POV-Ray : Newsgroups : povray.unofficial.patches : False obstinance in linux installer? Server Time
19 May 2024 01:54:32 EDT (-0400)
  False obstinance in linux installer? (Message 11 to 14 of 14)
Subject: Re: False obstinance in linux installer?
Date: 15 Nov 2007 13:02:23
Message: <473c89af$1@news.povray.org>
> I wouldn't call it a bug, so much as the standard Povray installer not
> quite conforming to the FHS.
	POV's install paths try to conform as much as possible to the FHS,
but if you found some that are off-standard, please report them  :-)
	- NC
Date: 15 Nov 2007 17:40:53
Message: <473ccaf5@news.povray.org>
   Apparently, /usr/share/povray-3.6 is not conforming, so it was changed to
/usr/share/povray. ;)
Jaime
Date: 16 Nov 2007 00:43:19
Message: <473d2df7$1@news.povray.org>
Hash: SHA1
Okay, I'm being stupid.
The official Povray installer installs under /usr/local, as it should,
since it isn't part of the system's package system. The
distribution-specific packages do not, since, drumroll, they *are* part
So, this makes me wonder if it actually *would* be sane to have the
Megapov installer check for the packaged versions of POV. The above
would imply that there's really only two places that it would have to
search for things, barring distributions with weird notions of how the
system heirarchy should work.
William Tracy
You know you've been raytracing too long when you're quite happy to let
people think you're on a mission to enlighten the world - in other
words; you've stopped trying to explain what "global illumination" is.
    -- Alex McLeod a.k.a. Giant Robot Messiah
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHPS33KrVIcTMekC8RAmnqAKDQDrNvTtaDUit7c8L+bRH8R0PvGwCfZTQY
2HTm4E9T/w3zgl5mRWF6CEM=
=DiDW
-----END PGP SIGNATURE-----
Date: 16 Nov 2007 02:50:00
Message: <web.473d4b18bb855db982e15b410@news.povray.org>
BTW, not only it's not hard to do the usual config/make stuff as you're likely
to only need to do it once:  most dependency binary libs are upward compatible,
so, moving on to a newer distro you only need your latest binary.  No need to
recompile.  My povray binary has already survived 3 distros! :)
