![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Changing the order of block rendering (not starting always top left)
Date: 14 Jul 2010 15:04:45
Message: <4c3e0a4d@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Why: because the interesting part of a render in progress might not
start at the top left, continuing on the right and proceding like a book
of western culture. (and it might be more fun to have the pictures
rendered with alternative ways)
Apply to 3.7beta38
Default remain left-to-right, top to bottom (ro1.png).
Additional possibilities are:
- top-left to bottom, then left to right (ro2.png)
- top corners, top line, then last line and ending on the center (ro3.png)
- start at center, make it line by line (above & under alternatively)
(ro4.png)
- left-most cornet, then last columns and ending on the center (ro5.png)
- start at center, build central column and expand on each side.
(ro6.png)
Pictures are illustration from black to white of blocks' dispatching.
How to use: (syntax free to change for better naming)
command line: +HGRO x (with x between 0 and 5)
ini file: HG_Render_Order=x
Interest: Up to you.
Download 'ro1.png' (31 KB)
Download 'ro2.png' (31 KB)
Download 'ro3.png' (31 KB)
Download 'ro4.png' (31 KB)
Download 'ro5.png' (32 KB)
Download 'ro6.png' (32 KB)
Download 'order.tar.gz' (35 KB)
Preview of image 'ro1.png'
![ro1.png](/povray.unofficial.patches/attachment/%3C4c3e0a4d%40news.povray.org%3E/ro1.png?ttop=423942&toff=50&preview=1)
Preview of image 'ro2.png'
![ro2.png](/povray.unofficial.patches/attachment/%3C4c3e0a4d%40news.povray.org%3E/ro2.png?ttop=423942&toff=50&preview=1)
Preview of image 'ro3.png'
![ro3.png](/povray.unofficial.patches/attachment/%3C4c3e0a4d%40news.povray.org%3E/ro3.png?ttop=423942&toff=50&preview=1)
Preview of image 'ro4.png'
![ro4.png](/povray.unofficial.patches/attachment/%3C4c3e0a4d%40news.povray.org%3E/ro4.png?ttop=423942&toff=50&preview=1)
Preview of image 'ro5.png'
![ro5.png](/povray.unofficial.patches/attachment/%3C4c3e0a4d%40news.povray.org%3E/ro5.png?ttop=423942&toff=50&preview=1)
Preview of image 'ro6.png'
![ro6.png](/povray.unofficial.patches/attachment/%3C4c3e0a4d%40news.povray.org%3E/ro6.png?ttop=423942&toff=50&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> of western culture.
indeed. Blender starts from the center. Unbiased renderers start from
everywhere and a rough noisy preview is available in a few seconds, with most
light contributions already in place so you know before hours if that caustic is
looking good next to a wall or not...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Changing the order of block rendering (not starting always top left)
Date: 18 Jul 2010 03:14:51
Message: <4c42a9eb@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I like this. Should have great potential indeed.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 21 Jul 2010 16:41:30
Message: <4c475b7a$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 14.07.2010 21:04, schrieb Le_Forgeron:
> Apply to 3.7beta38
Did you make sure that it co-operates properly with the recent changes
to radiosity pretrace (especially the adaptive pretrace mechanism)?
How about a mode that starts in the center and then goes around in
"circles"?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Changing the order of block rendering (not starting always topleft)
Date: 22 Jul 2010 04:38:45
Message: <4c480395$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 21/07/2010 22:41, clipka nous fit lire :
>> Apply to 3.7beta38
Does radiosity pretrace rely on the View object ?
Only the View object is impacted by this patch. (well, the option system
too; but that's only a minor addition)
> "circles"?
Code is provided; it's basically adding 2 functions to replace the
previous computation made inline with modulo, twice in the code
(duplicating such code is a call for trouble in the futur).
Each function (one for X, the other for Y) is a switch statement which
choose how the bloc number is converted into X,Y block coordinates.
If you want more mode(s), just add your own case(s) in the switch, and
expand the clipped-range used for the option.
I do not have the math for computing a transformation which start at
center and goes around as circle (starting at center is easy and done
for mode 3 & 5, but circling is not, at least for me), feel free to
provide that if you can. (beware, the picture might not be a square, and
the numbering must cover any rectangle ratio)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 22 Jul 2010 06:29:41
Message: <4c481d95$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 22.07.2010 10:38, schrieb Le_Forgeron:
I just found time to actually look at the code, and I must say it looks
like a pretty elegant, "minimally-invasive" solution.
Yes, the other modules are perfectly unaware of the mapping of "block
numbers" vs. screen coordinates; some are actually aware of block
nubers, but all they know (or expect) is that the number is unique for
each block - plus a special mode of operation in which radiosity
pretrace code expects the numbers to be consecutive and in the same
order in which the blocks are actually dispatched to the individual threads.
I have only two points of critique:
(1) I think the computation of blockX and blockY should be done in one
single function, to prevent "fragmentation" of the mapping rules for
each case. (It is not uncommon in the POV-Ray code for a function to
have multiple output values.)
(2) Your code does not match the files' overall code formatting style :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 22 Jul 2010 06:35:01
Message: <4c481ed5$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 22.07.2010 12:29, schrieb clipka:
Oh, and (3) I can't make out what the "HG" in "HG_Render_Order" and
"HGRO" stands for, so I'd suggest to reconsider those option names.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 22 Jul 2010 06:57:47
Message: <4c48242b$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 22/07/2010 12:34, clipka nous fit lire :
Go for it! Feel free to amend and do what ever you want with it.
Find & use any naming you like for (3).
I even agree with (1), it was just easier to try it that way (replacing
each formula with a function) as a plugged replacement. On a
production-source, it might be better to rethink it further: you're right.
For (2), do you have any documentation (or indent rules, in fact, I
would like the indent rules better, as autoformating is far easier than
following manual rules), I would be glad to set my editor (gvim) to
format the code (in any futur contribution, should it happen)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 22 Jul 2010 07:09:37
Message: <4c4826f1$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 22/07/2010 12:29, clipka nous fit lire :
> threads.
Same order, yes (probably), but consecutive...I fear some render_order
modes are using a kind of double-head implicit list (apart from 0 & 1,
all use alternatives block dispatching : left/right or up/down... as
even/odd block numbers, look at the pictures of the first message, so as
to expand the image quickly)
Mode 3 & 5 (expanding from center) remains connected (even if block
expansion is done both way, even in one direction, odd in the opposite),
but 2 & 4 starts with top-left corner for block 0, then either top-right
or bottom-left for block 1, and then when the first line is done, the
next line is the one at the opposite side of the picture. They keep
alternating all the way down to the center of the picture (final block),
in both X & Y.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 22 Jul 2010 15:36:05
Message: <4c489da5@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 22.07.2010 13:09, schrieb Le_Forgeron:
>> threads.
> modes are using a kind of double-head implicit list (apart from 0& 1,
Maybe there's a misunderstanding here. What I mean is not that blocks N
and N+1 are next to each other, but that if there exists a block with
number N, there also exists a block with number N+1 (unless it's the
last block), and that block N+1 is dispatched after block N.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
