POV-Ray : Newsgroups : povray.unofficial.patches : POVMan 1.0 available Server Time
26 Jul 2026 23:34:52 EDT (-0400)
  POVMan 1.0 available (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: POVMan 1.0 available
Date: 20 May 2003 11:16:19
Message: <kihkcvkju72idga4coiui8g837dr3g3ufa@4ax.com>
On Tue, 20 May 2003 17:12:52 +0200, Christoph Hormann <chr### [at] gmxde>
wrote:
> > http://www.aetec.ee/fv/vkhomep.nsf/pages/POVMan2
> Nice but none of the download links seems to work here.
They do not have icons but download fine here.
ABX
Date: 20 May 2003 11:19:14
Message: <3ECA4772.ED4EDD1F@schunter.etc.tu-bs.de>
Strange.  I just tried with old Netscape 4.5 instead of the freshly
installed Mozilla 1.4 and it worked...
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 20 May 2003 13:49:40
Message: <3eca6ab1@news.povray.org>
Looks interesting, but can somebody explain to me the meaning of
"anisotropic scattering"? Well, I see the results, but what does it mean
exactly?
Thanks,
Andreas
http://www.render-zone.com
Date: 20 May 2003 16:02:06
Message: <3eca89be$1@news.povray.org>
> exactly?
Exactly?  I don't know exact definition, but more or less precisely it
means that reflections depend from surface orientation (as opposite to
isotropic). Unfortunately anisotropic examples are too dark to see
properly, I should really check my monitor setup...
Date: 26 May 2003 10:03:07
Message: <3ed21e9b@news.povray.org>
> can somebody explain to me the meaning of "anisotropic
> mean exactly?
http://news.povray.org/povray.general/28685/
Date: 26 May 2003 12:34:33
Message: <3ed24219@news.povray.org>
>> mean exactly?
Subject: Re: POVMan shader crash
Date: 29 May 2003 11:37:43
Message: <3ed62947$1@news.povray.org>
I've tried the SSS shaders (skin & FSSS) but there are almost no additional
effect. At least I was not able to get good results. However, during my
tests I was able to break rendering. When I change the objects from FSSS.POV
to a mesh2 I have, it usually breaks halfway through rendering:
"Shader array subscription error: index [1097011920] @176"
The rendering line, where it breaks, differs when I change the camera
location or the objects location. The mesh2 file that I use, uses 192 kb
memory. Well, despite these things, I value your work. Thank you!
Hugo
Date: 29 May 2003 13:30:06
Message: <3ed6439e@news.povray.org>
> memory.
192 kB? or is it MB? If it is small, then can you zip it along with
scene file and send me? Then I can find out, what is wrong there. This
error message shouldn't happen with FSSS shader, as this shader does not
use arrays, so I guess that memory is overwritten for some reason.
Date: 29 May 2003 14:36:50
Message: <3ed65342$1@news.povray.org>
It's 192 kB and I'll send you the file now.
Thanks,
Hugo
Date: 3 Jun 2003 12:44:59
Message: <3edcd08b@news.povray.org>
Updated shading language compiler to correct defect, which was found by
Hugo Asm. Source code and Windows binary are available in above
mentioned link.
Vahur
