POV-Ray : Newsgroups : povray.unofficial.patches : Blurred reflections Server Time
18 Mar 2026 09:35:13 EDT (-0400)
  Blurred reflections (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Blurred reflections
Date: 9 Feb 2018 20:22:37
Message: <5a7e495d$1@news.povray.org>
Le 18-02-09 à 07:19, Mike Horvath a écrit :
> On 2/6/2018 7:22 PM, Alain wrote:
>> Le 18-02-06 à 19:09, Mike Horvath a écrit :
>>> How do I get blurred reflections working in UberPOV? I had it working
>>> a few years go, but have since forgotten how. Thanks.
>>> Mike
>> You only need to add roughness into the reflection block such as :
>> reflection{0.9 metallic roughness 0.001}
>> or
>> reflection{1 fresnel roughness 0.001}
>> or
>> reflection{0.8 roughness 0.001}
>> or
>> reflection{0.1, 1 roughness 0.001}
>> Normally, you also want to add specular highlights with the same
>> roughness amount.
> What would the correct way to update the following be?
> #local ldrawChromeFin=finish {
>   brilliance 6
>   diffuse 0.7
>   metallic
>   specular 0.80
>   roughness 1/120
>   reflection 0.8
> Do reflection and specular each have their own blocks containing a
> roughness parameter?
>   brilliance 6
>   diffuse 0.7
>   metallic
>   specular {0.80 roughness 1/120}
>   reflection {0.8 roughness 1/120}
This could cause an error message.
> Mike
This way :
  brilliance 6
  diffuse 0.7
  metallic
  specular 0.80 roughness 1/120
  reflection {0.8 roughness 1/120 metallic}
The first metallic affect the specular or phong highlight. The metallic
in the reflection block affect the reflection only.
There is NO specular block.
Reflection may be used without a block which is the legacy syntax. In
that case, it will borrow the metallic of specular, but not the roughness.
Date: 9 Feb 2018 21:22:13
Message: <5a7e5755$1@news.povray.org>
On 2/9/2018 8:23 PM, Alain wrote:
> This way :
>   brilliance 6
>   diffuse 0.7
>   metallic
Awesome, thanks. That clears up the syntax for me.
Mike
Date: 10 Feb 2018 03:05:03
Message: <web.5a7ea679ba6b2c30a47873e10@news.povray.org>
I didn't know that reflection would 'borrow' the specular's metallic in such a
case. Thanks.
Date: 10 Feb 2018 12:24:15
Message: <5a7f2abf@news.povray.org>
> case. Thanks.
It's a leftover/backware compatibility thing.
Before the reflection block was introduced, there was no way to know if
any metallic modifier was intended for phong, specular or reflection.
Also, the actual order was totally ignored.
Thus
metallic
phong 1
phong_size 150
reflection 0.8
phong 1
metallic
phong_size 150
reflection 0.8
phong 1
reflection 0.8
metallic
phong_size 150
phong_size 150
metallic
reflection 0.8
phong 1
and
phong 1
phong_size 150
reflection 0.8
metallic
would gives the same result.
This is what I mean by "borrow".
Date: 10 Feb 2018 16:30:00
Message: <web.5a7f63efba6b2c30a47873e10@news.povray.org>
> > in such a
> > case. Thanks.
Ah. That explains the 'mystery' I used to wonder about in the older 3.6.x days--
I could never figure out exactly what was going on with metallic. Thanks!
Mystery solved ;-)
Date: 16 Jul 2018 10:15:00
Message: <web.5b4ca75eba6b2c30152ce7b80@news.povray.org>
Will blurred reflection integrate into official version one day? (this function
is too important)
Date: 16 Jul 2018 10:34:45
Message: <5b4cad05$1@news.povray.org>
Am 16.07.2018 um 16:10 schrieb And:
> is too important)
One could argue that "too important" also means "too important to screw up".
So the answer to your question may depend on whether a sufficiently good
and robust implementation (including a sufficiently good syntax and all)
can be... well, implemented.
My gut feeling is that the answer is "yes".
Date: 18 Jul 2018 02:05:00
Message: <web.5b4ed83bba6b2c30152ce7b80@news.povray.org>
> > is too important)
Well
But what is the disadvantage with recently implement?
Date: 18 Jul 2018 09:31:44
Message: <5b4f4140$1@news.povray.org>
Am 18.07.2018 um 08:03 schrieb And:
>>> is too important)
> Well
If you want my opinion: Speed.
Blurred reflections work best when the render engine includes a good
framework for unbiased stochastic rendering, so that all oversampling
stuff -- blurred reflections, area lights, media, focal blur and
what-have-you-not -- don't cause the render time to explode exponentially.
POV-Ray does not have any such framework. UberPOV does, but it is still
rudimentary and probably needs lots more work.
Date: 19 Jul 2018 10:30:00
Message: <web.5b509f2cba6b2c304dbcf4f0@news.povray.org>
> >>> is too important)
> > Well
Yeah... indeed. Unbiased stochastic rendering grew rapidly (and showed its
advantage) during this ten years.
