POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOV's PostProcessing and blurring Server Time
11 Jul 2026 11:25:49 EDT (-0400)
  MegaPOV's PostProcessing and blurring (Message 1 to 3 of 3)
Subject: MegaPOV's PostProcessing and blurring
Date: 9 Mar 2005 10:20:20
Message: <422f1434@news.povray.org>
I'm still working on that nuclear explosion, but it would be nice if I could
make the brightest parts of it really glow.  So I made this:
- begin code -
#macro Blur_red(S,RX,RY,Samples,Division)
 #local Seed=seed(S);
    function {
     f_output_red(x,y)
     +( #declare C=0;
      #while (C<Samples)
       #declare X=(rand(Seed)-rand(Seed))*RX;
       #declare RY=rand(Seed)*pi;
       #declare Y=sin(RY)*X;
       #declare X=cos(RY)*X;
       f_output_red(x+X,y+Y)/Division+
       #declare C=C+1;
    0)/Samples
#macro Blur_green(S,RX,RY,Samples,Division)
    function {
     f_output_green(x,y)
     +( #declare C=0;
      #while (C<Samples)
       f_output_green(x+X,y+Y)/Division+
       #declare C=C+1;
    0)/Samples
#macro Blur_blue(S,RX,RY,Samples,Division)
    function {
     f_output_blue(x,y)
     +( #declare C=0;
      #while (C<Samples)
       f_output_blue(x+X,y+Y)/Division+
       #declare C=C+1;
    0)/Samples
global_settings {
 post_process {
  PP_Init_Alpha_Colors_Outputs()
  Blur_red(1565,.05,.05,50,5)
  Blur_green(1565,.05,.05,50,5)
  Blur_blue(1565,.05,.05,50,5)
  function { f_output_alpha(x,y) }
  save_file "duplication.png"
- end code -
But as you probably can imagine, it gets extremely slow at decent settings.
Is there a faster way ?  In case it's not clear, this is what I want:  I want
the original image combined (additive) with a darkened blurred version of the
original.
cu!
Subject: Re: MegaPOV's PostProcessing and blurring
Date: 9 Mar 2005 11:25:13
Message: <is7u211jgu7cgc8u1cv8g4nss4hhr4med0@4ax.com>
On Wed, 9 Mar 2005 16:20:42 +0100, "Zeger Knaepen"
>    function {
>     f_output_red(x,y)
>     +( #declare C=0;
>      #while (C<Samples)
>       #declare C=C+1;
>      #end
>    0)/Samples
> #end
One thing is that you are doing "/Division" 'Samples' times. Instead of this
you could do "/(Samples*Division)" after sum.
More difficoult improvement (in fact I'm not sure it will improve but hard to
judge without testing) could be to move rand from parsing to runtime and
decrease length of the function. I mean take benefits of sum() function like
   function {
     f_output_red(x,y) +
     sum(i,0,Samples-1,f_output_red(x+f_X(i,S),y+f_Y(i,S)))/(Samples*Division)
where f_X() and f_Y() are functions which simulate random generator using some
noise pattern with your trigonometry applied.
ABX
Date: 9 Mar 2005 11:50:55
Message: <422f296f@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:is7u211jgu7cgc8u1cv8g4nss4hhr4med0@4ax.com...
> >    function {
> >     f_output_red(x,y)
> >     +( #declare C=0;
> >      #while (C<Samples)
> >       #declare C=C+1;
> >      #end
> >    0)/Samples
> > #end
>    function {
>      f_output_red(x,y) +
> #end
ok, I removed the randomness and I placed the division after the sum.  It's
slightly faster, looks slightly better, but is still way to slow to be useful :(
cu!
