POV-Ray : Newsgroups : povray.unofficial.patches : First official beta of UberPOV Server Time
27 Apr 2024 08:57:41 EDT (-0400)
  First official beta of UberPOV (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: First official beta of UberPOV
Date: 21 Nov 2013 06:11:27
Message: <528dea5f$1@news.povray.org>
On 11/20/2013 09:08 PM, clipka wrote:
> Am 21.11.2013 01:40, schrieb clipka:
>> Am 20.11.2013 23:40, schrieb James Holsenback:
>>> I had some problems with Makefile.in(s). first in ~uberpov/unix while
>>> running prebuild.sh then during configure phase ...  this time
>>> ~uberpov/vfe/Makefile.in and ~uberpov/source/Makefile.in are problems.
> Fix available now at:
> https://github.com/UberPOV/UberPOV
OK thanks ... got a good build, however when when I did uberpov
--version a slight problem:
ash@linux-c2bm:~/ScratchPad/git/uberpov $ uberpov --version
uberpov: cannot open the system configuration file
/usr/local/etc/uberpov/1.37/uberpov .conf: No such file or directory
uberpov: cannot open the user configuration file
/home/ash/.uberpov/1.37/uberpov.conf: No such file or directory
uberpov: I/O restrictions are disabled
UberPOV 3.7.0.unofficial
Notice the space in uberpov.pov above ... the file lives properly in the
root of the build directory. It did /not/ get copied into
/usr/local/etc/uberpov/1.37 (uberpov.ini /did/). ~users/.uberpov on down
did /not/ get created ... copied uberpov.conf to the two places it
needed to be and uberpov --version now at least id's proper because it
found the users conf file ... guess there's an error in the source
somewher that is causing it to look for "uberpovray. conf"
uberpov --version
Date: 21 Nov 2013 07:01:56
Message: <528df634$1@news.povray.org>
hmmm ... take it back!
> uberpov --version
shouldn't that be 1.3.7 ... VERSION file in root of build dir has:
1.37.0.0-alpha
so that means ~uberpov/unix/VERSION is correct ... could it be line 88
in ~uberpov/source/backend/povray.h ????
Date: 21 Nov 2013 07:39:44
Message: <528dff10@news.povray.org>
Am 21.11.2013 13:01, schrieb James Holsenback:
>> uberpov --version
> 1.37.0.0-alpha
No, that line is fine. In some places the program does tell the user
what official version of POV-Ray it is based on.
Found the culprits though; Git master should be ok now.
Thanks for finding those buggers, I'd probably never have seen them myself.
Date: 21 Nov 2013 07:50:49
Message: <528e01a9@news.povray.org>
>>> uberpov --version
>> 1.37.0.0-alpha
yer welcome ... was it on purpose that I can't view files in uber on
perforce
Date: 21 Nov 2013 08:11:30
Message: <528e0682$1@news.povray.org>
On 20-11-2013 18:10, clipka wrote:
> Happy POVing!
This is GREAT!
I am now playing around with the sample scene files before trying out on
my own scenes, but it looks fantastic.
Keep up the good work!
Date: 21 Nov 2013 08:30:53
Message: <528e0b0d$1@news.povray.org>
uberpov --version
UberPOV 1.37.0.0-alpha
OK ... id's proper now. uberpov.conf made it to
/usr/local/etc/uberpov/1.37/ but nada in users .uberpov directory
Date: 21 Nov 2013 08:48:47
Message: <528e0f3f@news.povray.org>
Am 21.11.2013 13:50, schrieb James Holsenback:
> perforce
Of course. I wouldn't want /you/ sniffing around in there ;-)
Seriously, I have no idea how I'd even be able to change the permissions.
Date: 21 Nov 2013 08:51:34
Message: <528e0fe6$1@news.povray.org>
Am 21.11.2013 14:30, schrieb James Holsenback:
> uberpov --version
Did you make install?
If not, then this is to be expected.
Date: 21 Nov 2013 08:56:41
Message: <528e1119$1@news.povray.org>
Am 21.11.2013 14:51, schrieb clipka:
>> uberpov --version
Uh... forget that statement. If you hadn't done make install, there
would be nothing in /usr/local/etc..., would there.
But it also means you installed as root; could there possibly be an
.uberpov directory now in the root's home directory?
What does POV-Ray proper do in that situation, anyway?
Date: 21 Nov 2013 09:04:12
Message: <528e12dc@news.povray.org>
> uberpov --version
As a side note, this message is just a warning; UberPOV should be able
to run just fine without a ~/.uberpov/1.37/uberpov.conf, except that it
prints this message. Same as POV-Ray does when it misses its
~/.povray/3.7/povray.conf file.
You might want to check though whether UberPOV accidently wrote an
uberpov.conf somewhere into ~/.povray, or even replaced POV-Ray's .conf
file. That would be seriously bad.
