POV-Ray : Newsgroups : povray.unofficial.patches : Tilemap patch for Megapov 1.2 Server Time: 21 Mar 2010 15:50:32 GMT
  Tilemap patch for Megapov 1.2 (Message 1 to 6 of 6)
Subject: Tilemap patch for Megapov 1.2
Date: 11 Sep 2006 01:50:05
Message: <4504c0cd$1@news.povray.org>
I have developed a new feature for Megapov which I call a "Tile map".
This is an image map, where each pixel of the image is another image. Go
look on povray.binaries.images for an example.
The really significant part, which makes this patch different from just
tiling the images separately in some other program and using the
composite in pov, is that the tiles can be sparse. The example image is
specified to be an array of 6x6 tiles, but only 13 of those tiles are
specified. The rest are transparent, and take only a tiny amount of
memory overhead, compared to an occupied tile.
I wrote this to take advantage of the Blue Marble dataset from NASA. It
is an image 86400x43200 pixels big, which when unpacked into memory
would take 11GiB. This is no good. What I have done is broken the image
up into tiles, and wrote some script which decides which tiles are
visible and close enough to need the full resolution, and only loads
those tiles.
I would like to see this patch incorporated into the next version of
Megapov. Who do I have to bribe in order to get that to happen? Aside
from this one, I have about 6 other patches I would like to get into
Megapov.
I will post the patch some time in the future, especially if anyone
shows any interest.
Subject: Re: Tilemap patch for Megapov 1.2
Date: 11 Sep 2006 05:15:03
Message: <ee2raq$ius$1@chho.imagico.de>
> Megapov.
This is strongly influenced by the following points:
- is there interest in using the patch?
- does the syntax/usage make sense, is the solution well suited for the
problem it is intended for?
- is the patch well written?
- is the patch sufficiently documented?
- has the patch already been tested?
Concerning your specific addition i have a few questions:
1) why is it restricted to image maps?
2) does it handle interpolation across the tile boundaries? (only makes
sense with (1) of course, difficult with different resolution tiles)
3) why is it restricted to a regular rectangular pattern?
What would be really interesting is a dynamically cached image map (i.e.
one that actually loads tiles on demand).  You would have to be careful
when using the internal image reading functions for this though - they
are not really intended to be used at render time.
http://www.imagico.de/ (Last updated 20 Aug. 2006)
Date: 11 Sep 2006 12:49:53
Message: <45055b71@news.povray.org>
  One possibility would be to temporarily write the image in raw format
onto a file and then read parts of that file on demand. This would just
consume disk space instead of consuming RAM.
  The difficulty in this is how to decide when to drop image parts from
the cache. There's no universal way of knowing how much memory is
available. One possibility would be for the user to specify manually
some value.
Date: 11 Sep 2006 17:50:03
Message: <ee47e1$la0$1@chho.imagico.de>
That would mean unnecessarily copying possibly lots of GB and in case of
a compressed format also decompressing it - data that is possibly not
needed at all since the render only uses a small part.
If such a patch is developed it would be good to have both the
possibility to use large uncompressed files directly and alternatively
to specify already existing tile images that can directly be used for
the dynamic caching.  Often when dealing with large images you have them
in form of tiles anyway to simplify handling and local modifications.
What would make sense for compressed formats is to temporarily store
expired tiles to disk to avoid decompressing them again in case they are
needed.
> some value.
That's what makes most sense i suppose (having the possibility to
specify the tile size and the number of tiles to keep would allow
detailed control over the performance).
Date: 12 Sep 2006 15:34:49
Message: <4506d399@news.povray.org>
I'm not sure that it is, it is just that I have never tried it for
anything else. My particular application only needs image maps. It is
implemented as a new image type, so it might "just work" anywhere an
image is needed.
Probably not. Again, I haven't tested it in this condition. At the
moment, I'm not even sure that it handles interpolation properly within
a tile.
This patch will work (without interpolation) for tiles of different
resolutions, but I am not sure what would happen with tiles of different
color types (grayscale, indexed, rgb). I suspect it would still work in
this case, but I haven't tried it.
Are you suggesting triangles and hexagons? Or a rectangular map with a
different number of tiles in each row? I thought about the latter, and
that can be implemented using nested tilemaps. Since with this patch a
tilemap is just another image type, it can be used anywhere any image
type can be used, including as the definition for another tilemap. For
instance, the outer tilemap is 1 column by n rows, and each row is an
inner tilemap with q columns by one row, where q is different for each row.
I guess the answer to all three questions is "That's not how I use it",
and that's not a good answer in order to get this patch included.
However, it has been my experience that there are lots of creative
people out there who can squeeze stuff out of a feature that the
programmer never even considered. If this patch were included, some
artist somewhere would surprise me.
Interesting. For my application, I have a script which determines which
tiles will be visible in a scene, and close enough to the camera to
matter, and pre-loads those. Since I know in advance that all tiles will
be used, it doesn't seem to make sense to have a dynamic loading system
like this.
> Christoph
In order to be reviewed, should I post the patch here? Where should I
put patches?
Chris
Date: 12 Sep 2006 18:45:03
Message: <ee6v76$ksl$1@chho.imagico.de>
> put patches?
You can post small patches to povray.binaries.programming but if you
want to include documentation, sample scenes etc. it is probably better
to put up a web page somewhere.
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
