POV-Ray : Newsgroups : povray.unofficial.patches : UberPOV does not render shadows of an object with a texture map, POV does. Server Time
28 Apr 2024 00:04:38 EDT (-0400)
  UberPOV does not render shadows of an object with a texture map, POV does. (Message 1 to 10 of 10)
Subject: UberPOV does not render shadows of an object with a texture map, POV does.
Date: 23 Sep 2014 06:45:01
Message: <web.54214e42b2c0e8b8b6820d7a0@news.povray.org>
Hi folks.  Hope you can help.  The two boxes in this scene cast shadows onto the
usual plane when I render it with vanilla POV-Ray, but UberPOV does not cast a
shadow behind the one with the texture map.
Uber build 1.37.1.0-beta.8.msvc10.win64
scenes/textures/pigments/txtrmap.pov also renders differently, which makes me
think this is more likely to be a bug than my doing something dumb, but I will
take either.
Sorry not to chase this down and submit a patch myself, but the last time I
looked at this tracer it was called DKB!
Thanks in advance.  Scene follows:
camera { location <0, 5, -5> look_at 0}
plane {  y, -2 texture { pigment { checker colour rgb y colour rgb z} }}
light_source { <2.5, 5.5, -3> rgb 1 }
box { -1, 1
  texture { wood
    texture_map {
      [ 0 pigment { rgb 0.5 } ]
      [ 1 pigment { rgb 1 } ]
box { 0 2 pigment {rgb x} }
Subject: Re: UberPOV does not render shadows of an object with a texture map, POV does.
Date: 23 Sep 2014 07:43:08
Message: <54215ccc$1@news.povray.org>
Am 23.09.2014 12:41, schrieb Ard:
> take either.
For starters, I can confirm that this is entirely unintended, and
therefore a bug indeed.
As an admittedly very counter-intuitive workaround, the shadows can be
made to re-appear by making the pigment slightly transparent. (Any value
larger than the adc_bailout value will do.)
Date: 23 Sep 2014 11:03:18
Message: <54218bb6$1@news.povray.org>
> take either.
> box { -1, 1
>    texture { wood
>      texture_map {
I have rendered this scene with UberPov 1.37.0.0-beta.6.mscv10 win32bits
and with pov-sse32 and there is no difference.
Do not judge my words, judge my actions.
http://www.avast.com
Subject: Re: UberPOV does not render shadows of an object with a texture map, POV do=
Date: 24 Sep 2014 04:05:01
Message: <web.54227af3b736ccfb6820d7a0@news.povray.org>
Thank you!  And to FractRacer.  0.004 transparency added, a refresher in the
difference between rgbf and rgbt and why the former only brought part of my
shadows back, and I'm good.
Date: 24 Sep 2014 08:05:01
Message: <web.5422b26cd4620f77332953fc0@news.povray.org>
I tried rendering the Blink-scene, with or without radiosity, and when rendered
with UberPOV beta 7 x64 the yellow ball has a shadow but looks strange with
radiosity on (I used 'no_cache'). UberPOV beta 8 x64 produces no shadow for the
yellow sphere no matter what, but when radiosity is on the result looks somewhat
better than with beta 7 (bar the lack of shadow).
A question about the Blink-addon: can I use it on a camera or a light?
@Clipka: I have 5 testrun png's, 400x300. If you want to take a look at them, or
the POV-file, just send me your e-mail address.
Date: 24 Sep 2014 09:50:01
Message: <web.5422cbfad4620f77332953fc0@news.povray.org>
I have to go grammar-nazi on myself (sorry):
-I rendered the Blink-scene, with and without radiosity...
Sorry but my OCD kicked in majortime when I reread my own message. :(
Date: 24 Sep 2014 11:44:09
Message: <5422e6c9$1@news.povray.org>
Am 24.09.2014 15:49, schrieb fomhorian:
Your message did come across ok, so no need to put up with grammar nazis.
I'd like you to send those test png's to Christoph at lipka minus koeln,
followed by dot de. Thank you!
Date: 24 Sep 2014 13:25:00
Message: <web.5422fd9ed4620f77332953fc0@news.povray.org>
Is that lipka-koeln, lipkaminuskoeln, lipkakoeln or?
Date: 24 Sep 2014 13:30:01
Message: <web.5422ff52d4620f77332953fc0@news.povray.org>
I think you should have received them by now. :)
Date: 24 Sep 2014 18:13:46
Message: <5423421a@news.povray.org>
Am 24.09.2014 14:00, schrieb fomhorian:
I hadn't tested blink with the no_cache radiosity yet, but yes - from
the images you sent me, it seems seriously broken. But I have a hunch
why that is, and if I'm right it should be easy to fix.
No, not at the moment, and in the case of the camera it certainly won't
be anytime soon - the internal architecture isn't suited to switch
between cameras while rendering a single frame.
As for light sources, it's probably just a matter of finding a bit of
time to implement support for blink.
Depending on what you want to achieve, you might be able to simulate
blinking lights by enclosing the respective light sources in "no_image
no_reflection no_radiosity" objects that blink just the other way around.
