POV-Ray : Newsgroups : povray.unofficial.patches : Hgpovray38, current state Server Time
16 May 2026 14:03:20 EDT (-0400)
  Hgpovray38, current state (Message 31 to 40 of 48)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Hgpovray38, current state
Date: 24 Oct 2020 11:59:23
Message: <5f944f5b$1@news.povray.org>
Le 23/10/2020 à 16:10, Mr a écrit :
> Le_Forgeron <jgr### [at] freefr> wrote:
>> For the people who do not want to bother with git, Hgpovray is now
>> available as sources
https://github.com/LeForgeron/povray/releases/tag/v3.8.0.alpha%2BHg.226-Thermidor-30
>> More works on the agenda :
>> http://wiki.povray.org/content/User:Le_Forgeron/HgPovray38
> Hello, ...With the set of default scenes, the advanced/abyss.pov shows a black
> background behind submarine instead of blue with current 3.8 plain pov master.
Can you identify the version of hgpovray38 ?
Date: 24 Oct 2020 12:11:10
Message: <5f94521e$1@news.povray.org>
Oups, my bad. 226 Thermidor is 2 years old.
I will check with the latest head.
Date: 24 Oct 2020 12:26:56
Message: <5f9455d0$1@news.povray.org>
Ok, happens also with latest head. I will have to search when it
started, not fun as I did not play with media.
Date: 24 Oct 2020 18:00:00
Message: <web.5f94a2aab933d8376adeaecb0@news.povray.org>
maybe color models are to be suspected as so many  relatively recent changes
happened ?
(rgb > srgb rgbf rgbt RAL...)
Date: 24 Oct 2020 21:40:01
Message: <web.5f94d666b933d8371f9dae300@news.povray.org>
> happened ?
Works ok in (qtpovray)3.8, using #version 3.6 and #version 3.8
Line 786 has a negative light source, so maybe scroll down to that section and
start commenting out some lights and see what happens.
after that is // submarine and media
light in lines Line 73 & 74 has media_interaction off
Other than that - no idea.
Date: 25 Oct 2020 05:33:26
Message: <5f954666$1@news.povray.org>
>> happened ?
Negative light are honored, not the problem.
Commenting the media in the last union, get the same bad result as
hgpovray38 with povray master 3.8;
Date: 25 Oct 2020 05:57:40
Message: <5f954c14$1@news.povray.org>
>>> happened ?
Ok, I can fix it... but I do not understand yet why it happened and how
it works.
diff --git a/source/core/render/tracepixel.cpp
b/source/core/render/tracepixel.cpp
index 6d661b07..50d420a1 100644
--- a/source/core/render/tracepixel.cpp
+++ b/source/core/render/tracepixel.cpp
@@ -235,7 +235,7 @@ void TracePixelCameraData::SetupCamera(const Camera&
cam)
     bool normalise = false;
     camera = cam;
     useFocalBlur = false;
-    //precomputeContainingInteriors = true;
+    precomputeContainingInteriors = true;
     cameraDirection = camera.Direction;
     cameraRight = camera.Right;
     cameraUp =  camera.Up;
Date: 25 Oct 2020 08:04:34
Message: <5f9569d2$1@news.povray.org>
I'd not have looked if not for the claim of the same bad results in
povray master 3.8, but I branched off the last commit to master and I do
not see that line in tracepixel.cpp commented. (I've not run the test case)
If any help, I went on to look at the state of tracepixel.cpp for every
commit since the move the github. I see twelve up to v3.8 master head
and none have the precompute... line commented.
> it works.
> cam)
>       camera = cam;
Date: 25 Oct 2020 08:45:43
Message: <5f957377$1@news.povray.org>
Latest package:
https://github.com/LeForgeron/povray/releases/tag/v3.8.0.alpha%2BHg.229.Betterave
Date: 26 Oct 2020 02:40:00
Message: <web.5f966e17b933d8376adeaecb0@news.povray.org>
> Latest package:
Thanks ! It does render with blue background now.
Next issue is when I try to render the grenadine scene, I get a "Parse Error:
Cannot open include file lemon.inc." (disregarding any +L option).
That however could also happen with standard povray 3.8.
