(2) - I'm playing with two actual methods. "null type n" - don't know.
Yes, I've been thinking some about geodesic centered - normal direction
sets where the incoming normal would be matched to closest direction
match creating a frame for normal perturbations. As you suggest, others
possible.
I need at some point to go back and work more on the black hole
'spherically contained' warps. Perhaps adding cylindrical black holes,
etc, with an ability to orient to an arbitrary direction vector. With
warps too there is more possible.
> regarding
> of.
I've not spent any time looking at it, but there is a normal block uv
mapping in normal.cpp. I don't use uv mapping much, but when active it
should map the intersection location on the uv map-able shape/object to
the appropriate 2d uv map position in the normal pattern in the 0-1, xy
square in the z=0 plane. Said another way, when uv mapping normals you
are explicitly setting the perturbed normal for the 3d surface
intersection from a 2d map. This is the normal pattern method if uv
mapping used for the normal block of the texture.
A point on your first link, given the questions asked there. There is
only one normal per material/texture for an object. That normal can
itself be and average, normal list or normal map of other normals, but
it's one normal as included in the texture. When you add a normal block
after an existing texture on an object as follows:
sphere { ... texture { T_wNormal } normal { granite } }
The normal in the sphere's texture is now 'normal { granite }' with
everything else the same; the normal originally in the texture
T_wNormal is gone for this sphere's texture.
> the EPoint?
If I understand your question, yes, in that you are not using a warped
EPoint when uv mapping. The 'EPoint' is the local shape intersection
point.
Again not quite sure I follow. You can delay defining all shape's
textures until you are at the global scene level. Say a set of 50
spheres in a union where the (not uv mapped) texture including the
normal is defined at the union definition or later. There the position
of the 50 spheres within the texture eventually applied will result in
differences sphere to sphere.
Bill P.
Date: 18 May 2021 13:35:00
Message: <web.60a3fa8ae71bfb471f9dae3025979125@news.povray.org>
> point.
OK
What I'm asking about is the separability of the texture and the normal.
Can I have a distinct uv-mapped texture for each object (which is bounded /
defined by the uv vectors), but have them all share a "regular" normal that
extends throughout all of POV-space and is calculated based on the POV-space
<x,y,z> location vector?
So: can I apply a POV-space normal to an object but then also apply the local
shape intersection point uv-mapped texture.  Or some other way of accomplishing
the same end result.
Date: 18 May 2021 14:56:24
Message: <60a40dd8$1@news.povray.org>
OK. Thanks. I believe I better understand your question.
With the repeated disclaimer I'm not a regular uv map user, I think the
answer is no, but...
The reason is uv mapping works with primitives(1). It's a mechanism
which associates the ray intersection on the surface of that primitive
with a 2d map position. This mapping comes from the primitive
shape/surface code and is the same for pigments and normals.
(1) You can use the uv_mapping keyword for csg entities, but I believe
it simply does a default (planar?) map. Somewhere in recent years there
are posts related to someone trying this.
Because uv mapping works at the primitive level you must define a
texture's pigment and normal mapping at the base shape/surface - and
once (a) texture(s) are defined for the surfaces of something - they are
set - even if the object is included in later CSG. You cannot change
them or add to them.
--- but
What you should be able to do - since you can define pigments and
normals independently ahead of inclusion in a texture for each
shape/surface - is use different maps for the pigment and normal
uv_mapping for 'each' low level uv map-able thingy. Pigments, normals or
both could use maps created for the object as they need to be when
placed in global space. No automation for this as far as I know - you'd
have to work out how to create the thingy by thingy map(s) cut from
global space on your own.
All as far as know - maybe I've got something wrong, or someone has done
something clever(2).
Bill P.
(2) - A very rough idea would be to do something with _map values based
on passing global space values to a function, but I don't see all of how
it would work at the moment - and the _map would either be huge to
encompass all the global positions or limited. Another idea might be to
make use of povr like normal chaining within average maps, but I have no
idea, if, or how uv mapped normals might work/act within a normal {
average ... } alongside other types of normals. Never tried to mix uv
mapped types with others for pigments or normals.
Date: 18 May 2021 21:00:00
Message: <web.60a46299e71bfb471f9dae3025979125@news.povray.org>
> --- but
So, I could define a function that translated an <x, y, z> coordinate (that is
used internally to calculate a uv coordinate) to a projected <x, y, z>
coordinate that is outside the range of the 0-1 uv vectors of the local space...
<insert headache here>
Then do normal {function {f_translate (x, y, x)}, which should should remap the
local <x, y, z> mapping of the uv vectors to a projected set of uv vectors that
in turn correspond to the actual spatial positions of the bezier patch...
Egads.
I'm a _little_ surprised that no one has ever brought this up before, but then
again, I'm always going off into the weeds when doing what seem to be perfectly
ordinary things...
I'm wondering if you were to implement this in povr source, if it would be as
simple as defining a "no_uv" normal type that simply uses the native EPoint
instead of the uv_vector coordinate.
I will have think a bit more on this and see when I can puzzle out something
functional [sic].
Thanks for the analysis and ideas for a solution   :)
