POV-Ray : Newsgroups : povray.unofficial.patches : media method 3 jitter 0 performance branch off release/v3.8.0. Server Time
28 Apr 2024 14:08:50 EDT (-0400)
  media method 3 jitter 0 performance branch off release/v3.8.0. (Message 1 to 3 of 3)
Subject: media method 3 jitter 0 performance branch off release/v3.8.0.
Date: 18 Feb 2018 10:40:30
Message: <5a899e6e$1@news.povray.org>
For those building their own POV-Ray versions see:
https://github.com/wfpokorny/povray/tree/tune/mediaPerformanceAndSceneFiles
I'm working on other more complicated, longer term alternatives, but the
commit for the scene changes and the commit for method 3 performance
contained in this branch are simple, safe and reasonably well tested.
Enough so that I think it worth considering this branch for adoption in
release/v3.8.0. Opinions?
Bill P.
--- Details for those interested ---
For the usual Jitter=0 media the performance gain tops out at about
5.5%. For (abs(Jitter))!=0 there the penalty for the conditional tops
out at a performance loss of 1.5%.  Not possible at this point, but if
we could dump the jitter option with method 3 we'd top out at a 7%
performance gain for complex medias/densities.
Note: I recommend jitter alway be 0 given our current implementation
unless a noisy, expensive to AA result is what you want.
Note: Performance is always better in my testing where method 3 is
really used however many of our sample scenes will see less performance
gain (1-1.5%) because they almost all use constant media (PLAIN_PATTERN
densities) and so trigger a fast path into method 1 for part of the
media evaluation. In other words many of our sample scenes partly bypass
the method 3 code and so the change herein.
While I reformatted the functions
MediaFunction::ComputeMediaAdaptiveSampling and
MediaFunction::ComputeOneMediaSampleRecursive to the 120 character max,
the code change for performance is quite small. Instead of doing the
jitter calculattion on all ComputeOneMediaSample() calls it changes that
parameter to:
(IMedia->Jitter==0.0 ? 0.0 : dd * IMedia->Jitter *
(randomNumberGenerator() - 0.5))
or similar.  In addition the top of ComputeOneMediaSampleRecursive the
jdist calc becomes:
     if(Jitter==0.0)
         jdist = d2;
     else
         jdist = d2 + Jitter * (d3 - d1) * (randomNumberGenerator() - 0.5);
Aside: It neatly happens the performance improvement here speeds up our
benchmark scene in my testing almost enough to counter the
FixedSimpleVector elimination degrade.
--- Scene file changes. Both fix artifacts/bugs/set-up issues.
1) media3.pov - Result looked really bad with existing samples setting
so increased it until result looked good.
2) micro.pov - Was using "intervals 2" to no benefit.  It was also using
an assumed_gamma of 1.5.  Changed that to 1.0 and updated the emitting
media colors for I believe is a much better result.  The exact result
here not mattering much in any case as just demonstrating technique.
Subject: Re: media method 3 jitter 0 performance branch off release/v3.8.0.
Date: 6 Apr 2018 13:44:48
Message: <5ac7b210$1@news.povray.org>
Sorry, I'm a bit late in replying to this one.
Am 18.02.2018 um 16:40 schrieb William F Pokorny:
I'm a bit reluctant to throw jitter overboard entirely (even for an
individual sampling method, particularly the default one). When a scene
contains other sources of image noise anyway (such as subsurface light
transport, jittered area lights, blurred reflections or focal blur),
increasing media jitter may actually be a better choice performance-wise
than cranking up the media sampling quality parameters.
Date: 7 Apr 2018 04:09:50
Message: <5ac87cce$1@news.povray.org>
                                  s
Agree given it already exists as is and folks have likely used it in
scenes. I have it still in my sandbox media branches.
> When a scene
If rendering a non-uniform density accurately is your aim, I don't agree
with the last of this sentence for method 3 jitter. Method 3 jitter is
expensive noise.
Jitter tends to help 'resolve non-unform media densities' with methods 1
& 2. Jitter often helps as an option implemented in other than media. In
those cases jitter amounts to less uniform sampling toward a still
accurate result. In method 3, jitter - as implemented today - acts
against the sampling approach even aside from github issue(s):
https://github.com/POV-Ray/povray/issues/348.
Elsewhere - or maybe only as a thought floating about my head - I've
suggested a new method 3 aa_jitter feature might be useful. This a
jitter with an effect more in line with jitter in the other two media
methods. I wouldn't be free to method 3 performance of course...
Bill P.
