POV-Ray : Newsgroups : povray.unofficial.patches : Error trying to use MegaPOV 1.2 post_process Server Time
28 Jul 2026 02:51:06 EDT (-0400)
  Error trying to use MegaPOV 1.2 post_process (Message 1 to 4 of 4)
Subject: Error trying to use MegaPOV 1.2 post_process
Date: 29 Oct 2010 05:25:01
Message: <web.4cca9278338c34b17b578a710@news.povray.org>
Hi all,
I'm trying to use megapov post_process in order to create a Depth image.
I already struggled to get megapov running on a simple povray scene, had to copy
inc files in the good directory and stuff.
The problem I am experimenting now is the following :
I added to my scene the code :
#version unofficial MegaPOV 1.2;
#include "pprocess.inc"
in the beginning, and then in the end :
post_process{PP_Depth(pdV,150)}
When I run it, i get an error message :
"Parse Error: Expected 'object or directive', post_process found instead"
How do I get post_process recognize ??? Did I forget to include something ? Or
is my declaration of megapov version wrong ?
Thanks for helping,
Subject: Re: Error trying to use MegaPOV 1.2 post_process
Date: 29 Oct 2010 07:41:51
Message: <4ccab2ff@news.povray.org>
  IIRC, that should go in the global_settings{} block...
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 2 Nov 2010 06:30:01
Message: <web.4ccfe7d1453f6bf87b578a710@news.povray.org>
Thanks for the hint !
I was able to reach the next error : the compiler now recognizes the
post_process and the PP_Depth, but it stops in pprocess.inc (which I absolutely
did not modify), in the macro :
#macro _filter_depth(_f_in,_firld_start,_firld_depth)
function{clip(adj_range2(_f_in(u,v),_firld_start,_firld_start+_firld_depth,0,1),0,1)}
The error message is "Parse error, expected 'operand', found vector identifier
instead"
It seems to come from "_f_in(u,v)"
I don't understand what I did wrong. Did I give wrong inputs to PP_Depth ?
I called the function this way :
global_settings{
     post_process{PP_Depth(<0,150,0>,150)}
completely in the end of my scene's code...
Thanks for helping
Date: 2 Nov 2010 10:16:26
Message: <4cd01d3a$1@news.povray.org>
> absolutely did not modify), in the macro :
> #end
> identifier instead"
  Most likely, yes...
> global_settings{
  This seems a clear case of RTFM... :)
  I've just looked at
http://megapov.inetart.net/manual-1.2.1/megapov0121.html#inc_pprocess.inc
  and there I read "Field_Start specifies the beginning of the focal
range *IN UNITS* from the camera." ;)
