POV-Ray : Newsgroups : povray.unofficial.patches : bicubic interpolation patch Server Time
28 Mar 2026 03:03:12 EDT (-0400)
  bicubic interpolation patch (Message 12 to 21 of 21)
Subject: Re: bicubic interpolation patch
Date: 11 Jun 2003 16:40:21
Message: <3ee793b4@news.povray.org>
Lutz-Peter Hooge wrote:
> 1) It is enabled with "interpolation 3"
> In image.h this is/was mapped to CUBIC_SPLINE, but wasn't implemented
What about introducing string names as alternatives to the numeric
values? Then one could prevent ambiguities and make the scene file more
readable. The numeric values can still be accepted, too.
Wolfgang
Date: 11 Jun 2003 19:50:11
Message: <3ee7c032@news.povray.org>
ABX <abx### [at] abxartpl> wrote:
> Isn't this already available in
> http://staff.aist.go.jp/r-suzuki/e/povray/iso/df_body.htm
  No, that's df3 interpolation. I talk about image map interpolation.
Date: 11 Jun 2003 23:40:01
Message: <web.3ee7f5f8d02fbf4518ccf4f70@news.povray.org>
>  Mipmapping is a technique to avoid these moire artifacts.
NO NO NO! Not mip mapping in POVRay! Mip mapping ruins the image. Whenever I
play any of the Quake-based games, I turn it off. I think things look a lot
better without it. I'd rather have the shimmering, than the blurriness.
Now, how about including Trilinear/Tricubic interpolation for use with voxel
objects?
Rohan _e_ii
Date: 12 Jun 2003 04:21:16
Message: <3ee837fc@news.povray.org>
Christopher James Huff <cja### [at] earthlinknet> wrote:
> But a direct implementation would be faster, right?
Of course.
> > But I think it is also possible to modify the matrix to get a sharper
> > image (with the tradeoff of getting more grid artifacts)
I experimented a bit with it. At least blur and sharpen is possible.
Lutz-Peter
Date: 12 Jun 2003 04:39:25
Message: <3ee83c3d@news.povray.org>
  Strange claim.
  Trilinear filtering is closer to the photographic phenomenon than the
plain bilinear filtering. In other words, it's more photorealistic.
  In the real world, when you scan a photograph (or take a photo with a
high-quality digital camera), one pixel will be the average of all the
colors inside the pyramid which goes through that pixel towards the scene.
This is exactly what trilinear filtering simulates: It averages all the
texture pixels which fall into this pyramid to get the pixel color.
  That is, if 40 of the texture pixels are inside that singe image pixel,
the average of all those 40 pixels is calculated there (as would happen
with a photograph).
  In regular bilinear filtering this does not happen. Instead of taking
into account all the 40 texture pixels, it takes 4. All the other 36
texture pixels are simply ignored.
  You can imagine that if the texture has very fine details, this causes
really bad moire effects.
Date: 12 Jun 2003 09:55:11
Message: <cjameshuff-178958.08465112062003@netplex.aussie.org>
In article <3ee7479b$1@news.povray.org>,
 Lutz-Peter Hooge <lpv### [at] gmxde> wrote:
> I don't think so. It would be correct for a reflection on a plane, but
> totally wrong for a reflection on a small sphere.
> To make it correct the 'width' of the ray would be needed, and to
> calculate (an approximation of) this, the curvature of the reflective/
> refractive surface at the intersection point would be needed.
You need to track the ray footprint, it's called differential ray
tracing. If I remember right, Ron Parker was talking about this a few
years ago, but never got it added to POV.
http://graphics.stanford.edu/papers/trd/
http://tag.povray.org/
Date: 12 Jun 2003 09:59:01
Message: <cjameshuff-CB2C62.08504112062003@netplex.aussie.org>
In article <web.3ee7f5f8d02fbf4518ccf4f70@news.povray.org>,
Mip-mapping is simply a way to more cheaply do supersampling. Small
details can not be represented by the pixels, so the details in each
pixel are blended together. The final image has more information, not
less, and is a more realistic representation of what the eye or a camera
would see. You might as well be ranting against the use of antialiasing.
Date: 12 Jun 2003 10:21:14
Message: <3EE88CD7.D5F83EC0@pacbell.net>
Both AA and MM have their advantages and drawbacks. Many a time I have
lamented the severe AA settings I had to use to get rid of strait edge
stair stepping only to see my textures and other geometry related details
suffer as a result.
Ken Tyler
Date: 15 Jun 2003 03:00:01
Message: <web.3eec180dd02fbf45337505cb0@news.povray.org>
>suffer as a result.
Hear Hear!
Rohan _e_ii
Date: 15 Jun 2003 04:38:30
Message: <3eec3086@news.povray.org>
The next version of my patch is available:
-interpolation matrix support
-some small modifications to pvengine.c and windows/config.h
 so it can be compiled with MingW.
<http://www.lutz-peter.hoogi.de/extern/lppov_usr.zip>
Win32 executable (MingW) and sample scenes
<http://www.lutz-peter.hoogi.de/extern/lppov_diff.zip>
Just the changed files needed to apply the patch to megapov 1.0
<http://www.lutz-peter.hoogi.de/extern/lppov_src.zip>
Full source code (minus support libs) including makefiles for
MingW (windows and windows console) and BCC 5.5
Lutz-Peter
