POV-Ray : Newsgroups : povray.unofficial.patches : Lean toward point normal patterns (povr branch) Server Time
16 May 2026 16:39:25 EDT (-0400)
  Lean toward point normal patterns (povr branch) (Message 1 to 1 of 1)
Subject: Lean toward point normal patterns (povr branch)
Date: 10 May 2021 08:45:31
Message: <60992aeb$1@news.povray.org>
Elsewhere the idea of leaning toward a point in space as a normal
pattern was discussed. In an initial povr branch implementation ended up
with two forms of the pattern. One for use in averages with other
patterns and another which comes after the zero weighted perturbed
pattern prior that adds the lean on top of the previous perturbation.
These are 'bevy type 3' and 'bevy type 4' below, respectively.
In the attached image the upper left corner is the original sphere with
no normal{} perturbation. In the upper right only a lean toward +y. In
the lower left an average of normals where one pattern wrinkles like and
the other the lean toward point. In the lower right the second form
which leans the already wrinkle perturbed normal to create a final
perturbed normal.
The code for the lower two images looks like:
  average
  normal_map {
       [1 bevy type 1 bump_size 0.5]
       [1 bevy type 3 bump_size 0.5] // lean
and
  average
  normal_map {
       [0 bevy type 1 bump_size 0.5]
       [1 bevy type 4 bump_size 0.5] // lean normal perturbed above
where currently 'bevy' is a normal perturbation pattern really a
collection of experimental normal patterns of which two are the leaning
kind(1). Type 1 is a possible non-biased wrinkles replacement.
Bill P.
(1) - Wondering if types not the better way to go over keywords when
patterns are related - otherwise the number of keywords starts to explode.
Download 'normalleanstory.jpg' (24 KB)
Preview of image 'normalleanstory.jpg'
