POV-Ray : Newsgroups : povray.unofficial.patches : Win10 UberPov minor locking when switching to/from Server Time
20 Oct 2026 20:16:19 EDT (-0400)
  Win10 UberPov minor locking when switching to/from (Message 1 to 4 of 4)
Subject: Win10 UberPov minor locking when switching to/from
Date: 15 Nov 2016 19:55:51
Message: <481645455.500950424.052595.gdsHYPHENentropyAThotmaolDOTcom@news.povray.org>
I noticed that under Win 10 x64 that when switching to/from the UberPov
window it will freeze for a second or two, and when there is a completed or
working render it is a bit more pronounced.
Has anyone else noticed such?
Ian
Subject: Re: Win10 UberPov minor locking when switching to/from
Date: 15 Nov 2016 22:20:19
Message: <582bd073$1@news.povray.org>
Am 16.11.2016 um 01:55 schrieb [GDS|Entropy]:
I can't think of any reason whatsoever why that should happen with
UberPOV but not with official contemporary POV-Ray pre-releases. They
differ in the set of features, but the overall architecture is virtually
identical, and as of recently the pre-releases also use exactly the same
build environment.
Date: 16 Nov 2016 20:54:50
Message: <1216175028.501040436.410587.gdsHYPHENentropyAThotmaolDOTcom@news.povray.org>
> build environment.
It is quite possible that it is some aspect of Windows 10 pro, but yes it
is puzzling.
Ian
Date: 16 Nov 2016 22:00:00
Message: <web.582d1c3eed589d179c5d6c810@news.povray.org>
> > build environment.
> is puzzling.
Win 10 64-bit here too and no pauses from program transitions, however, I've had
a couple crashes from the POV-Ray alpha versions going back a month or two.
Saved 2 sets of dump files, hundreds of megabytes. Thought I would wait to see
if it would happen a lot more or change with newer releases.
Event Viewer does show something went wrong with UberPOV in September:
Fault bucket 50, type 5
Event Name: RADAR_PRE_LEAK_64
Response: Not available
Cab Id: 0
Problem signature:
P1: uberpov64.exe
P2: 3.7.0.0
P3: 10.0.14393.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
\\?\C:\Users\Bob\AppData\Local\Temp\RDRFF43.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERFF82.tmp.WERInternalMetadata.xml
These files may be available here:
Analysis symbol:
Rechecking for solution: 0
Report Id: 320daf4b-7a6f-11e6-9bed-dc5360a9a04b
Report Status: 0
Hashed bucket: 654db5c4b9e65eb5527a9f78fc1a0507
While the alpha POV-Ray very recently shows this:
Application popup: POV-Ray for Windows : Unfortunately, it appears that a memory
access violation at address 0x0000000140349AA5 has caused this unofficial
POV-Ray build to crash. This dialog will allow you to choose whether or not a
dump file (useful for diagnostics) is written.
And also going back to September, or August, I've seen an application memory
error message (possibly some other type) flash on the screen at Shutdown.
Happens too fast for me to see or read anything. Probably a dozen or more of
those to date, but I haven't tried to check what it might be in the Event Viewer
next Startup. Only looking for things now because of this message post.
