POV-Ray : Newsgroups : povray.unofficial.patches : Is anyone working on a distributed / stochastic / Monte Carlo ray-tracing patch for 3.7? Server Time
13 May 2024 18:49:44 EDT (-0400)
  Is anyone working on a distributed / stochastic / Monte Carlo ray-tracing patch for 3.7? (Message 1 to 10 of 17)
Subject: Is anyone working on a distributed / stochastic / Monte Carlo ray-tracing patch for 3.7?
Date: 20 Jul 2014 13:44:19
Message: <op.xja4vvrwufxv4h@xena.home>
-Nekar Xenos-
Subject: Re: Is anyone working on a distributed / stochastic / Monte Carloray-tracing patch for 3.7?
Date: 20 Jul 2014 14:45:29
Message: <53cc0e49@news.povray.org>
Am 20.07.2014 19:44, schrieb Nekar Xenos:
3.7?
Distributed raytracing patch: Planned for official POV-Ray; don't hold
your breath though.
Stochastic / Monte Carlo raytracing patch: Maybe UberPOV
(https://github.com/UberPOV/UberPOV) already offers what you're looking
for; it already uses stochastic rendering for various features. If
stochastic global illumination is what you're after, just drop me a note
and I'll make that happen as well.
Date: 21 Jul 2014 15:12:14
Message: <op.xjc3mdmvufxv4h@xena.home>
> your breath though.
I'm not 100% sure what the correct term is, the Wikipedia entry was a bit
confusing. I can describe it as following the ray from the light source to
the screen. Just like MCPov, only with all of the 3.7 features.
-Nekar Xenos-
Subject: Re: Is anyone working on a distributed / stochastic / MonteCarloray-tracing patch for 3.7?
Date: 21 Jul 2014 18:53:51
Message: <53cd99ff$1@news.povray.org>
Am 21.07.2014 21:12, schrieb Nekar Xenos:
>> your breath though.
>> looking for; it already uses stochastic rendering for various
>> features. If stochastic global illumination is what you're after, just
>> drop me a note and I'll make that happen as well.
> bit confusing. I can describe it as following the ray from the light
> source to the screen. Just like MCPov, only with all of the 3.7 features.
Hmm, there's definitely some misunderstanding going on here.
"Following the ray from the light source to the screen" is /forward
raytracing/, as opposed to following the ray from the screen to the
object surface and ultimately to the light source, aka /backward
raytracing/. The latter is the classic approach, and the one used by
POV-Ray.
MCPov also uses /backward/ raytracing like POV-Ray.
/Stochastic/ raytracing can be done with both approaches (I guess it is
the only way to do forward raytracing, but it is also a way to do
backward raytracing), or even with combinations of the two, such as
bidirectional raytracing, Metropolis Light Transport or some such.
So let's forget about the technical terms, and start at the other end:
What is it about MCPov that you actually want?
Blurred reflections? Definitely go for UberPOV, as it has them. Yay!
Blurred refractions? Not supported by UberPOV yet, but shouldn't be too
difficult to add once I decide on a nice syntax.
A less artifact-prone replacement for the effect that official POV-Ray
uses radiosity for (so-called Global Illumination)? Raise your hand, and
I'll make it happen in UberPOV.
Render over and over again while you sit and watch, until you're happy
with the result? Not supported in UberPOV yet; it's on the agenda, but
may require quite some intrusion into the POV-Ray architecture. What
UberPOV does already support, however, is an "anti-aliasing" mode (or,
more to the point, an oversampling mode) that allows you to specify what
quality you'd be happy with, and UberPOV will do the
rendering-over-and-over-again in the background until the quality
criteria are met.
As a rule of thumb, if MCPov has it, it is also planned (if not already
implemented) for UberPOV.
Subject: Re: Is anyone working on a distributed / stochastic / MonteCarloray-tracingpatch for 3.7?
Date: 22 Jul 2014 03:11:32
Message: <53ce0ea4$1@news.povray.org>
I don't know what you have in mind for this, if it's not the render over
and over again approach?
> criteria are met.
This seems like a better approach, as with MCPov you're often left
re-rendering the entire image waiting for just a small dark area to
smooth out.
So if you implement the less artefact-prone GI and combine it with the
per-pixel oversampling it should be something better than MCPov? Sounds
good to me! Hand firmly raised!
Subject: Re: Is anyone working on a distributed / stochastic / MonteCarloray-tracingpatchfor 3.7?
Date: 22 Jul 2014 08:26:33
Message: <53ce5879$1@news.povray.org>
Am 22.07.2014 09:11, schrieb scott:
Essentially that, yes.
At the moment, for Global Illumination UberPOV still uses the same
approach as POV-Ray: On an object's surface it chooses some points more
or less at random, for which it computes indirect illumination with high
precision(*), and caches this information; for any points in between,
indirect illumination is interpolated from nearby cached samples. This
interpolation can lead to systematic artifacts that are difficult to get
rid of - obviously it's not enough to just sample the image over and
over again with the same set of cached samples.
(*) Computation of indirect illumination is done simply by shooting a
number of secondary rays, and see what light might come from other
objects present there; the more rays are shot, the more precise the
result will be.
To avoid the typical POV-Ray radiosity artifacts, MCPov (re-)computes
indirect illumination for each and every point on an object's surface,
and doesn't cache the results at all. Usually this is done with a
comparatively low precision, which also leads to artifacts; however,
they manifest as random noise that can be reduced by oversampling pixels
over and over again.
>> criteria are met.
> smooth out.
It's not all that bad; MCPov does spend more time on areas of the image
that prove to really need the additional work.
I'm not sure if it that'll suffice to indeed be better than MCPov; time
will tell. A definitive advantage will be the full support for
multithreading.
Two other things that had always bothered me about MCPov is that it
doesn't allow the use of classic light source (which would be far less
noisy and hence much faster than using bright spheres), and that it has
a factor-2 error in diffuse computations that make it necessary to use
different finish settings. Both make it excessively difficult to create
scenes that render essentially identical (except for artifacts or noise)
in both POV-Ray and MCPov. Needless to say that UberPOV is intended to
do a better job in that respect.
Subject: Re: Is anyone working on a distributed / stochastic / MonteCarloray-tracingpatchfor3.7?
Date: 22 Jul 2014 09:11:57
Message: <53ce631d@news.povray.org>
Yes, I have a few macros so that scenes can work in both POV and MCPov
but it's a messy solution (and obviously I can't use any 3.7 features).
Date: 23 Jul 2014 14:05:38
Message: <op.xjgpvdseufxv4h@xena.home>
And there was also a problem with media. I hope UberPov will be able to do
what MCPov did and still be able to render different types of media
correctly.
-Nekar Xenos-
Date: 23 Jul 2014 14:12:54
Message: <op.xjgp7gp3ufxv4h@xena.home>
>>> your breath though.
>> features.
> POV-Ray.
I don't know why I thought MCPov used forward ray-tracing. I think it was
probably because of the slow rendering and good results after waiting a
long time ;)
That would be useful.
*raises hand*
> criteria are met.
Yes, please :)
Whoo-hoo!
-Nekar Xenos-
Date: 23 Jul 2014 14:18:44
Message: <op.xjgqg7fsufxv4h@xena.home>
> your breath though.
What I would like to see with radiosity is a system that distinguishes
between different materials. Smooth shiny materials should have a smaller
cone of scattering than cement which should have a very wide angle of
scattering.
-Nekar Xenos-
