POV-Ray : Newsgroups : povray.unofficial.patches : UberPOV v1.37.1.0-beta.9 released Server Time
20 Jun 2025 23:30:59 EDT (-0400)
  UberPOV v1.37.1.0-beta.9 released (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: UberPOV v1.37.1.0-beta.9 released
Date: 31 Jan 2015 22:10:57
Message: <54cd9941$1@news.povray.org>
Am 01.02.2015 um 02:49 schrieb James Holsenback:
>> and noticed the checking whether g++ accepts yada-yada shows up for the
>> beta9 configure ... is that a clue?
> Oh ... and the Compiler flags shows -Wno-non-template-friend for b9 as well
Nope (presuming with "yada-yada" you mean "-Wno-non-template-friend");
this is just the suppression of an unwarranted warning from g++.
Effectively, what this is all about is that there was a quirk in older
g++ versions violating the C++ specs, and now by default they issue a
warning just in case your code was relying on g++'s old behaviour.
I'll have a closer look at it. It's certainly not something affecting
the Windows build.
Date: 31 Jan 2015 22:37:39
Message: <54cd9f83$1@news.povray.org>
Am 01.02.2015 um 02:26 schrieb James Holsenback:
> Same error that I'm getting with ANY source AFTER beta6 (which built
> just fine)
Can you please do me a favor and check again with the following versions:
     ce0aae6b54d434ceb3daf7410582f95ea742ac14 (2014-07-27)
     e1028cd0dbb0918324cf9b898906b54222fc67da (2014-07-29)
I have strong reason to believe that the latter introduced the error.
Which also means that it's probably already present in the
feature/colour_model branch in the official POV-Ray repo.
Date: 31 Jan 2015 23:08:01
Message: <54cda6a1$1@news.povray.org>
>> just fine)
ce0aae6b54d434ceb3daf7410582f95ea742ac14 has the same error so I did NOT
pull e1028cd0dbb0918324cf9b898906b54222fc67da
Date: 1 Feb 2015 00:14:27
Message: <54cdb633@news.povray.org>
Am 01.02.2015 um 05:08 schrieb James Holsenback:
>>> just fine)
Strange - I suspect you must have done something wrong there. Never
mind, I've been able to reproduce the error and trace it back to the
"feature/colour_model" branch in the official repo (which is what
UberPOV is based on). I'm currently in the process of releasing a fix.
Date: 1 Feb 2015 00:56:53
Message: <54cdc025$1@news.povray.org>
Am 31.01.2015 um 09:47 schrieb clipka:
> Latest UberPOV version, with all the new official POV-Ray bells &
> whistles merged in.
> https://github.com/UberPOV/UberPOV/releases/tag/v1.37.1.0-beta.9
As Jim has pointed out, beta.9 doesn't compile on Linux, so here's a
source code update:
https://github.com/UberPOV/UberPOV/releases/tag/v1.37.1.0-beta.9b
Date: 1 Feb 2015 01:23:58
Message: <54cdc67e$1@news.povray.org>
>> whistles merged in.
> source code update:
yer gettin' closer:
backend/povray.cpp: In function ‘void
{anonymous}::BuildInitInfo(POVMSObjectPtr)’:
backend/povray.cpp:301:115: error: expected ‘)’ before ‘SSE2_INCLUDED’
Date: 1 Feb 2015 01:39:00
Message: <54cdca04$1@news.povray.org>
Am 01.02.2015 um 07:23 schrieb James Holsenback:
> yer gettin' closer:
Strangely enough, I didn't come across that one on my Linux machine.
Are you building on a 32 bit computer?
Until I figure this one out, I recommend you just remove the
"SSE2_INCLUDED" from that line (any anywhere else where it might cause
hiccups).
Date: 1 Feb 2015 01:46:53
Message: <54cdcbdd$1@news.povray.org>
>> yer gettin' closer:
yes
> hiccups).
was already in the file trying to make repair when i saw your reply ...
line 301 was the only place
Date: 1 Feb 2015 09:15:37
Message: <54ce3509$1@news.povray.org>
>> yer gettin' closer:
> hiccups).
It appears that removing SSE_INCLUDED from line 301 in
backend/povray.cpp does the trick.
I got the same error as James but I was compiling on a 64 bit machine.
After removal of offending word, all is sweetness and light
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 1 Feb 2015 10:29:32
Message: <54ce465c$1@news.povray.org>
> John
Additional:
john@linux-bh1u:~> gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib64/gcc/x86_64-suse-linux/4.8/lto-wrapper
Target: x86_64-suse-linux
Configured with: ../configure --prefix=/usr --infodir=/usr/share/info
--mandir=/usr/share/man --libdir=/usr/lib64 --libexecdir=/usr/lib64
--enable-languages=c,c++,objc,fortran,obj-c++,java,ada
--enable-checking=release --with-gxx-include-dir=/usr/include/c++/4.8
--enable-ssp --disable-libssp --disable-plugin
--with-bugurl=http://bugs.opensuse.org/ --with-pkgversion='SUSE Linux'
--disable-libgcj --disable-libmudflap --with-slibdir=/lib64
--with-system-zlib --enable-__cxa_atexit
--enable-libstdcxx-allocator=new --disable-libstdcxx-pch
--enable-version-specific-runtime-libs --enable-linker-build-id
--enable-linux-futex --program-suffix=-4.8 --without-system-libunwind
--with-arch-32=i586 --with-tune=generic --build=x86_64-suse-linux
--host=x86_64-suse-linux
Thread model: posix
gcc version 4.8.3 20140627 [gcc-4_8-branch revision 212064] (SUSE Linux)
John
Protect the Earth
