POV-Ray : Newsgroups : povray.unofficial.patches : First official beta of UberPOV Server Time
19 Apr 2024 07:22:59 EDT (-0400)
  First official beta of UberPOV (Message 1 to 10 of 18)
Subject: First official beta of UberPOV
Date: 20 Nov 2013 12:10:25
Message: <528ced01@news.povray.org>
First official (beta) release of UberPOV is now available at:
https://github.com/UberPOV/UberPOV/tree/v1.37.0.0-beta.1
Windows binaries are now available as well. Just copy the uberpov*.exe
beside your pvengine*.exe.
Happy POVing!
Subject: Re: First official beta of UberPOV
Date: 20 Nov 2013 16:47:38
Message: <528d2dfa$1@news.povray.org>
Am 20.11.2013 18:10, schrieb clipka:
> Happy POVing!
Sorry, posted the wrong link; while the above does point in the general
direction, the actual distribution packages can be found here:
https://github.com/UberPOV/UberPOV/releases/tag/v1.37.0.0-beta.1
Date: 20 Nov 2013 17:40:09
Message: <528d3a49$1@news.povray.org>
> Happy POVing!
I had some problems with Makefile.in(s). first in ~uberpov/unix while
running prebuild.sh then during configure phase ...  this time
~uberpov/vfe/Makefile.in and ~uberpov/source/Makefile.in are problems. I
ended up getting those files from my povray git build directory and got
a good configure ... or so I thought. make halts right away with the
following:
make: *** No rule to make target `disp_sdl.cpp', needed by `disp_sdl.o'.
  Stop.
oh ... ~unix/prebuild clean doesn't seem to be working either
Date: 20 Nov 2013 18:17:10
Message: <528d42f6$1@news.povray.org>
Am 20.11.2013 23:40, schrieb James Holsenback:
>> Happy POVing!
Can you specify "some problems"?
> I ended up getting those files from my povray git build directory and got
> following:
>   Stop.
The files generated by POV-Ray's ./prebuild.sh won't cut it, due to
various differences related to the project name. IIRC some of them were
inevitable to make autoconf happy with the different project name.
 From what I can tell, prebuild.sh calls the generated makefiles for
some part of the cleanup job, so I'm not too surprised there either.
As I'm not really a Linux jockey I'd be happy about any help I can get
for sorting out those problems you experience.
Date: 20 Nov 2013 18:46:00
Message: <528d49b8$1@news.povray.org>
well ... i'm not into learning the in's and out's of make, and i guess
that put's me square in the middle of knowing just enough to be
dangerous, because things got broke quick. i think i'll hang back and
wait to see if converting to cmake gains any traction ... seems like
povray is becoming a windows-centric project
Date: 20 Nov 2013 19:12:37
Message: <528d4ff5$1@news.povray.org>
Am 21.11.2013 00:45, schrieb James Holsenback:
I don't think so; it has in the past years, but with the AGPL, Git repo
and all I expect it to swing back a deal towards Linux and, hopefully,
other platforms as well.
(That said, CMake may turn out to become part of that process of course.)
Date: 20 Nov 2013 19:40:19
Message: <528d5673$1@news.povray.org>
>> Happy POVing!
Looks like autoconf hates you when two .cpp files in the project have
the same name, even if they're in different directories. In this case it
is "backend/colour/colour.cpp" and the newly added "base/colour.cpp".
I definitely need to do something about it, or the problem will also
surface in POV-Ray proper (same change there, except that it hasn't made
it into the Git repo yet).
Date: 20 Nov 2013 21:08:22
Message: <528d6b16$1@news.povray.org>
Am 21.11.2013 01:40, schrieb clipka:
Fix available now at:
Date: 21 Nov 2013 06:11:27
Message: <528dea5f$1@news.povray.org>
OK thanks ... got a good build, however when when I did uberpov
--version a slight problem:
ash@linux-c2bm:~/ScratchPad/git/uberpov $ uberpov --version
uberpov: cannot open the system configuration file
/usr/local/etc/uberpov/1.37/uberpov .conf: No such file or directory
uberpov: cannot open the user configuration file
/home/ash/.uberpov/1.37/uberpov.conf: No such file or directory
uberpov: I/O restrictions are disabled
UberPOV 3.7.0.unofficial
Notice the space in uberpov.pov above ... the file lives properly in the
root of the build directory. It did /not/ get copied into
/usr/local/etc/uberpov/1.37 (uberpov.ini /did/). ~users/.uberpov on down
did /not/ get created ... copied uberpov.conf to the two places it
needed to be and uberpov --version now at least id's proper because it
found the users conf file ... guess there's an error in the source
somewher that is causing it to look for "uberpovray. conf"
uberpov --version
Date: 21 Nov 2013 07:01:56
Message: <528df634$1@news.povray.org>
hmmm ... take it back!
> uberpov --version
shouldn't that be 1.3.7 ... VERSION file in root of build dir has:
1.37.0.0-alpha
so that means ~uberpov/unix/VERSION is correct ... could it be line 88
in ~uberpov/source/backend/povray.h ????
