POV-Ray : Newsgroups : povray.unofficial.patches : XML-RPC Render Server protocol 0.9.0 RFC Server Time
15 Jun 2026 10:52:31 EDT (-0400)
  XML-RPC Render Server protocol 0.9.0 RFC (Message 1 to 6 of 6)
Subject: XML-RPC Render Server protocol 0.9.0 RFC
Date: 10 Aug 2004 07:03:37
Message: <4118ab89$1@news.povray.org>
Hi all,
    I've mentioned that I'm working on a patch to POV-Ray that turns it
into a render server. However, since a goal is to get authors of
existing parallel render software to include support for the an XRS
render slave (XML-RPC Render Server), I've drafted (and attached) a
protocol spec that I submit for your comments. I have a working patch
made that uses my protocol, which I am cleaning up and preparing for
release.
Thanks,
George
George Pantazopoulos
http://www.gammaburst.net
Download 'us-ascii' (15 KB)
Subject: Re: XML-RPC Render Server protocol 0.9.0 RFC
Date: 11 Aug 2004 14:32:40
Message: <411a6647@news.povray.org>
> release.
Two comments:
(1) Did I miss anything or is there no client authentication?
    Since the only "render farm" I could use is available to more people
    than me alone, I'd never use something which does not at least have
    some challenge-response auth.
(2) In case we have 20 computers for a render task and parsing + photons
    (only?) takes 5% of total time, then the complete overhead is 100%, i.e.
    we spend twice as much CPU*computers as necessary.
    Overcoming this by having the client doing the parsing and send the
    internal state to the server, however, is probably really hard to do.
    This is IMO only a problem when rendering animations (per-frame rendering
    time normally relatively short) or scenes which need a lot of parsing.
Wolfgang
Date: 11 Aug 2004 20:14:43
Message: <411ab673@news.povray.org>
Hi Wolfgang!
> Two comments:
       You are certainly right to bring up this point, and I have
considered it as well. However, ssh already does this better than
anything I could code up, so I felt I shouldn't try reinventing the wheel.
       I regurlaly run a MegapovXRS server on a remote machine, which I
connect to by using ssh port forwarding. For the sake of example, say
the remote (Server) machine is 'caboose' and the local (client) machine
is 'megatron', and MegapovXRS listens on port 9000. I would start the
server on caboose with "ssh -L 9123:localhost:9000 megapovXRS". This
opens a secure connection to the server, which is reachable by
connecting to megatron:9123. There is no need for any ports to be opened
on caboose besides the ssh port (22).
> Wolfgang
        Say we have 20 computers, and each task takes 100 minutes total
(per computer). 5 percent parse overhead means 5 minutes per computer is
spent parsing, and the remaining 95 rendering. That means that (20 cpus
* 5 minutes parsing/cpu = 100 ) cpu-minutes are spent parsing and (20
cpus * 95 minutes rendering/cpu = 1900 ) cpu-minutes are spent
rendering. So the complete overhead is 100 cpu-minutes out of the 2000
total, which is still 5%, not 100%. Remember, my patch only parses once
per machine, not once per tile :)
Also, we have a great program called RendView for anims, I'm aiming this
   program at accelerating high-quality stills :)
Thanks for your comments!
George
Date: 14 Aug 2004 09:03:32
Message: <411e0da3@news.povray.org>
Yes, okay, tunnelling over ssh is perfectly okay from the security point
of view. Especially if one can make sure that the POV server port is
not directly accessible from the internet...
You're certainly correct here. What I was calculating is: we could render
one complete image from the produced overhead. So, the overhead is
100% of the CPU cycles required to render one image.
So, if you have any suggestions / improvements or find bugs in this program,
please let me know.
Wolfgang
Date: 14 Aug 2004 10:10:13
Message: <411e1d45$1@news.povray.org>
Yeah, a render farm behind a firewall is the target I have in mind.
One subimage (tile), not one full-sized image :)
> please let me know.
> Wolfgang
I will, and I've wanted to check out your other cool patches as well.
I've just been so busy lately that I can't even work on my own stuff.
You've been super-productive lately. What's your secret? :)
Date: 14 Aug 2004 10:19:14
Message: <411e1f62@news.povray.org>
The one I could use is _not_ behind a firewall...
(But it's okay; binding the port to the 127.0.0.1 address and/or rejecting
connections with non-local sources will give a reasonable amount of
security.)
>> please let me know.
:) The "secret"? I'm not (busy with) studying ATM...
Wolfgang
