POV-Ray : Newsgroups : povray.unofficial.patches : UberPOV 1.37.0.0-beta.2 released Server Time
25 Apr 2024 09:19:14 EDT (-0400)
  UberPOV 1.37.0.0-beta.2 released (Message 1 to 10 of 23)
Subject: UberPOV 1.37.0.0-beta.2 released
Date: 22 Nov 2013 09:30:32
Message: <528f6a88$1@news.povray.org>
Now with basic support for motion blur.
Source & Windows binary packages are available at:
https://github.com/UberPOV/UberPOV/releases/tag/v1.37.0.0-beta.2
Subject: Re: UberPOV 1.37.0.0-beta.2 released
Date: 24 Nov 2013 07:05:16
Message: <5291eb7c$1@news.povray.org>
    I just started to try to apply reflection blur to my christmas
baubles... but found a problem even before starting:
    As a first test, I just changed the version directive and rendered it
with UberPOV, and the garland was missing. Checking my ugly code, I
found that trace() seems to not be working at all. The attached simple
scene shows the problem: on 3.7 you get some scattered spheres, as the
trace() call finds an intersection point with the plane, but on UberPOV
all the spheres get placed at <0,0,0>, as the intersection test seems to
fail (normal is also 0).
Jaime
Download 'us-ascii' (1 KB)
Date: 24 Nov 2013 08:02:30
Message: <5291f8e6$1@news.povray.org>
Am 24.11.2013 13:05, schrieb Jaime Vives Piqueres:
I've already stumbled across - and fixed - this very bug myself
yesterday :-)
In case you are using Linux, or have access to Visual Studio 2010, you
may want to get the latest code from the "master" branch at
https://github.com/UberPOV/UberPOV.
I would have rushed out a new beta already, but haven't found the time
yet; it'll probably happen no sooner than tomorrow. Windows users might
want to use the older beta.2 until then.
There is another bug in beta.2 that breaks SSLT; again, both beta.2 and
the current master branch are fine.
Date: 24 Nov 2013 09:36:42
Message: <52920efa@news.povray.org>
Hmmm ... just pulled and I'm getting:
In file included from /usr/include/boost/thread.hpp:24:0,
                  from ./backend/povray.h:53,
                  from ./backend/control/renderbackend.h:40,
                  from ./backend/control/messagefactory.h:39,
                  from backend/frame.h:65,
                  from lightgrp.cpp:35:
/usr/include/boost/thread/future.hpp:286:12: error: stray ‘\267’ in program
/usr/include/boost/thread/future.hpp:286:12: error: stray ‘\23’ in program
/usr/include/boost/thread/future.hpp: In static member function ‘static
void
boost::detail::future_traits<void>::cleanup(boost::detail::future_traits<void>::storage_type&)’:
/usr/include/boost/thread/future.hpp:286:19: error: ‘orage’ was not
declared in this scope
I last built yesterday (23rd) early in the morning ... was fine then. I
was not getting the results I was expecting from +am3, so after seeing
Jamies post I decided to re-build.
Jim
Date: 24 Nov 2013 09:36:45
Message: <52920efd$1@news.povray.org>
> yesterday :-)
   Surely, just moments after I downloaded it... :) ...will try again
with the latest code, thanks.
Jaime
Date: 24 Nov 2013 16:32:28
Message: <5292706c@news.povray.org>
Am 24.11.2013 15:36, schrieb James Holsenback:
> void
According to the message, the file "future.hpp" - part of the boost
library's dev package that apparently comes with your Linux distro -
contains two non-ASCII characters among the program code. \267 (aka
0xB7, or decimal 183) and \23 (aka 0x13, or decimal 19), are a centered
dot ("MIDDLE DOT") and a non-printable character ("DEVICE CONTROL THREE"
aka DC3), respectively.
The code you just pulled probably doesn't have anything to do with it;
something must have garbled your libboost-dev package.
Date: 24 Nov 2013 23:12:00
Message: <5292ce10$1@news.povray.org>
>> program
>> program
>> void
Since I hadn't touched my end I didn't think it was the problem, but I
refreshed my boost package and that was indeed the problem ... however a
render I left running while at work (yesterday build) had an error when
I got home to check:
Rendered 379904 of 705600 pixels (53%)
Cannot access data in file.
Rendered 380928 of 705600 pixels (53%)
Fatal error in renderer: Frontend halted render.
Dunno if it was related to the above problem ... just thought I'd
mention it anyways
Date: 25 Nov 2013 09:06:48
Message: <52935978@news.povray.org>
> mention it anyways
sheesh ... should have realized my pull script was snagging the master
/not/ beta branch ... that will teach me to try to throw something
together quickly before i've checked things a bit more
Date: 25 Nov 2013 15:14:58
Message: <5293afc2$1@news.povray.org>
> mention it anyways
decreased +am3 aa depth from +r6 to +r4 and abort went away ...
Date: 25 Nov 2013 15:36:56
Message: <5293b4e8@news.povray.org>
Am 25.11.2013 21:14, schrieb James Holsenback:
>> mention it anyways
Strange one - can't make any sense of this yet.
