POV-Ray : Newsgroups : povray.unofficial.patches : [announce] JITC: Really fast POVRay FPU Server Time
26 Jul 2026 23:32:57 EDT (-0400)
  [announce] JITC: Really fast POVRay FPU (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: [announce] JITC: Really fast POVRay FPU
Date: 3 Aug 2004 18:39:20
Message: <41101418@news.povray.org>
In article <41101157$1@news.povray.org> , Nicolas Calimet
<pov### [at] freefr>  wrote:
>> You are aware that the official POV-Ray for Mac OS does include a
>> just-in-time compiler, aren't you?
>  It's very likely Wolfgang never tried the Mac OS version  ;-)
That is true, but using the core code SYS_FUNCTIONS macro family would have
made integration of a JIT compiler possible without hacking fnpovfpu.cpp.
In particular because they are documented to exist exactly for that purpose.
Would at least have made the whole implementation easier...
>  Sounds like a cool patch anyway !
Certainly!  On the other hand, calling gcc is overkill to make JIT
compilation possible :-)
    Thorsten
e-mail: tho### [at] trfde
Date: 3 Aug 2004 19:12:52
Message: <41101bf4$1@news.povray.org>
haven't tried it myself, but........ wow!
Date: 3 Aug 2004 19:14:53
Message: <41101c6d@news.povray.org>
otherwise encorporate the whole gcc thing in pov-ray. probably impossible
because of licensing issues.
Date: 4 Aug 2004 01:40:01
Message: <cepsnj$260$1@chho.imagico.de>
Wolfgang Wieser wrote:
> Hello all...
> the last two days, I wrote a patch for UNIX POVRay-3.6. to speed
> up user-functions as used e.g. in isosurfaces.
> Instead of interpreting the functions as done by the POV VM, this
> patch does just-in-time compilation of the function using the system
> compiler -- all that on-the-fly completely transparent for the user.
I think the work probably would have been better invested in
implementing an internal JIT compiler using the existing hooks as
Thorsten explained.  This would work on all x86 systems (and for Mac an
implementation already exists).
BTW your page does not say which optimizations you used for compiling
the patched version.  To me it seems quite unlikely that you always get
a speedup, there is also some overhead introduced by calling an external
library.
None the less an interesting idea of course.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 4 Aug 2004 05:29:29
Message: <4110ac78@news.povray.org>
Sounded interesting. I'll have a look at that.
Why didn't anybody put that on a publically available todo list? ;)
Well, this actually does not matter much. As pointed out on my home page,
I used the same compiler flags for the patched and the unpatched version
to make sure that the timings can be compared. And of course, I used the
best ones I know.
-O2 -ffast-math -march=athlon-xp -Wno-multichar -finline-functions
-funit-at-a-time -fno-rtti -mfpmath=387
> library.
This is correct. An external no-op function called via a pointer takes
about 10 times as long as an internal no-op function.
No-op function means:
  int foo(int x)  {  return(x);  }
But we should not forget that the huge swith-case construct in the main VM
takes some time, too. And this switch is effectively eliminated by JITC.
Wolfgang
Date: 4 Aug 2004 05:33:53
Message: <4110ad81@news.povray.org>
Thorsten Froehlich wrote:
> In article <41100d82@news.povray.org> , Wolfgang Wieser
> <wwi### [at] nospamgmxde>  wrote:
>> - The patch is Linux-specific. Probably Minor efford porting to other
Actually, I was not aware of that! I'll have a look.
Thanks for the hint.
Wolfgang
Date: 4 Aug 2004 05:41:49
Message: <7lb1h0pgvjkebk6e6ofo9a8hvdt5b07nt1@4ax.com>
On Wed, 04 Aug 2004 11:28:22 +0200, Wolfgang Wieser <wwi### [at] nospamgmxde>
I have considered this task for the future versions of MegaPOV thought I would
be veeeeery happy if you could be faster :-)
ABX
Date: 4 Aug 2004 05:48:20
Message: <4110b0e3@news.povray.org>
> have made integration of a JIT compiler possible without hacking
> fnpovfpu.cpp. In particular because they are documented to exist exactly
> for that purpose.
Well, "they are documented to..." is little exaggeration.
All I have found in the sources about these macros were a couple
of lines which described just what I already knew from reading the
code and one "cryptic" allusion that it can be used somehow to allow
JIT compilation. And that sounded to me like "we could some time
use that for JIT if we finally find the time to do so"...
> easier...
Okay... could somebody please make the POVRay-for-MacOS
source code available in a file format which I can read?
Or, alternatively, point me to a _working_ .sit unpacker for Linux.
The last time I was using the stuffit expander, I sweared to ban it from
my HD: First, I unpacked the archive which took quite long for just
some hundret kb. The binaries were okay but I saw that it messed up
the newlines in the text. So, I un-packed it again with changed flags
which really took _ages_ now and finally the text files were okay but
the binaries were corrupt. Oh dear...
I wonder how the Mac version does it...
Wolfgang
Date: 4 Aug 2004 05:59:25
Message: <4110b37c@news.povray.org>
> would be veeeeery happy if you could be faster :-)
IMO, in the present stage, this patch is not suitable for inclusion into
MegaPOV. Need to get rid of some unclean "hacks" first.
Or, maybe better, use the existing SYS_ macros if I manage to figure out
how to use them.
BTW, will the features from MLPov be included in the next MegaPOV version?
Wolfgang
Date: 4 Aug 2004 06:04:07
Message: <pqc1h0h2j6naajeiafc1btvvck2vfpl9pc@4ax.com>
On Wed, 04 Aug 2004 11:58:19 +0200, Wolfgang Wieser <wwi### [at] nospamgmxde>
Well... we try to be trendy ;-)
ABX
