POV-Ray : Newsgroups : povray.unofficial.patches : UberPOV v1.37.1.0-beta.9 released Server Time
16 May 2026 14:57:12 EDT (-0400)
  UberPOV v1.37.1.0-beta.9 released (Message 11 to 16 of 16)
Subject: Re: UberPOV v1.37.1.0-beta.9 released
Date: 1 Feb 2015 00:56:53
Message: <54cdc025$1@news.povray.org>
Am 31.01.2015 um 09:47 schrieb clipka:
> Latest UberPOV version, with all the new official POV-Ray bells &
> whistles merged in.
> https://github.com/UberPOV/UberPOV/releases/tag/v1.37.1.0-beta.9
As Jim has pointed out, beta.9 doesn't compile on Linux, so here's a
source code update:
https://github.com/UberPOV/UberPOV/releases/tag/v1.37.1.0-beta.9b
Date: 1 Feb 2015 01:23:58
Message: <54cdc67e$1@news.povray.org>
>> whistles merged in.
> source code update:
yer gettin' closer:
backend/povray.cpp: In function ‘void
{anonymous}::BuildInitInfo(POVMSObjectPtr)’:
backend/povray.cpp:301:115: error: expected ‘)’ before ‘SSE2_INCLUDED’
Date: 1 Feb 2015 01:39:00
Message: <54cdca04$1@news.povray.org>
Am 01.02.2015 um 07:23 schrieb James Holsenback:
> yer gettin' closer:
Strangely enough, I didn't come across that one on my Linux machine.
Are you building on a 32 bit computer?
Until I figure this one out, I recommend you just remove the
"SSE2_INCLUDED" from that line (any anywhere else where it might cause
hiccups).
Date: 1 Feb 2015 01:46:53
Message: <54cdcbdd$1@news.povray.org>
>> yer gettin' closer:
yes
> hiccups).
was already in the file trying to make repair when i saw your reply ...
line 301 was the only place
Date: 1 Feb 2015 09:15:37
Message: <54ce3509$1@news.povray.org>
>> yer gettin' closer:
> hiccups).
It appears that removing SSE_INCLUDED from line 301 in
backend/povray.cpp does the trick.
I got the same error as James but I was compiling on a 64 bit machine.
After removal of offending word, all is sweetness and light
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 1 Feb 2015 10:29:32
Message: <54ce465c$1@news.povray.org>
> John
Additional:
john@linux-bh1u:~> gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib64/gcc/x86_64-suse-linux/4.8/lto-wrapper
Target: x86_64-suse-linux
Configured with: ../configure --prefix=/usr --infodir=/usr/share/info
--mandir=/usr/share/man --libdir=/usr/lib64 --libexecdir=/usr/lib64
--enable-languages=c,c++,objc,fortran,obj-c++,java,ada
--enable-checking=release --with-gxx-include-dir=/usr/include/c++/4.8
--enable-ssp --disable-libssp --disable-plugin
--with-bugurl=http://bugs.opensuse.org/ --with-pkgversion='SUSE Linux'
--disable-libgcj --disable-libmudflap --with-slibdir=/lib64
--with-system-zlib --enable-__cxa_atexit
--enable-libstdcxx-allocator=new --disable-libstdcxx-pch
--enable-version-specific-runtime-libs --enable-linker-build-id
--enable-linux-futex --program-suffix=-4.8 --without-system-libunwind
--with-arch-32=i586 --with-tune=generic --build=x86_64-suse-linux
--host=x86_64-suse-linux
Thread model: posix
gcc version 4.8.3 20140627 [gcc-4_8-branch revision 212064] (SUSE Linux)
John
Protect the Earth
