POV-Ray : Newsgroups : povray.unofficial.patches : UberPOV 1.37.0.0-beta.2 released Server Time
30 Jun 2025 18:26:28 EDT (-0400)
  UberPOV 1.37.0.0-beta.2 released (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: UberPOV 1.37.0.0-beta.2 released
Date: 25 Nov 2013 15:48:40
Message: <5293b7a8@news.povray.org>
Am 25.11.2013 21:14, schrieb James Holsenback:
> On 11/24/2013 11:11 PM, James Holsenback wrote:
>> Rendered 379904 of 705600 pixels (53%)
>> Cannot access data in file.
>> Rendered 380928 of 705600 pixels (53%)
>> Fatal error in renderer: Frontend halted render.
>> Dunno if it was related to the above problem ... just thought I'd
>> mention it anyways
> decreased +am3 aa depth from +r6 to +r4 and abort went away ...
This must be something deep in the bowels of the POVMS message-passing
code; can you try the following - in source/base/povmscpp.cpp, replace all
     throw POV_EXCEPTION_CODE(pov_base::kFileDataErr)
with
     throw POV_EXCEPTION_CODE(pov_base::kFileDataErr, "FUBAR: ###")
where ### is different for each instance (ideally the line number), then
compile & try again, and report which line claims the jackpot?
What are your system specs?
Date: 25 Nov 2013 16:52:46
Message: <5293c6ae@news.povray.org>
>>> mention it anyways
> with
I'll do that later this evening ...
amd athlon x2 250 4gb ram
Date: 25 Nov 2013 17:39:01
Message: <5293d185$1@news.povray.org>
Am 25.11.2013 22:52, schrieb James Holsenback:
That's a 64 bit machine AFAIK; otherwise my first suspect would have
been /some/ variable /somewhere/ with just 32 bit where 64 bit would
have been required for whatever you're doing there.
Date: 25 Nov 2013 22:33:07
Message: <52941673$1@news.povray.org>
>>> mention it anyways
> with
error: macro "POV_EXCEPTION_CODE" passed 2 arguments, but takes just 1
Date: 26 Nov 2013 07:43:01
Message: <52949755$1@news.povray.org>
Am 26.11.2013 04:33, schrieb James Holsenback:
>> all
>> with
My bad - that should have been:
     throw POV_EXCEPTION(pov_base::kFileDataErr, "FUBAR: ###")
Date: 26 Nov 2013 10:50:10
Message: <5294c332$1@news.povray.org>
>>> all
>>> with
This run got a little farther .... used +am3 aa depth +r5
Rendered 553984 of 705600 pixels (78%)
Belch: 1494
Rendered 555008 of 705600 pixels (78%)
Render failed
btw: amd x2 250 is 32-bit dual core ... fwiw: 3.1.10-1.29-desktop kernel
opensuse 12.1
Date: 26 Nov 2013 11:23:59
Message: <5294cb1f@news.povray.org>
Am 26.11.2013 16:50, schrieb James Holsenback:
>>>> all
>>>> with
> Belch: 1494
> Render failed
> opensuse 12.1
Duh.. sure it's 32 bit? All I can find on the 'net says that it must be
either an "AMD Athlon 64 x2", or an "AMD Athlon x2" - but the latter is
a 64-bit thing, too. Even the notebook variant is.
Still, you're possibly running a 32-bit OS on it, so that brings integer
size issues back on the list of suspects.
Date: 26 Nov 2013 11:32:25
Message: <5294cd19@news.povray.org>
>>>> all
>>>> with
> Belch: 1494
Still doesn't make much sense to me. Mind e-mailing the complete scene +
all render settings? (See the dev newsgroup for my e-mail address).
Date: 26 Nov 2013 12:16:56
Message: <5294d788@news.povray.org>
>>>>> all
>>>>> with
>> Belch: 1494
a little bit too big to email ~15MB, so I put it on my wiki testbed ...
see your email for the link
Date: 26 Nov 2013 12:31:29
Message: <5294daf1$1@news.povray.org>
Am 26.11.2013 18:16, schrieb James Holsenback:
Thanks, but I guess I've nailed down the culprit already - after
accidently getting my Windows system into swap hell by "nothing more"
than cranking up the AA mode 3 quality settings (something like +am3
+ac0.999 +a0.001 +r9). The quality settings shouldn't have any effect on
the memory consumption during AA mode 3, but obviously they do.
That was the clue I needed. Turned out to be a stupid bug, actually.
