POV-Ray : Newsgroups : povray.unofficial.patches : UberPOV 1.37.0.0-beta.2 released Server Time
11 Oct 2026 23:07:07 EDT (-0400)
  UberPOV 1.37.0.0-beta.2 released (Message 1 to 23 of 23)
Subject: UberPOV 1.37.0.0-beta.2 released
Date: 22 Nov 2013 09:30:32
Message: <528f6a88$1@news.povray.org>
Now with basic support for motion blur.
Source & Windows binary packages are available at:
https://github.com/UberPOV/UberPOV/releases/tag/v1.37.0.0-beta.2
Subject: Re: UberPOV 1.37.0.0-beta.2 released
Date: 24 Nov 2013 07:05:16
Message: <5291eb7c$1@news.povray.org>
    I just started to try to apply reflection blur to my christmas
baubles... but found a problem even before starting:
    As a first test, I just changed the version directive and rendered it
with UberPOV, and the garland was missing. Checking my ugly code, I
found that trace() seems to not be working at all. The attached simple
scene shows the problem: on 3.7 you get some scattered spheres, as the
trace() call finds an intersection point with the plane, but on UberPOV
all the spheres get placed at <0,0,0>, as the intersection test seems to
fail (normal is also 0).
Jaime
Download 'us-ascii' (1 KB)
Date: 24 Nov 2013 08:02:30
Message: <5291f8e6$1@news.povray.org>
Am 24.11.2013 13:05, schrieb Jaime Vives Piqueres:
I've already stumbled across - and fixed - this very bug myself
yesterday :-)
In case you are using Linux, or have access to Visual Studio 2010, you
may want to get the latest code from the "master" branch at
https://github.com/UberPOV/UberPOV.
I would have rushed out a new beta already, but haven't found the time
yet; it'll probably happen no sooner than tomorrow. Windows users might
want to use the older beta.2 until then.
There is another bug in beta.2 that breaks SSLT; again, both beta.2 and
the current master branch are fine.
Date: 24 Nov 2013 09:36:42
Message: <52920efa@news.povray.org>
Hmmm ... just pulled and I'm getting:
In file included from /usr/include/boost/thread.hpp:24:0,
                  from ./backend/povray.h:53,
                  from ./backend/control/renderbackend.h:40,
                  from ./backend/control/messagefactory.h:39,
                  from backend/frame.h:65,
                  from lightgrp.cpp:35:
/usr/include/boost/thread/future.hpp:286:12: error: stray ‘\267’ in program
/usr/include/boost/thread/future.hpp:286:12: error: stray ‘\23’ in program
/usr/include/boost/thread/future.hpp: In static member function ‘static
void
boost::detail::future_traits<void>::cleanup(boost::detail::future_traits<void>::storage_type&)’:
/usr/include/boost/thread/future.hpp:286:19: error: ‘orage’ was not
declared in this scope
I last built yesterday (23rd) early in the morning ... was fine then. I
was not getting the results I was expecting from +am3, so after seeing
Jamies post I decided to re-build.
Jim
Date: 24 Nov 2013 09:36:45
Message: <52920efd$1@news.povray.org>
> yesterday :-)
   Surely, just moments after I downloaded it... :) ...will try again
with the latest code, thanks.
Jaime
Date: 24 Nov 2013 16:32:28
Message: <5292706c@news.povray.org>
Am 24.11.2013 15:36, schrieb James Holsenback:
> void
According to the message, the file "future.hpp" - part of the boost
library's dev package that apparently comes with your Linux distro -
contains two non-ASCII characters among the program code. \267 (aka
0xB7, or decimal 183) and \23 (aka 0x13, or decimal 19), are a centered
dot ("MIDDLE DOT") and a non-printable character ("DEVICE CONTROL THREE"
aka DC3), respectively.
The code you just pulled probably doesn't have anything to do with it;
something must have garbled your libboost-dev package.
Date: 24 Nov 2013 23:12:00
Message: <5292ce10$1@news.povray.org>
>> program
>> program
>> void
Since I hadn't touched my end I didn't think it was the problem, but I
refreshed my boost package and that was indeed the problem ... however a
render I left running while at work (yesterday build) had an error when
I got home to check:
Rendered 379904 of 705600 pixels (53%)
Cannot access data in file.
Rendered 380928 of 705600 pixels (53%)
Fatal error in renderer: Frontend halted render.
Dunno if it was related to the above problem ... just thought I'd
mention it anyways
Date: 25 Nov 2013 09:06:48
Message: <52935978@news.povray.org>
> mention it anyways
sheesh ... should have realized my pull script was snagging the master
/not/ beta branch ... that will teach me to try to throw something
together quickly before i've checked things a bit more
Date: 25 Nov 2013 15:14:58
Message: <5293afc2$1@news.povray.org>
> mention it anyways
decreased +am3 aa depth from +r6 to +r4 and abort went away ...
Date: 25 Nov 2013 15:36:56
Message: <5293b4e8@news.povray.org>
Am 25.11.2013 21:14, schrieb James Holsenback:
>> mention it anyways
Strange one - can't make any sense of this yet.
Date: 25 Nov 2013 15:48:40
Message: <5293b7a8@news.povray.org>
>> mention it anyways
This must be something deep in the bowels of the POVMS message-passing
code; can you try the following - in source/base/povmscpp.cpp, replace all
     throw POV_EXCEPTION_CODE(pov_base::kFileDataErr)
with
     throw POV_EXCEPTION_CODE(pov_base::kFileDataErr, "FUBAR: ###")
where ### is different for each instance (ideally the line number), then
compile & try again, and report which line claims the jackpot?
What are your system specs?
Date: 25 Nov 2013 16:52:46
Message: <5293c6ae@news.povray.org>
>>> mention it anyways
> with
I'll do that later this evening ...
amd athlon x2 250 4gb ram
Date: 25 Nov 2013 17:39:01
Message: <5293d185$1@news.povray.org>
Am 25.11.2013 22:52, schrieb James Holsenback:
That's a 64 bit machine AFAIK; otherwise my first suspect would have
been /some/ variable /somewhere/ with just 32 bit where 64 bit would
have been required for whatever you're doing there.
Date: 25 Nov 2013 22:33:07
Message: <52941673$1@news.povray.org>
>>> mention it anyways
> with
error: macro "POV_EXCEPTION_CODE" passed 2 arguments, but takes just 1
Date: 26 Nov 2013 07:43:01
Message: <52949755$1@news.povray.org>
Am 26.11.2013 04:33, schrieb James Holsenback:
>> all
>> with
My bad - that should have been:
     throw POV_EXCEPTION(pov_base::kFileDataErr, "FUBAR: ###")
Date: 26 Nov 2013 10:50:10
Message: <5294c332$1@news.povray.org>
>>> all
>>> with
This run got a little farther .... used +am3 aa depth +r5
Rendered 553984 of 705600 pixels (78%)
Belch: 1494
Rendered 555008 of 705600 pixels (78%)
Render failed
btw: amd x2 250 is 32-bit dual core ... fwiw: 3.1.10-1.29-desktop kernel
opensuse 12.1
Date: 26 Nov 2013 11:23:59
Message: <5294cb1f@news.povray.org>
Am 26.11.2013 16:50, schrieb James Holsenback:
>>>> all
>>>> with
> Belch: 1494
> Render failed
> opensuse 12.1
Duh.. sure it's 32 bit? All I can find on the 'net says that it must be
either an "AMD Athlon 64 x2", or an "AMD Athlon x2" - but the latter is
a 64-bit thing, too. Even the notebook variant is.
Still, you're possibly running a 32-bit OS on it, so that brings integer
size issues back on the list of suspects.
Date: 26 Nov 2013 11:32:25
Message: <5294cd19@news.povray.org>
>>>> all
>>>> with
> Belch: 1494
Still doesn't make much sense to me. Mind e-mailing the complete scene +
all render settings? (See the dev newsgroup for my e-mail address).
Date: 26 Nov 2013 12:16:56
Message: <5294d788@news.povray.org>
>>>>> all
>>>>> with
>> Belch: 1494
a little bit too big to email ~15MB, so I put it on my wiki testbed ...
see your email for the link
Date: 26 Nov 2013 12:31:29
Message: <5294daf1$1@news.povray.org>
Am 26.11.2013 18:16, schrieb James Holsenback:
Thanks, but I guess I've nailed down the culprit already - after
accidently getting my Windows system into swap hell by "nothing more"
than cranking up the AA mode 3 quality settings (something like +am3
+ac0.999 +a0.001 +r9). The quality settings shouldn't have any effect on
the memory consumption during AA mode 3, but obviously they do.
That was the clue I needed. Turned out to be a stupid bug, actually.
Date: 26 Nov 2013 12:31:47
Message: <5294db03@news.povray.org>
>>>>>> message-passing
>>>>>> replace
>>>>>> all
>>>>>> with
>>> Belch: 1494
another thought ... might be worth it to have a quick look at latest
Coverity scan results. I've not looked so your mileage may vary
Date: 26 Nov 2013 12:43:34
Message: <5294ddc6$1@news.povray.org>
Am 26.11.2013 18:31, schrieb clipka:
BTW, the render abort you experience is probably due to an excessively
large chunk of memory being passed from one of the render threads to the
front end.
Date: 26 Nov 2013 12:48:48
Message: <5294df00$1@news.povray.org>
Am 25.11.2013 05:11, schrieb James Holsenback:
You might want to try the newest version from the "master" branch; I'm
quite sure it fixes your issue.
