POV-Ray : Newsgroups : povray.unofficial.patches : Linux framebuffer patch version 0.3.1 released Server Time
11 Jul 2026 09:52:46 EDT (-0400)
  Linux framebuffer patch version 0.3.1 released (Message 1 to 1 of 1)
Subject: Linux framebuffer patch version 0.3.1 released
Date: 24 Aug 2005 07:36:42
Message: <430c5bca@news.povray.org>
The version 0.3.1 of the Linux framebuffer patch to povray-3.6.1 for Unix
is available for download here:
http://pov4grasp.free.fr/download/povray-3.6.1-fb-0.3.1.tar.bz2
	This is a bugfix release, no new feature is added.  The following lists
the changes from version 0.3.0 to 0.3.1:
- fix color mismatch with 16 bpp directcolor visual (untested)
- fix dithering problems with alpha transparency
- fix incorrect display of transparent background without +ua
- fix screen coordinates to always deal with virtual resolution
	Installation instructions:
	To apply the patch, untar the archive and copy all the files from the
newly created povray-3.6.1-fb-0.3.1/ directory to the corresponding locations
in the source distribution of povray-3.6.1.  Then run the ./configure script
as usual, and 'make check' to build and run a test render.  The tarball contains
only the new and modified files, as compared to the official povray-3.6.1 for
Unix source archive.
(From version 0.3.0 to 0.3.1 only the unix/fbb.cpp file was actually changed.
Thus it should be safe to copy that file alone if you already applied the
previous version of this patch to the povray-3.6.1 sources.)
     - NC
