POV-Ray : Newsgroups : povray.unofficial.patches : Megapov: is there a bug? mesh in environment Server Time
23 Apr 2024 05:58:08 EDT (-0400)
  Megapov: is there a bug? mesh in environment (Message 1 to 1 of 1)
Subject: Megapov: is there a bug? mesh in environment
Date: 9 Jul 2006 13:42:39
Message: <44b1400f$1@news.povray.org>
I don't know if this could interest anyone here, but I don't know where
else to post it :-)
Defining the object in the environment section I used a mesh2 but
Megapov 1.21 had a problem, the error message was:
"The POV-Ray core rendering code threw an unhandled exception.
The backend thread has been shut down and you will not be able to
perform any further renders.
The mesh2 object was created using param.inc, from
http://members.home.nl/seedseven/#param
Code example that gives that problem:
======cut=====
#version unofficial MegaPov 1.21;
#include "mechsim.inc"
#include "param.inc"
#include "math.inc"
#declare FR=function{pattern{bozo scale 0.3}}
#declare R1=function(u,v){
         f_ridged_mf(14*u,14*v,0, 1, 4.77, 31, 0.5, 2, 1)
#declare F1= function(u,v){u}
#declare F2= function(u,v){v}
#declare F3= function(u,v){
                 R1(u,v)*0.2+FR(u,v,0)*0.1
                 +sin(u-1.5)/2.5+
                 sin(v-1.5)/10
#declare base=
object{
    Parametric(
       F1, F3, F2,
       <-3, -3>,
       < 3, 3>,
       35,35,
    scale 5
    uv_mapping
    rotate<0,180,0>
    pigment{
         White
#declare ob_env=union{
         object{ base}
global_settings {
   assumed_gamma 1.0
   mechsim {
     gravity <0, -9.81, 0>
         method 1
     environment {
         object ob_env
         stiffness 240000
         damping 50000
         friction 0.1, 1.01
         method 1
     #declare fname="bug00-";
     #if (clock_on)
         #declare start=0;
         #declare
datin=concat(fname,"-",str(start+frame_number-1,-2,0),".dat");
         #declare
datout=concat(fname,"-",str(start+frame_number,-2,0),".dat");
         #debug concat ("read ",datin," write ",datout,"\n")
         #declare ffn=30;
         #declare stc=30;//0-2 1400;//1400
         #declare dvc=80;//0-2 1400;//1400
         step_count stc
         time_step (1/ffn)/dvc
       topology {
         load_file datin //datfile
         save_file datout //datfile
     #else
       step_count 0
       #local dde=25000;
       #local ddi=25000;
       topology {
         MechSim_Generate_Sphere(<0, 0, 0>, 0.05, dde, 1900, 2000, ddi,
1600, 2000, true, 1, 0.75,
                 transform{
                         scale<1,1.5,1>
                         rotate<0,0,135>
                         translate<0,4,0>
         #declare datout=concat(fname,"-00.dat");
         save_file datout
#declare MSim_Tex_N=texture{
         pigment { Red }
#declare MSim_Tex_C =texture{
         pigment{Yellow}
#declare MSim_Tex_Mesh=texture{
         pigment{
                 Red
MechSim_Show_All_Objects(-1, false, -1, "")
object{
         ob_env
light_source {
   <0, 120, 0>
   color rgb <1, 1, 1>
sky_sphere {
     gradient y
     color_map {
       [0.0 rgb <0.3,0.35,0.8>]
       [0.7 rgb <0.0,0.1,0.4>]
#declare cax=0;
#declare caxd=0;
#declare cay=3.25;
#declare cayd=-0.5;
#declare caz=-26.0;
#declare cazd=16.0;
#declare caxl=cax+caxd;
#declare cayl=cay+cayd;
#declare cazl=caz+cazd;;
   location  <cax, cay, caz>
   up y*1
   look_at   <caxl, cayl,  cazl>
======cut=====
If clock_on is false all works and the .dat file is created, after that,
using the -kff switch, it gives the error message.
The operative system used to run Megapov is Windows 98 SE.
Using a parametric object instead of the mesh2 works fine.
'bye
