POV-Ray : Newsgroups : povray.unofficial.patches : UberPOV 1.37.0.0-beta.2 released Server Time
2 Jun 2024 06:54:59 EDT (-0400)
  UberPOV 1.37.0.0-beta.2 released (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: UberPOV 1.37.0.0-beta.2 released
Date: 24 Nov 2013 09:36:42
Message: <52920efa@news.povray.org>
On 11/24/2013 08:02 AM, clipka wrote:
> There is another bug in beta.2 that breaks SSLT; again, both beta.2 and
> the current master branch are fine.
Hmmm ... just pulled and I'm getting:
In file included from /usr/include/boost/thread.hpp:24:0,
                  from ./backend/povray.h:53,
                  from ./backend/control/renderbackend.h:40,
                  from ./backend/control/messagefactory.h:39,
                  from backend/frame.h:65,
                  from lightgrp.cpp:35:
/usr/include/boost/thread/future.hpp:286:12: error: stray ‘\267’ in program
/usr/include/boost/thread/future.hpp:286:12: error: stray ‘\23’ in program
/usr/include/boost/thread/future.hpp: In static member function ‘static
void
boost::detail::future_traits<void>::cleanup(boost::detail::future_traits<void>::storage_type&)’:
/usr/include/boost/thread/future.hpp:286:19: error: ‘orage’ was not
declared in this scope
I last built yesterday (23rd) early in the morning ... was fine then. I
was not getting the results I was expecting from +am3, so after seeing
Jamies post I decided to re-build.
Jim
Date: 24 Nov 2013 09:36:45
Message: <52920efd$1@news.povray.org>
> I've already stumbled across - and fixed - this very bug myself
> yesterday :-)
   Surely, just moments after I downloaded it... :) ...will try again
with the latest code, thanks.
Jaime
Date: 24 Nov 2013 16:32:28
Message: <5292706c@news.povray.org>
Am 24.11.2013 15:36, schrieb James Holsenback:
> void
According to the message, the file "future.hpp" - part of the boost
library's dev package that apparently comes with your Linux distro -
contains two non-ASCII characters among the program code. \267 (aka
0xB7, or decimal 183) and \23 (aka 0x13, or decimal 19), are a centered
dot ("MIDDLE DOT") and a non-printable character ("DEVICE CONTROL THREE"
aka DC3), respectively.
The code you just pulled probably doesn't have anything to do with it;
something must have garbled your libboost-dev package.
Date: 24 Nov 2013 23:12:00
Message: <5292ce10$1@news.povray.org>
>> program
>> program
>> void
Since I hadn't touched my end I didn't think it was the problem, but I
refreshed my boost package and that was indeed the problem ... however a
render I left running while at work (yesterday build) had an error when
I got home to check:
Rendered 379904 of 705600 pixels (53%)
Cannot access data in file.
Rendered 380928 of 705600 pixels (53%)
Fatal error in renderer: Frontend halted render.
Dunno if it was related to the above problem ... just thought I'd
mention it anyways
Date: 25 Nov 2013 09:06:48
Message: <52935978@news.povray.org>
> mention it anyways
sheesh ... should have realized my pull script was snagging the master
/not/ beta branch ... that will teach me to try to throw something
together quickly before i've checked things a bit more
Date: 25 Nov 2013 15:14:58
Message: <5293afc2$1@news.povray.org>
> mention it anyways
decreased +am3 aa depth from +r6 to +r4 and abort went away ...
Date: 25 Nov 2013 15:36:56
Message: <5293b4e8@news.povray.org>
Am 25.11.2013 21:14, schrieb James Holsenback:
>> mention it anyways
Strange one - can't make any sense of this yet.
Date: 25 Nov 2013 15:48:40
Message: <5293b7a8@news.povray.org>
>> mention it anyways
This must be something deep in the bowels of the POVMS message-passing
code; can you try the following - in source/base/povmscpp.cpp, replace all
     throw POV_EXCEPTION_CODE(pov_base::kFileDataErr)
with
     throw POV_EXCEPTION_CODE(pov_base::kFileDataErr, "FUBAR: ###")
where ### is different for each instance (ideally the line number), then
compile & try again, and report which line claims the jackpot?
What are your system specs?
Date: 25 Nov 2013 16:52:46
Message: <5293c6ae@news.povray.org>
>>> mention it anyways
> with
I'll do that later this evening ...
amd athlon x2 250 4gb ram
Date: 25 Nov 2013 17:39:01
Message: <5293d185$1@news.povray.org>
Am 25.11.2013 22:52, schrieb James Holsenback:
That's a 64 bit machine AFAIK; otherwise my first suspect would have
been /some/ variable /somewhere/ with just 32 bit where 64 bit would
have been required for whatever you're doing there.
