POV-Ray : Newsgroups : povray.unofficial.patches : Hgpovray38, current state Server Time
16 May 2026 14:03:20 EDT (-0400)
  Hgpovray38, current state (Message 19 to 28 of 48)
Subject: Re: Hgpovray38, current state
Date: 3 Jun 2020 17:45:03
Message: <web.5ed8198db933d8376adeaecb0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> one hack-ish workaround could be to separate out the operations, ie in C I might
> do something like:
> size_t const n = strlen(Get_Token_String(...));
> char tmp_compound[4 + n] = {'\0'};
So instead of this:
char tmp_compound[4+strlen(Get_Token_String(CYLINDER_TOKEN))];
....and after adding the same include in parser_strings.cpp, I used:
const ssize_t n = strlen(Get_Token_String(CYLINDER_TOKEN));
char tmp_compound[4 + n];
And still error messages from the same line not eval to const also tried with
const int n = strlen(Get_Token_String(CYLINDER_TOKEN));
Date: 4 Jun 2020 04:55:00
Message: <web.5ed8b565b933d8374d00143e0@news.povray.org>
hi,
> > do something like:
> So instead of this:
two points.  the 'strlen()' function returns a 'size_t', that is, an unsigned
value, while both 'int' and 'ssize_t' hold signed values; however, if that was
the problem you would have seen "warning: conversion to..." messages, not
errors.
second, I just downloaded 'Hg.226.Bigarade' and built it; one single warning
message aside, the program builds cleanly (on a Slackware GNU/Linux box).  so,
sorry, cannot help any further, but my advice is: either create a virtual
machine running a Linux, or install 'cygwin'[*], or explore whether the Windows
10/Ubuntu thing works for you.
(I read the following quote in someone's signature block years back
(paraphrased): "computers are like air-conditioning, they stop working when you
open Windows."  ;-))
[*] there are other s/wares too, like 'MinGW'.
regards, jr.
Date: 4 Jun 2020 09:25:00
Message: <web.5ed8f5ceb933d8376adeaecb0@news.povray.org>
> hi,
> > > do something like:
> > So instead of this:
> errors.
> open Windows."  ;-))
> regards, jr
Sorry since my purpose is blender exporter use.  I can't afford to not be cross
platform
Date: 4 Jun 2020 10:25:00
Message: <web.5ed9032bb933d8374d00143e0@news.povray.org>
hi,
> ...  I can't afford to not be cross platform
you know that POV-Ray builds, you know that Hg is derived from the same sources.
 it would be a lot of work, but if you worked through the differences in the
sources, perhaps aided by single-stepping (with debugger) through POV-Ray
execution, you could (likely) find out exactly what
'Get_Token_String(CYLINDER_TOKEN)' returns, and what else matters at that point
in the code.  sorry to be of little/no help.
regards, jr.
Date: 4 Jun 2020 18:55:00
Message: <web.5ed97b6fb933d8376adeaecb0@news.povray.org>
> hi,
> regards, jr.
I had tried but could not find 'Get_Token_String(CYLINDER_TOKEN)' used in the
same context in POV-Ray trunk source, I may have searched wrong.
Just trying to help would already be a lot! besides I do have the impression
that you did unlock a few a step forwards. thanks !
Date: 5 Jun 2020 04:15:00
Message: <web.5ed9fdf4b933d8374d00143e0@news.povray.org>
hi,
thanks for the .. vote of confidence.  (flattery will get you anywhere..  :-))
I've created two 'tags' files with the symbols/names used in the sources.
searching them for 'Get_Token' gives me:
jr@swift:1:tmp$ xzgrep -n Get_Token hg_tags.xz
46500:Get_Token
povray-3.8.0.alpha-Hg.226.Bigarade/source/parser/parser_tokenizer.cpp 317;" f
class:pov_parser::Parser
46501:Get_Token_String
povray-3.8.0.alpha-Hg.226.Bigarade/source/parser/parser_tokenizer.cpp 1701;" f
jr@swift:2:tmp$ xzgrep -n Get_Token pov_tags.xz
45379:Get_Token povray-3.8.0-alpha.10064268/source/parser/parser_tokenizer.cpp
210;" f class:pov_parser::Parser
45380:Get_Token_String
povray-3.8.0-alpha.10064268/source/parser/parser_tokenizer.cpp 877;" f
jr@swift:3:tmp$
you can download the listings from here:
<https://drive.google.com/file/d/10RaLHKnogRE6ikkiaybHMP4d8ezyZfH9/view?usp=sharing>
<https://drive.google.com/file/d/10ThvgvOXlnSnHJrlAVdiV1UF1fcRpAIZ/view?usp=sharing>
they're about 20M each, so I have used 'xz' to compress, you can use 'WinRAR' to
uncompress if you don't have an 'unxz' installed.
regards, jr.
(reply via email if you feel this discussion is a bit off-topic)
Date: 9 Jun 2020 14:55:00
Message: <web.5edfd9cab933d8376adeaecb0@news.povray.org>
> hi,
> 46500:Get_Token
> jr@swift:3:tmp$
> regards, jr.
The solution from this page seems to bring me a step further:
https://stackoverflow.com/questions/33423502/expression-did-not-evaluate-to-a-constant-c
so...
becomes
char* tmp_compound = new char[4+strlen(Get_Token_String(CYLINDER_TOKEN))];
Now I'm left with new lnk errors of "unresolved external symbols"(?) in
povcore64d.lib(tracepixel.obj)
Date: 3 Oct 2020 19:25:01
Message: <web.5f79074bb933d8376adeaecb0@news.povray.org>
> > hi,
sources.
point
> > 46500:Get_Token
> > jr@swift:3:tmp$
> > regards, jr.
> so...
> becomes
Hi, I went on trying:
....Then removing deprecated binary_function following this page helped me clear
the next issue:
https://stackoverflow.com/questions/22386882/why-have-unary-function-binary-function-been-removed-from-c11
So in compare_pointees.hpp line 36 may become:
struct equal_pointees_t {
  bool operator() ( OptionalPointee const& x, OptionalPointee const& y ) const
    { return equal_pointees(x,y) ; }
  typedef OptionalPointee first_argument_type;
  typedef OptionalPointee second_argument_type;
  typedef bool result_type;
And line 61:
struct less_pointees_t {
    { return less_pointees(x,y) ; }
However in function _template.hpp, line 662 should also change:
    , public std::function<T0,R>
and line 666:
    , public std::function<T0,T1,R>
but to what?
(using CLANG-cl compiler in MSVS2019 from its internal installer, and ISO C++ 17
language version
Date: 4 Oct 2020 04:50:00
Message: <web.5f798bb2b933d837f5e85bab0@news.povray.org>
hi,
> and line 666:
> but to what?
uh, sorry, no idea, this is way into C++ territory.  hopefully JG, or someone
else with the required language skills, can help.
regards, jr.
Date: 4 Oct 2020 09:49:35
Message: <5f79d2ef$1@news.povray.org>
> language version
The code to which you are pointing is not familiar to me.
Have you tried compiling with the compiler flag '-std=c++11' ?
For windows compiles, the libraries necessary are in the libraries
directory. In the official POV-Ray code base these have not been updated
in a long time. Further, the POV-Ray base code is only ensured to work
with c++11.
In what state you might find the libraries directory in hgpovray38 I do
not know. Jerome was a Ubuntu user last I knew.
On unix/linux based systems the libraries are install-able based upon a
release of whatever version of unix/linux/osx one runs. Therefore these
libraries will work (are supposed to work) with the default c/c++
compiler version shipped. Compiles in the unix/linux/osx environments do
not use the libraries directory.
The g++ default for Ubuntu 18.04.1 and 20.04.1 to which I just upgraded
is c++14. I also set -std=c++11 occasionally to test I have not
introduced something code wise which will not compile at that standard.
In doing that for povr, I'm pretty sure POV-Ray itself still OK at c++11.
I've also played with compiles using -std=c++17, but these don't compile
on 18.04 systems because the Ubuntu 18.04 'libraries' are not compatible
with c++17(1). A hint the even older libraries directory versions likely
are not.
(1) I've not yet tried a -stdc++17 compile on Ubuntu 20.04.1 - in part
because I've been busy these past few days cleaning up new warnings in
the povr code base I now see in the Ubuntu 20.04.1 environment!
My upfront guess is the windows libraries directory is out of date for
the environment in which you are compiling. Give -std=c++11 a try. If
you're lucky, let us know.
Bill P.
