POV-Ray : Newsgroups : povray.unofficial.patches : Hgpovray38, current state Server Time
12 Nov 2026 09:49:03 EST (-0500)
  Hgpovray38, current state (Message 1 to 48 of 48)
Subject: Hgpovray38, current state
Date: 18 Aug 2018 07:58:25
Message: <5b7809e1$1@news.povray.org>
For the people who do not want to bother with git, Hgpovray is now
available as sources
https://github.com/LeForgeron/povray/releases/tag/v3.8.0.alpha%2BHg.226-Thermidor-30
More works on the agenda :
http://wiki.povray.org/content/User:Le_Forgeron/HgPovray38
Subject: Re: Hgpovray38, current state
Date: 12 Sep 2018 16:39:04
Message: <5b997968$1@news.povray.org>
Latest version so far:
https://github.com/LeForgeron/povray/releases/tag/v3.8.0.alpha%2BHg.226.Bigarade
Date: 12 Sep 2018 17:55:01
Message: <web.5b998a25b933d837b0d4fc1e0@news.povray.org>
hi,
downloaded the .tar.gz version and run into trouble -- make error when
compilation gets to the maths/spline code.  log posted in p.binaries.misc.
regards, jr.
Date: 13 Sep 2018 01:42:00
Message: <5b99f8a8$1@news.povray.org>
Le 12/09/2018 à 23:50, jr a écrit :
> hi,
What age is your compiler ?
I have compiled it with g++ 7, modern clang and icc (intel).
Date: 13 Sep 2018 05:30:00
Message: <web.5b9a2df6b933d837b0d4fc1e0@news.povray.org>
hi,
4.8.2.  :-)
however, is that not a "red herring"?  I would expect './configure' to fail if
the s/ware is .. not modern enough.
regards, jr.
Date: 13 Sep 2018 10:16:41
Message: <5b9a7149@news.povray.org>
Am 13.09.2018 um 11:29 schrieb jr:
> hi,
> 4.8.2.  :-)
For the records, GCC 4.8.2 is feature-complete with respect to C++11.
The question isn't that offbeat; as a matter of fact, the only reliable
way to test whether any given compiler will compile a given program is
to actually try compiling that program.
Case in point: gcc 4.8.2 (or, more precisely, the standard header files
that came with it), despite claiming full C++11 compliance, actually
isn't, due to a couple of bugs in the implementation of std::vector<T>.
And that seems to be exactly what you are seeing; I couldn't find a bug
report matching the /exact/ symptoms, but the error messages point to a
a non-standard-compliant interface of `std::vector<T>::insert`, and
there are bug reports of multiple other non-compliances of
`std::vector<T>`, such as this one:
    https://gcc.gnu.org/bugzilla/show_bug.cgi?id=55817
Judging from when the other bugs were fixed, you'll probably need gcc
4.9 or later.
Date: 13 Sep 2018 11:40:00
Message: <web.5b9a8458b933d837b0d4fc1e0@news.povray.org>
hi,
> > 4.8.2.  :-)
> 4.9 or later.
wow.  thank you very much for digging in to the details, appreciated.  update it
is then (well, near future :-))
regards, jr.
Date: 9 May 2020 08:50:00
Message: <web.5eb6a67cb933d8376adeaecb0@news.povray.org>
Bonjour !
I just tried to build the latest HG-Pov I could find which seems to be that
Bigarade, right? Using MS VS2015,
Here is VS2015 build output:
1>------ Début de la génération : Projet : vfewin, Configuration : Debug x64
2>------ Début de la génération : Projet : rtrsupport, Configuration : Debug x64
3>------ Début de la génération : Projet : povbackend, Configuration : Debug x64
4>------ Début de la génération : Projet : povbase, Configuration : Debug x64
5>------ Début de la génération : Projet : povfrontend, Configuration : Debug
x64 ------
6>------ Génération ignorée : Projet : boost_date_time, Configuration : Debug
x64 ------
6>Projet non sélectionné dans le cadre d'une génération pour cette configuration
de solution
7>------ Début de la génération : Projet : povcore, Configuration : Debug x64
8>------ Début de la génération : Projet : povparser, Configuration : Debug x64
1>  vfesession.cpp
2>  vidcapimpl.cpp
3>  boundingtask.cpp
5>  povmain.cpp
4>  colour.cpp
7>  bounding.cpp
8>  parser.cpp
7>  texture.cpp
4>  metadata.cpp
3>..\..\source\backend\bounding\boundingtask.cpp(91): warning C4267: 'return' :
conversion de 'size_t' en 'unsigned int', perte possible de données
3>..\..\source\backend\bounding\boundingtask.cpp(162): warning C4267: '=' :
3>..\..\source\backend\bounding\boundingtask.cpp(163): warning C4267: '=' :
3>..\..\source\backend\bounding\boundingtask.cpp(178): warning C4267: '=' :
3>..\..\source\backend\bounding\boundingtask.cpp(179): warning C4267: '=' :
3>  povray.cpp
7>  scenedata.cpp
5>povmain.obj : warning LNK4221: Ce fichier objet ne dÚfinit pas de symboles
publics jusqu'ici non dÚfinis. Par consÚquent, il ne sera utilisÚ par aucune
opÚration de lien utilisant cette bibliothÞque
5>  povfrontend.vcxproj ->
C:\HG-POV\povray-3.8.0.alpha-Hg.226.Bigarade\windows\vs2015\bin64\lib\povfrontend64d.lib
3>..\..\source\backend\povray.cpp(515): warning C4267: 'argument' : conversion
de 'size_t' en 'int', perte possible de données
3>  benchmark.cpp
3>  renderbackend.cpp
7>  tracethreaddata.cpp
8>..\..\source\parser\parser.cpp(9673): warning C4267: 'argument' : conversion
8>..\..\source\parser\parser.cpp(12022): error C2065: 'ssize_t' : identificateur
non déclaré
8>..\..\source\parser\parser.cpp(12022): error C2146: erreur de syntaxe :
absence de ';' avant l'identificateur 'idx1'
4>  mathutil.cpp
8>..\..\source\parser\parser.cpp(12022): error C2065: 'idx1' : identificateur
non déclaré
4>  Génération de code en cours...
8>..\..\source\parser\parser.cpp(12023): error C2065: 'ssize_t' : identificateur
non déclaré
8>..\..\source\parser\parser.cpp(12023): error C2146: erreur de syntaxe :
absence de ';' avant l'identificateur 'idx2'
8>..\..\source\parser\parser.cpp(12023): error C2065: 'idx2' : identificateur
non déclaré
8>..\..\source\parser\parser.cpp(12024): error C2065: 'idx1' : identificateur
non déclaré
8>..\..\source\parser\parser.cpp(12024): error C2065: 'idx2' : identificateur
non déclaré
8>..\..\source\parser\parser.cpp(12026): error C2065: 'idx2' : identificateur
non déclaré
8>..\..\source\parser\parser.cpp(12028): error C2065: 'idx2' : identificateur
non déclaré
8>..\..\source\parser\parser.cpp(12031): error C2065: 'idx1' : identificateur
non déclaré
8>..\..\source\parser\parser.cpp(12031): error C2065: 'idx2' : identificateur
non déclaré
4>  jpeg.cpp
8>  parser_strings.cpp
7>  box.cpp
3>  scene.cpp
7>  Génération de code en cours...
4>..\..\source\base\image\jpeg.cpp(502): warning C4267: 'argument' : conversion
8>..\..\source\parser\parser_strings.cpp(479): error C2131: l'expression n'a pas
été évaluée en constante
8>  ..\..\source\parser\parser_strings.cpp(479): note: échec en raison
d'arguments non constants ou d'une référence à un symbole non constant
8>  ..\..\source\parser\parser_strings.cpp(479): note: voir l'utilisation de
'this'
8>..\..\source\parser\parser_strings.cpp(708): warning C4267: '=' : conversion
8>..\..\source\parser\parser_strings.cpp(1176): warning C4267: '=' : conversion
8>  parser_tokenizer.cpp
3>  Génération de code en cours...
8>..\..\source\parser\parser_tokenizer.cpp(1514): warning C4267: '=' :
conversion de 'size_t' en 'int', perte possible de données
7>bounding.obj : warning LNK4221: Ce fichier objet ne dÚfinit pas de symboles
4>  png.cpp
8>..\..\source\parser\parser_tokenizer.cpp(3915): warning C4267: '=' :
2>  vidcap.cpp
8>..\..\source\parser\parser_tokenizer.cpp(3935): warning C4267: '=' :
8>  Génération de code en cours...
3>  povbackend.vcxproj ->
C:\HG-POV\povray-3.8.0.alpha-Hg.226.Bigarade\windows\vs2015\bin64\lib\povbackend64d.lib
7>  povcore.vcxproj ->
C:\HG-POV\povray-3.8.0.alpha-Hg.226.Bigarade\windows\vs2015\bin64\lib\povcore64d.lib
4>timer.obj : warning LNK4221: Ce fichier objet ne dÚfinit pas de symboles
4>mathutil.obj : warning LNK4221: Ce fichier objet ne dÚfinit pas de symboles
4>  povbase.vcxproj ->
C:\HG-POV\povray-3.8.0.alpha-Hg.226.Bigarade\windows\vs2015\bin64\lib\povbase64d.lib
2>  rtrsupport.cpp
1>  vfewin.vcxproj ->
C:\HG-POV\povray-3.8.0.alpha-Hg.226.Bigarade\windows\vs2015\bin64\lib\vfe64d.lib
2>  Génération de code en cours...
2>vidcap.obj : warning LNK4221: Ce fichier objet ne dÚfinit pas de symboles
2>  rtrsupport.vcxproj ->
C:\HG-POV\povray-3.8.0.alpha-Hg.226.Bigarade\windows\vs2015\bin64\lib\rtrsupport64d.lib
9>------ Génération ignorée : Projet : tests, Configuration : Debug x64 ------
9>Projet non sélectionné dans le cadre d'une génération pour cette configuration
de solution
10>------ Début de la génération : Projet : GUI, Configuration : Debug x64
11>------ Génération ignorée : Projet : console, Configuration : Debug x64
11>Projet non sélectionné dans le cadre d'une génération pour cette
configuration de solution
10>  pvbitmap.cpp
10>  pvdialog.cpp
10>  pvdisplay.cpp
10>  pvedit.cpp
10>..\pvedit.cpp(301): warning C4267: '+=' : conversion de 'size_t' en 'int',
10>  pvengine.cpp
10>C:\Program Files (x86)\Windows Kits\8.1\Include\um\dbghelp.h(1544): warning
C4091: 'typedef ' : ignoré à gauche de '' quand aucune variable n'est déclarée
10>C:\Program Files (x86)\Windows Kits\8.1\Include\um\dbghelp.h(3190): warning
10>..\pvengine.cpp(498): warning C4838: la conversion de 'int' en 'WORD'
requiert une conversion restrictive
10>..\pvengine.cpp(1721): warning C4477: 'sprintf' : la chaîne de format '%p'
nécessite un argument de type 'void *', mais l'argument variadique 2 est de type
'DWORD64'
10>..\pvengine.cpp(5152): warning C4996: 'GetVersionExA': a été déclaré
déconseillé
10>  C:\Program Files (x86)\Windows Kits\8.1\Include\um\sysinfoapi.h(433): note:
voir la déclaration de 'GetVersionExA'
10>..\pvengine.cpp(5608): warning C4267: '=' : conversion de 'size_t' en
10>..\pvengine.cpp(5787): warning C4267: '=' : conversion de 'size_t' en
10>..\pvengine.cpp(5719): warning C4996: 'GetVersionExA': a été déclaré
déconseillé
10>  pvfiles.cpp
10>  pvfrontend.cpp
10>  pvguiext.cpp
10>  pvmem.cpp
10>  pvmenu.cpp
10>  pvmisc.cpp
10>..\pvmisc.cpp(223): warning C4838: la conversion de 'int' en 'unsigned int'
10>  pvtext.cpp
10>  pvupdate.cpp
10>..\pvupdate.cpp(166): warning C4996: 'GetVersionExA': a été déclaré
déconseillé
10>  Génération de code en cours...
10>LINK : fatal error LNK1104: impossible d'ouvrir le fichier
'C:\HG-POV\povray-3.8.0.alpha-Hg.226.Bigarade\windows\vs2015\bin64\lib\povparser64d.lib'
========== Génération : 6 a réussi, 2 a échoué, 15 mis à jour, 3 a été ignoré
Date: 10 May 2020 05:15:02
Message: <5eb7c616$1@news.povray.org>
> Bonjour !
x64
x64
> x64 ------
> x64 ------
> de solution
x64
> 1>  vfesession.cpp
> 2>  vidcapimpl.cpp
> 3>  boundingtask.cpp
> 5>  povmain.cpp
> 4>  colour.cpp
> 7>  bounding.cpp
> 8>  parser.cpp
> 7>  texture.cpp
> 4>  metadata.cpp
> 3>  povray.cpp
> 7>  scenedata.cpp
> 3>  benchmark.cpp
> non déclaré
> 4>  mathutil.cpp
> non déclaré
> non déclaré
> non déclaré
> non déclaré
> non déclaré
> non déclaré
> non déclaré
> non déclaré
> non déclaré
> 4>  jpeg.cpp
> 7>  box.cpp
> 3>  scene.cpp
> 'this'
> 4>  png.cpp
> 2>  vidcap.cpp
> 2>  rtrsupport.cpp
> de solution
> 10>  pvbitmap.cpp
> 10>  pvdialog.cpp
> 10>  pvdisplay.cpp
> 10>  pvedit.cpp
> 10>  pvengine.cpp
> 'DWORD64'
> déconseillé
> déconseillé
> 10>  pvfiles.cpp
> 10>  pvfrontend.cpp
> 10>  pvguiext.cpp
> 10>  pvmem.cpp
> 10>  pvmenu.cpp
> 10>  pvmisc.cpp
> 10>  pvtext.cpp
> 10>  pvupdate.cpp
> déconseillé
ignoré
you can fix the ssize_t error by defining it as a signed integer such as
int_least32_t
Date: 10 May 2020 06:10:01
Message: <web.5eb7d2ecb933d8376adeaecb0@news.povray.org>
> > Bonjour !
x64
x64
x64
Debug
> > x64 ------
Debug
> > x64 ------
configuration
> > de solution
x64
x64
> > 1>  vfesession.cpp
> > 2>  vidcapimpl.cpp
> > 3>  boundingtask.cpp
> > 5>  povmain.cpp
> > 4>  colour.cpp
> > 7>  bounding.cpp
> > 8>  parser.cpp
> > 7>  texture.cpp
> > 4>  metadata.cpp
> > 3>  povray.cpp
> > 7>  scenedata.cpp
> > 3>  benchmark.cpp
> > non déclaré
> > 4>  mathutil.cpp
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > 4>  jpeg.cpp
> > 7>  box.cpp
> > 3>  scene.cpp
> > 'this'
> > 4>  png.cpp
> > 2>  vidcap.cpp
> > 2>  rtrsupport.cpp
configuration
> > de solution
> > 10>  pvbitmap.cpp
> > 10>  pvdialog.cpp
> > 10>  pvdisplay.cpp
> > 10>  pvedit.cpp
> > 10>  pvengine.cpp
déclarée
déclarée
> > 'DWORD64'
> > déconseillé
> > déconseillé
> > 10>  pvfiles.cpp
> > 10>  pvfrontend.cpp
> > 10>  pvguiext.cpp
> > 10>  pvmem.cpp
> > 10>  pvmenu.cpp
> > 10>  pvmisc.cpp
> > 10>  pvtext.cpp
> > 10>  pvupdate.cpp
> > déconseillé
ignoré
> int_least32_t
Does that mean I need to learn C to test the branch? :-)
Date: 2 Jun 2020 05:15:01
Message: <web.5ed617eab933d8376adeaecb0@news.povray.org>
> > Bonjour !
x64
x64
x64
Debug
> > x64 ------
Debug
> > x64 ------
configuration
> > de solution
x64
x64
> > 1>  vfesession.cpp
> > 2>  vidcapimpl.cpp
> > 3>  boundingtask.cpp
> > 5>  povmain.cpp
> > 4>  colour.cpp
> > 7>  bounding.cpp
> > 8>  parser.cpp
> > 7>  texture.cpp
> > 4>  metadata.cpp
> > 3>  povray.cpp
> > 7>  scenedata.cpp
> > 3>  benchmark.cpp
> > non déclaré
> > 4>  mathutil.cpp
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > non déclaré
> > 4>  jpeg.cpp
> > 7>  box.cpp
> > 3>  scene.cpp
> > 'this'
> > 4>  png.cpp
> > 2>  vidcap.cpp
> > 2>  rtrsupport.cpp
configuration
> > de solution
> > 10>  pvbitmap.cpp
> > 10>  pvdialog.cpp
> > 10>  pvdisplay.cpp
> > 10>  pvedit.cpp
> > 10>  pvengine.cpp
déclarée
déclarée
> > 'DWORD64'
> > déconseillé
> > déconseillé
> > 10>  pvfiles.cpp
> > 10>  pvfrontend.cpp
> > 10>  pvguiext.cpp
> > 10>  pvmem.cpp
> > 10>  pvmenu.cpp
> > 10>  pvmisc.cpp
> > 10>  pvtext.cpp
> > 10>  pvupdate.cpp
> > déconseillé
ignoré
> int_least32_t
I don't know if that was any sensible thing to do but, in parser.cpp, line 12022
and 12023 I made a few attempts at replacing "ssize_t"
ssize_t idx1 = std::min(Local_Vector[0], Local_Vector[1]);
ssize_t idx2 = std::max(Local_Vector[0], Local_Vector[1]);
First by "int_least32_t" and then by "unsigned int" and finally "int_least64_t",
but every time only got an  error "conversion de 'size_t' en 'int', perte
possible de données" and no build. Using MSVS 2015 on Windows 7, with I7
processor machine.
Any further advice?
Date: 2 Jun 2020 10:30:00
Message: <web.5ed66158b933d8374d00143e0@news.povray.org>
hi,
> > int_least32_t
> processor machine.
> Any further advice?
taking that error (from clean source, I assume) means that, for some reason, no
header is included which provides 'ssize_t'.  after a quick look on my system, I
think including 'unistd.h' would do.  alternatively, you could, at the top of
whichever .cpp file, add a definition (ideally with a '#ifndef' guard) like:
  #define ssize_t int
POSIX guarantees a max of 32767, I think.
hth.
regards, jr.
Date: 2 Jun 2020 13:50:00
Message: <web.5ed69109b933d8376adeaecb0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > > int_least32_t
> > processor machine.
> > Any further advice?
>   #define ssize_t int
> hth.
> regards, jr.
I made a search for "unistd.h" and could not find it neither in HG-POV nor in
POV-Ray 3.8 sources. what path should I include from? I tried without path and
it is not found.
Date: 2 Jun 2020 14:15:00
Message: <web.5ed696c1b933d8374d00143e0@news.povray.org>
hi,
> > > > int_least32_t
> > > processor machine.
> > > Any further advice?
> >   #define ssize_t int
should have written: guarantees at least a maximum of 32767.
> it is not found.
it's not part of an application, it's a system header (well, it is here, on a
Slackware GNU/Linux box).  turns out on my box just including 'stdio.h' is
enough.
jr@crow:1:tmp$ locate unistd.h | grep /usr/include
/usr/include/unistd.h
/usr/include/sys/unistd.h
/usr/include/asm-x86/unistd.h
/usr/include/bits/unistd.h
/usr/include/linux/unistd.h
/usr/include/asm-generic/unistd.h
jr@crow:2:tmp$ cat mr.c
#include <stdio.h>
int main(void) {
  ssize_t a, b, c;
  a = -1, b = 0, c = 1;
  printf("ssize_t vals: %zd  %zd  %zd\n", a, b, c);
  return 0;
jr@crow:3:tmp$ c99 mr.c
jr@crow:4:tmp$ ./a.out
ssize_t vals: -1  0  1
jr@crow:5:tmp$
(the 'c99' is a shell alias for the compiler)
regards, jr.
Date: 2 Jun 2020 14:55:01
Message: <web.5ed69f59b933d8374d00143e0@news.povray.org>
> #include <stdio.h>
> int main(void) {
>   ssize_t a, b, c;
>   return 0;
and, although I don't "speak" C++, I was able to confirm that it should work if
you include 'stdio.h'.
jr@crow:6:tmp$ c### [at] mrcpp
#include <iostream>
#include <stdio.h>
int main(void) {
  ssize_t a, b, c;
  std::cout << "ssize_t vals:" << a << "  " << b << "  " << c << "\n";
  return 0;
jr@crow:7:tmp$ c++ mr.cpp
jr@crow:8:tmp$ ./a.out
ssize_t vals:-1  0  1
jr@crow:9:tmp$
regards, jr.
Date: 3 Jun 2020 09:50:01
Message: <web.5ed7aa0db933d8376adeaecb0@news.povray.org>
> hi,
> > > int_least32_t
> > processor machine.
> > Any further advice?
>   #define ssize_t int
> hth.
> regards, jr.
Thanks
I tried all manners of include suggested to no success... However, this seemed
to do it for me, added after line 47 of parser.cpp below #include <algorithm> :
#if defined(_MSC_VER)
#include <BaseTsd.h>
typedef SSIZE_T ssize_t;
#endif
Now I have another error, Which I boldly assume unrelated:
line 479  expression not evaluated to constant:
char tmp_compound[4+strlen(Get_Token_String(CYLINDER_TOKEN))];
as well as "Impossible d'utiliser 'this' dans une expression constante" (for the
same line)
web search brings me here:
https://docs.microsoft.com/fr-fr/cpp/error-messages/compiler-errors-1/compiler-error-c2131?view=vs-2019
I interpret it as an incentive to initialize some variable or iterator index
beforehand? I am standing still in the dark waiting for your lights !
Date: 3 Jun 2020 10:05:01
Message: <web.5ed7ad84b933d8376adeaecb0@news.povray.org>
> same line)
I forgot to mention that this line 479 was now in parser_strings.cpp
Date: 3 Jun 2020 11:25:00
Message: <web.5ed7c080b933d8374d00143e0@news.povray.org>
hi,
> > > > int_least32_t
> > > processor machine.
> > > Any further advice?
> >   #define ssize_t int
> Thanks
> #endif
I had not realised you're on Redmond's finest.
I wonder whether using either the Linux "sub-system" supplied with Windows 10,
aiui, or an installation of 'cygwin', would not make all these errors/problems
go away.
<https://www.cygwin.com/>
one hack-ish workaround could be to separate out the operations, ie in C I might
do something like:
size_t const n = strlen(Get_Token_String(...));
char tmp_compound[4 + n] = {'\0'};
> same line)
some "lights", more like a 15W bulb.  :-)  good luck.
regards, jr.
Date: 3 Jun 2020 17:45:03
Message: <web.5ed8198db933d8376adeaecb0@news.povray.org>
> do something like:
So instead of this:
....and after adding the same include in parser_strings.cpp, I used:
const ssize_t n = strlen(Get_Token_String(CYLINDER_TOKEN));
char tmp_compound[4 + n];
And still error messages from the same line not eval to const also tried with
const int n = strlen(Get_Token_String(CYLINDER_TOKEN));
Date: 4 Jun 2020 04:55:00
Message: <web.5ed8b565b933d8374d00143e0@news.povray.org>
hi,
> > do something like:
> So instead of this:
two points.  the 'strlen()' function returns a 'size_t', that is, an unsigned
value, while both 'int' and 'ssize_t' hold signed values; however, if that was
the problem you would have seen "warning: conversion to..." messages, not
errors.
second, I just downloaded 'Hg.226.Bigarade' and built it; one single warning
message aside, the program builds cleanly (on a Slackware GNU/Linux box).  so,
sorry, cannot help any further, but my advice is: either create a virtual
machine running a Linux, or install 'cygwin'[*], or explore whether the Windows
10/Ubuntu thing works for you.
(I read the following quote in someone's signature block years back
(paraphrased): "computers are like air-conditioning, they stop working when you
open Windows."  ;-))
[*] there are other s/wares too, like 'MinGW'.
regards, jr.
Date: 4 Jun 2020 09:25:00
Message: <web.5ed8f5ceb933d8376adeaecb0@news.povray.org>
> hi,
> > > do something like:
> > So instead of this:
> errors.
> open Windows."  ;-))
> regards, jr
Sorry since my purpose is blender exporter use.  I can't afford to not be cross
platform
Date: 4 Jun 2020 10:25:00
Message: <web.5ed9032bb933d8374d00143e0@news.povray.org>
hi,
> ...  I can't afford to not be cross platform
you know that POV-Ray builds, you know that Hg is derived from the same sources.
 it would be a lot of work, but if you worked through the differences in the
sources, perhaps aided by single-stepping (with debugger) through POV-Ray
execution, you could (likely) find out exactly what
'Get_Token_String(CYLINDER_TOKEN)' returns, and what else matters at that point
in the code.  sorry to be of little/no help.
regards, jr.
Date: 4 Jun 2020 18:55:00
Message: <web.5ed97b6fb933d8376adeaecb0@news.povray.org>
> hi,
> regards, jr.
I had tried but could not find 'Get_Token_String(CYLINDER_TOKEN)' used in the
same context in POV-Ray trunk source, I may have searched wrong.
Just trying to help would already be a lot! besides I do have the impression
that you did unlock a few a step forwards. thanks !
Date: 5 Jun 2020 04:15:00
Message: <web.5ed9fdf4b933d8374d00143e0@news.povray.org>
hi,
thanks for the .. vote of confidence.  (flattery will get you anywhere..  :-))
I've created two 'tags' files with the symbols/names used in the sources.
searching them for 'Get_Token' gives me:
jr@swift:1:tmp$ xzgrep -n Get_Token hg_tags.xz
46500:Get_Token
povray-3.8.0.alpha-Hg.226.Bigarade/source/parser/parser_tokenizer.cpp 317;" f
class:pov_parser::Parser
46501:Get_Token_String
povray-3.8.0.alpha-Hg.226.Bigarade/source/parser/parser_tokenizer.cpp 1701;" f
jr@swift:2:tmp$ xzgrep -n Get_Token pov_tags.xz
45379:Get_Token povray-3.8.0-alpha.10064268/source/parser/parser_tokenizer.cpp
210;" f class:pov_parser::Parser
45380:Get_Token_String
povray-3.8.0-alpha.10064268/source/parser/parser_tokenizer.cpp 877;" f
jr@swift:3:tmp$
you can download the listings from here:
<https://drive.google.com/file/d/10RaLHKnogRE6ikkiaybHMP4d8ezyZfH9/view?usp=sharing>
<https://drive.google.com/file/d/10ThvgvOXlnSnHJrlAVdiV1UF1fcRpAIZ/view?usp=sharing>
they're about 20M each, so I have used 'xz' to compress, you can use 'WinRAR' to
uncompress if you don't have an 'unxz' installed.
regards, jr.
(reply via email if you feel this discussion is a bit off-topic)
Date: 9 Jun 2020 14:55:00
Message: <web.5edfd9cab933d8376adeaecb0@news.povray.org>
> hi,
> 46500:Get_Token
> jr@swift:3:tmp$
> regards, jr.
The solution from this page seems to bring me a step further:
https://stackoverflow.com/questions/33423502/expression-did-not-evaluate-to-a-constant-c
so...
becomes
char* tmp_compound = new char[4+strlen(Get_Token_String(CYLINDER_TOKEN))];
Now I'm left with new lnk errors of "unresolved external symbols"(?) in
povcore64d.lib(tracepixel.obj)
Date: 3 Oct 2020 19:25:01
Message: <web.5f79074bb933d8376adeaecb0@news.povray.org>
> > hi,
sources.
point
> > 46500:Get_Token
> > jr@swift:3:tmp$
> > regards, jr.
> so...
> becomes
Hi, I went on trying:
....Then removing deprecated binary_function following this page helped me clear
the next issue:
https://stackoverflow.com/questions/22386882/why-have-unary-function-binary-function-been-removed-from-c11
So in compare_pointees.hpp line 36 may become:
struct equal_pointees_t {
  bool operator() ( OptionalPointee const& x, OptionalPointee const& y ) const
    { return equal_pointees(x,y) ; }
  typedef OptionalPointee first_argument_type;
  typedef OptionalPointee second_argument_type;
  typedef bool result_type;
And line 61:
struct less_pointees_t {
    { return less_pointees(x,y) ; }
However in function _template.hpp, line 662 should also change:
    , public std::function<T0,R>
and line 666:
    , public std::function<T0,T1,R>
but to what?
(using CLANG-cl compiler in MSVS2019 from its internal installer, and ISO C++ 17
language version
Date: 4 Oct 2020 04:50:00
Message: <web.5f798bb2b933d837f5e85bab0@news.povray.org>
hi,
> and line 666:
> but to what?
uh, sorry, no idea, this is way into C++ territory.  hopefully JG, or someone
else with the required language skills, can help.
regards, jr.
Date: 4 Oct 2020 09:49:35
Message: <5f79d2ef$1@news.povray.org>
> language version
The code to which you are pointing is not familiar to me.
Have you tried compiling with the compiler flag '-std=c++11' ?
For windows compiles, the libraries necessary are in the libraries
directory. In the official POV-Ray code base these have not been updated
in a long time. Further, the POV-Ray base code is only ensured to work
with c++11.
In what state you might find the libraries directory in hgpovray38 I do
not know. Jerome was a Ubuntu user last I knew.
On unix/linux based systems the libraries are install-able based upon a
release of whatever version of unix/linux/osx one runs. Therefore these
libraries will work (are supposed to work) with the default c/c++
compiler version shipped. Compiles in the unix/linux/osx environments do
not use the libraries directory.
The g++ default for Ubuntu 18.04.1 and 20.04.1 to which I just upgraded
is c++14. I also set -std=c++11 occasionally to test I have not
introduced something code wise which will not compile at that standard.
In doing that for povr, I'm pretty sure POV-Ray itself still OK at c++11.
I've also played with compiles using -std=c++17, but these don't compile
on 18.04 systems because the Ubuntu 18.04 'libraries' are not compatible
with c++17(1). A hint the even older libraries directory versions likely
are not.
(1) I've not yet tried a -stdc++17 compile on Ubuntu 20.04.1 - in part
because I've been busy these past few days cleaning up new warnings in
the povr code base I now see in the Ubuntu 20.04.1 environment!
My upfront guess is the windows libraries directory is out of date for
the environment in which you are compiling. Give -std=c++11 a try. If
you're lucky, let us know.
Bill P.
Date: 4 Oct 2020 10:50:00
Message: <web.5f79e00ab933d8376adeaecb0@news.povray.org>
> Bill P.
Indeed, instead of what was in my last message, I just replaced the content of
boost immediate sub-directories with what was in the similarly named directories
of a fresh boost download... That got rid of this error! (I wonder if my two
previous modifications (posix ssize_t specific import and typedef, and cam
tokenizer pointer are still needed. I will assume they were and go on after
switching back to iso c++14 language version) I am left with another error line
506 in pvengine.cpp,
at the end of SCROLLKEYS key2scroll []:
constant expression evaluates to -1 which cannot be narrowed to type 'WORD' (aka
'unsigned short') [-Wc++11-narrowing] GUI
C:\HG-povray\povray-hgpovray38\windows\pvengine.cpp 506
I also have the exact same error for what appears (to my Python-only eye) to be
a negative index, line 223 in pvmisc.cpp
I don't know by what to replace them ?
Date: 23 Oct 2020 10:15:01
Message: <web.5f92e466b933d8376adeaecb0@news.povray.org>
Hello, ...With the set of default scenes, the advanced/abyss.pov shows a black
background behind submarine instead of blue with current 3.8 plain pov master.
Date: 24 Oct 2020 11:59:23
Message: <5f944f5b$1@news.povray.org>
Can you identify the version of hgpovray38 ?
Date: 24 Oct 2020 12:11:10
Message: <5f94521e$1@news.povray.org>
Oups, my bad. 226 Thermidor is 2 years old.
I will check with the latest head.
Date: 24 Oct 2020 12:26:56
Message: <5f9455d0$1@news.povray.org>
Ok, happens also with latest head. I will have to search when it
started, not fun as I did not play with media.
Date: 24 Oct 2020 18:00:00
Message: <web.5f94a2aab933d8376adeaecb0@news.povray.org>
maybe color models are to be suspected as so many  relatively recent changes
happened ?
(rgb > srgb rgbf rgbt RAL...)
Date: 24 Oct 2020 21:40:01
Message: <web.5f94d666b933d8371f9dae300@news.povray.org>
> happened ?
Works ok in (qtpovray)3.8, using #version 3.6 and #version 3.8
Line 786 has a negative light source, so maybe scroll down to that section and
start commenting out some lights and see what happens.
after that is // submarine and media
light in lines Line 73 & 74 has media_interaction off
Other than that - no idea.
Date: 25 Oct 2020 05:33:26
Message: <5f954666$1@news.povray.org>
>> happened ?
Negative light are honored, not the problem.
Commenting the media in the last union, get the same bad result as
hgpovray38 with povray master 3.8;
Date: 25 Oct 2020 05:57:40
Message: <5f954c14$1@news.povray.org>
>>> happened ?
Ok, I can fix it... but I do not understand yet why it happened and how
it works.
diff --git a/source/core/render/tracepixel.cpp
b/source/core/render/tracepixel.cpp
index 6d661b07..50d420a1 100644
--- a/source/core/render/tracepixel.cpp
+++ b/source/core/render/tracepixel.cpp
@@ -235,7 +235,7 @@ void TracePixelCameraData::SetupCamera(const Camera&
cam)
     bool normalise = false;
     camera = cam;
     useFocalBlur = false;
-    //precomputeContainingInteriors = true;
+    precomputeContainingInteriors = true;
     cameraDirection = camera.Direction;
     cameraRight = camera.Right;
     cameraUp =  camera.Up;
Date: 25 Oct 2020 08:04:34
Message: <5f9569d2$1@news.povray.org>
I'd not have looked if not for the claim of the same bad results in
povray master 3.8, but I branched off the last commit to master and I do
not see that line in tracepixel.cpp commented. (I've not run the test case)
If any help, I went on to look at the state of tracepixel.cpp for every
commit since the move the github. I see twelve up to v3.8 master head
and none have the precompute... line commented.
> it works.
> cam)
>       camera = cam;
Date: 25 Oct 2020 08:45:43
Message: <5f957377$1@news.povray.org>
Latest package:
https://github.com/LeForgeron/povray/releases/tag/v3.8.0.alpha%2BHg.229.Betterave
Date: 26 Oct 2020 02:40:00
Message: <web.5f966e17b933d8376adeaecb0@news.povray.org>
> Latest package:
Thanks ! It does render with blue background now.
Next issue is when I try to render the grenadine scene, I get a "Parse Error:
Cannot open include file lemon.inc." (disregarding any +L option).
That however could also happen with standard povray 3.8.
Date: 26 Oct 2020 03:10:01
Message: <web.5f967589b933d8376adeaecb0@news.povray.org>
> > Latest package:
Sorry, ignore the grenadine (non)issue, I was making a typo.
Date: 6 Nov 2020 03:15:01
Message: <web.5fa5058db933d8376adeaecb0@news.povray.org>
Hi, I tried building on windows again with "betterave", and after reimplementing
all the changes previously mentioned in this thread I manage to push again many
of the errors away, but fail to see what to do about the wrong type line 485 of
windows/pvengine.cpp :
https://github.com/LeForgeron/povray/blob/Hgpovray/windows/pvengine.cpp#L485
At the end of a struct array typed WORD, having -1 values maybe to specify end
of array that looks like list of all keys that allow to scroll.
It seems that some difference relied upon *outside* this file allows vanilla pov
to build with that same technique.
Is there maybe some library that I could change to more recent version? (I
already pushed many errors by replacing boost folder... But maybe I want too far
with that one in a too recent version?
Date: 6 Nov 2020 06:45:00
Message: <web.5fa5365eb933d8376adeaecb0@news.povray.org>
Adding :
-Wno-c++11-narrowing
into additional compiler options seems to have solved that... next issues coming
soon :-)
Date: 13 Nov 2020 11:15:01
Message: <web.5faeb074b933d8376adeaecb0@news.povray.org>
> Adding :
> soon :-)
It now tells me as error for
libraries\boost\boost\type_index\detail\compile_time_type_info.hpp ,  line 279
(" boost::typeindex::detail::failed_to_get_function_name();") :
no matching function for call to 'failed_to_get_function_name'
....and as info for \libraries\boost\boost\type_index\ctti_type_index.hpp , line
117 :
in instantiation of member function 'boost::detail::ctti<void>::n' requested
here
also info for libraries\boost\boost\type_index\detail\compile_time_type_info.hpp
, line 87 :
candidate template ignored: couldn't infer template argument 'T'
If I click to show definition of 'T', below are lines :
"TypeIndex library could not detect your compiler.Please make the
BOOST_TYPE_INDEX_FUNCTION_SIGNATURE macro use correct compiler macro for getting
the whole function name. Define BOOST_TYPE_INDEX_CTTI_USER_DEFINED_PARSING to
correct value after that."
I am using Visual Studio 2019 building Release x64 target, with LLVM as a
compiler, ISO standard Language version C++14, --disable-io-restrictions
-Wno-c++11-narrowing, and with all other changes mentioned before in this
discussion. any clue what else to change to keep/(start?) moving forward?
Date: 28 Feb 2021 17:20:00
Message: <web.603c1617b933d8376adeaecb0@news.povray.org>
Hi, I made yet another attempt at building on Windows with other parameters and
received different warnings mentioning :
unknown type name '__m64'
Is there any chance to replace / enhance definition of this in the source code
with something more cross platform  ?
Date: 1 Mar 2021 06:56:51
Message: <603cd683$1@news.povray.org>
Can you elaborate a bit more (location of the error ?) ?
What is puzzling is that something like __m64 starts with double
underscore and that is something which should be reserved to compiler
implementation.
Any capture of the full message ?
Date: 1 Mar 2021 11:30:00
Message: <web.603d1603b933d8376adeaecb0@news.povray.org>
> implementation.
 Indeed includes belonged to LLVM /CLANG 10 for VC... The thing is I know too
little, especially about expected options and get lost in trial and errors.
A few clues or reminders of what "should" normally  be the best options could
help me to get there quicker. (Using a Windows 10 with an I7 CPU) current
settings: when loading a file I let it update toolset from v140 to version142
Configuration: Debug, Platform: x64
Windows SDK version 10 ... Better with the default of 8.1?
Floating point mode Precise... Better with strict or fast?
MFC: Use Standard Windows Libraries... Better with use MFC from a static
library? or from a shared dll?
Desactivate language extensions : Yes (/Za)... ok?
iso norm for C version?  trying with MSVC inherited... Better with C 11 or C 17?
iso norm for C++ version?  trying with default std C++14 (nothing older)...
Better with 17 or "latest"?
Character set currently undefined  in project file, better with unicode or MBCS?
No Common Language Runtime
Compile as C++(/TP) ... Better with compile as C Code (/TC)?
With that, I get all the errors mentionned in this discussion, so I stopped
assuming that the code should not be touched and am about to start again to the
suggested changes. I was only searching for a working build setup witout it
first : so I now switched the toolset from Visual Studio 2019 (v142) to LLVM
(clang-cl).. better with LLVM? any clues?
Date: 13 Dec 2021 11:35:00
Message: <web.61b7748eb933d83716086ed03f378f2@news.povray.org>
Hi, I made a new attempt at building on Windows after changing one machine and a
fresh msvs install, (all configurations for vanilla pov built fine)  and noticed
one different warning about 'GetVersionExA' declared deprecated, from
pvupdate.cpp line 164, (microsoft error code C4996):
So I copied it here in case it might help solving windows build issues I met
before.
