POV-Ray : Newsgroups : povray.unofficial.patches : Problem rendering cinematic like explosing with MegaPov 1.1 Server Time
29 Apr 2024 10:36:29 EDT (-0400)
  Problem rendering cinematic like explosing with MegaPov 1.1 (Message 1 to 4 of 4)
Subject: Problem rendering cinematic like explosing with MegaPov 1.1
Date: 20 Jun 2005 04:48:00
Message: <42b682c0@news.povray.org>
Hello folks,
I have modified the cinematic-like explosiong file posted by H.E. Day at
p.b.sf
The original file was intended for Megapov 0.4, and I have made a few
changes to try to render it with MegaPov 1.1. Here is the modified version:
$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ BEGIN FILE $$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Real Explosion Ver .5
Created by H.E. Day
mailto: Pov### [at] aolcom
This is a demonstation of the explosion.  I will add more features
and functions soetine in the future. Feel free to use this version
in any pic or anim as long as you give me credit for the explosion.
I recommend that you render this with 60 frames or more. Happy destruction!
#version unofficial MegaPov 1.10;
#include "pprocess.inc"
global_settings {
post_process {soft_glow{.675, 2}}
#declare Rand = -18
#declare Deform = 1
#declare Detail = .05  //.001 - .1 are good values.
#declare Smoke =  on    //turns the light-sampling smoke on or off
#declare SmokeAmount = 1.25    //.5 is about minimum
#declare SmokeGlowAmount = 1/2
#declare FireBrightness = 1  //.5 is about minimum
#declare FireRedness = 1/2
#declare SmokeBrightness = 1 //.5 is about minimum
#declare SmokeDrift = off //Will the smoke drift?  Any wind?
#declare SmokeDriftDirection = y //doesn't matter if not using SmokeDrift
#declare SmokeDriftAmount = 1 //doesn't matter if not using SmokeDrift
#declare ModClock = pow(clock,.5)
#if (SmokeDrift = off)
#declare SmokeTranslate = vrotate(ModClock/2*y,Rand-90)
#declare SmallSmokeTranslate = vrotate(ModClock/4*y,7*Rand)
#else
#declare SmokeTranslate = ModClock*SmokeDriftDirection*SmokeDriftAmount
ModClock*(SmokeDriftDirection/2)*SmokeDriftAmount
#declare Base=function {"sphere",<1>}
#declare Add1=
function {
pigment {granite
color_map {[0 rgb 1][1 rgb 0]}
scale 3
translate 2*ModClock
warp {turbulence 1 omega 0}
translate -2*ModClock
translate Rand
translate SmokeTranslate
#declare Add3=
function {
pigment {granite
color_map {[0 rgb 0][1 rgb 1]}
scale 4
translate Rand
#declare Add2=
function {
pigment {granite
scale 1/4
translate 1*ModClock
translate -1*ModClock
translate Rand
translate SmallSmokeTranslate
isosurface {
function {
Base(x,y,z)
+(Add1(y,z,x))*(.65*Deform-(clock*.15*Deform))
+(Add2(y,z,x))*(.15*Deform-(clock*.05*Deform))
eval
accuracy Detail
contained_by{sphere{0,1}}
granite
color_map {[.3+.7*clock rgb
SmokeBrightness-(sin((clock-.25)*2*pi)/2+.5)/2 transmit
2*clock-1][.7+.3*(2*clock-1) rgb SmokeBrightness-sin(clock * 2 * pi)/2
transmit pow(clock,.75)/2]}
scale 1/2
translate Rand
normal {bumps scale .125/3 turbulence .5 bump_size .45*clock}
#if (Smoke = on)
finish {ambient 1/2-clock/2 diffuse 1-clock }
#else
finish {ambient 0 diffuse 0 }
pigment {spherical color_map {
[.15*(1-SmokeGlowAmount) rgbt <1,1/2*(1-FireRedness),0,1>*FireBrightness]
[.4 rgbt <1,1/2*(1-FireRedness),0,.5>*FireBrightness]
[.575 rgb <1,.75-(.5*ModClock)*FireRedness,.1>*1.5*FireBrightness]
[1 rgb 1]
}scale 10 warp {turbulence 1 omega .125} scale 1/10  turbulence .35}
finish {ambient 1}
scale (1.5-(clock*1.5)*(SmokeAmount/2+1/2))*1.45
hollow on
scale 1/2+ModClock*3/2
direction 1
location <0,0,2>*2
look_at <0,0,0>
light_source {<75,20,0>*100 rgb 1}
sphere {0,1/3 pigment { rgb 1}}
$$$$$$$$$$$$$$$$$$$$$ END FILE $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
and this is the error I am getting:
File Context (5 lines)
global_settings {
Parse Error: expected 'operand', found { instead
I have looked at the post_process syntax and I can't find where the
parse error is.
Can anyone help me figure out where the error is?
Thanks in advance
Fidel.
Subject: Re: Problem rendering cinematic like explosing with MegaPov 1.1
Date: 20 Jun 2005 07:34:34
Message: <42b6a9ca$1@news.povray.org>
"Fidel Viegas" <non### [at] nodomaincom> wrote in message
news:42b682c0@news.povray.org...
> Hello folks,
> p.b.sf
> global_settings {
> parse error is.
The problem is that the post-processing feature of MegaPov 1.1 (or higher) is
completely different (more powerful, but sadly enough also a lot slower) than it
was in MegaPov 0.4.  Remove the post-process block, and it should work fine.  If
you want the soft-glowing post-processing, you'll need to make it yourself,
because, as far as I know, it's not included with MegaPov 1.1.  It's not that
hard to do, but as I said earlier, it's rather slow.
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)                 // ZK http://www.povplace.com
Date: 20 Jun 2005 07:45:02
Message: <d96a7d$93e$1@chho.imagico.de>
Fidel Viegas wrote:
> Hello folks,
> p.b.sf
> global_settings {
This isn't valid MegaPOV 1.x syntax - see
http://megapov.inetart.net/manual-1.2/inc_pprocess.inc.html#post_proc_macros
for how to use it.  Note however that there isn't any 'soft glow' filter
implemented at the moment.
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
Date: 20 Jun 2005 09:36:35
Message: <42b6c663@news.povray.org>
Thanks a lot guys!
I'll try to play with it.
Fidel.
