POV-Ray : Newsgroups : povray.unofficial.patches : Direct Ray Tracing of Displacement Mapped Triangles Server Time
27 Jul 2026 00:51:50 EDT (-0400)
  Direct Ray Tracing of Displacement Mapped Triangles (Message 21 to 30 of 46)
Subject: Re: Direct Ray Tracing of Displacement Mapped Triangles
Date: 27 Apr 2003 12:43:40
Message: <cjameshuff-32D8F6.12451727042003@netplex.aussie.org>
In article <3eac0502@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
wrote:
> Okay, then please give me your advice: How should I set up the scene
> correctly? I'll do just that and we'll see if it looks nice.
> I want to animate a space ship which flies to a planet, along a valley
> in the topography and back up into space.
A sphere primitive for the planet. As you get closer, a mesh of the area
visible from the ship...a few hundred thousand triangles, maybe a
million. Once you get close to the canyon, switch to a high level of
detail mesh, the detail will probably require a million or so. Then back
through a medium LOD mesh (maybe the same as the one on incoming, maybe
different) and then switch to the sphere again. 2 or 3 meshes, none
having anything near 100 million triangles. You could set things up so
you have one bigger mesh with variable amounts of detail, highest in the
canyon...simpler but less efficient, but nowhere near as bad as your
idea of using a full-resolution mesh of an entire freaking planet.
*That* is just wasteful on current systems, even if you have the RAM for
it.
http://tag.povray.org/
Date: 27 Apr 2003 12:46:37
Message: <3EAC096C.4F3B0866@gmx.de>
I recently showed some samples of high detail rendering of the earth with
variable level of detail.  See:
Subject: rendering the earth (71k+68k)
Date: Tue, 01 Apr 2003 22:57:55 +0200
Newsgroups: povray.binaries.images
The data the renders are based on would result in ~3.5 billion triangles
when rendered as a whole with a mesh.
You can apply the same method (i.e. rendering a planetary body with an
isosurface defined by image maps, using higher resolution data for the
foreground part and blending with the lower resolution basis using
functions) to any other planet.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 27 Apr 2003 12:52:49
Message: <3EAC0A9F.AC61318@pacbell.net>
Christopher James Huff wrote:
> none having anything near 100 million triangles. You could set things up so
> it.
I'm rendering a scene right now that has over 130 million triangles and
the parse time for just the mesh include files is about 8 minutes on my
1 ghz machine. Add in texture computations, radiosity, area lighting,
the trace function and few other things, the total parse time is around
12 min. I would hate to do that for every frame of an animation...!
Ken Tyler
Date: 27 Apr 2003 14:31:01
Message: <3eac21e5@news.povray.org>
In article <3eabfca7@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
wrote:
> What about 1 byte per triangle?
> It only works for planets with 2 byte height info with the height
> info being the height difference to a sphere surface.
Why do you use a mesh if you want a height field???  You can already do what
you suggest easily with POV-Ray 3.5 using an isosurface and an image map
pattern!
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Apr 2003 14:49:53
Message: <3eac2650@news.povray.org>
Wolfgang Wieser <wwi### [at] gmxde> wrote:
> I was talking about culling as a technique to keep the mesh include file
> small. Because if you have a 100 million triangle mesh of a planet but
> only see 5% of them, you can try and do viewport culling -- otherwise
> the mesh will not fit into memory.
  There's no way of knowing which parts of the mesh will not be visible
in the final image other than raytracing the image.
  Raytracing is more versatile than scanline-rendering: In scanline rendering
when a triangle is facing away or if it's located outside the viewing port,
you know that it will not be visible. However, raytracing is not that simple.
A triangle can be far behind the camera, yet be visible in the final image.
Date: 27 Apr 2003 18:05:59
Message: <3eac5446@news.povray.org>
> 1 ghz machine.
I cannot imagine that.
I have to wait >4 minutes to get 1 million triangles parsed
on a 1.4 GHz box.
Furthermore, you must have more than 4Gb of virtual memory.
Wolfgang
Date: 27 Apr 2003 18:06:11
Message: <3eac5452@news.povray.org>
> From: Christoph Hormann <chr### [at] gmxde>
Looks pretty cool!
Did you "request" the data?
("Files denoted by double asterisks (**) are available upon request.
Please send an email to...")
Thanks, the isosurface image map sounds promising. 2 bytes per sample
is just great. Hope it does not take ages...
> using higher resolution data for the foreground part
okay...
"blending using functions"... What do you mean by that?
Wolfgang
Date: 27 Apr 2003 18:21:20
Message: <3EAC57A3.AE871C96@pacbell.net>
> > 1 ghz machine.
> on a 1.4 GHz box.
Guess I should have put a decimal place in there :) 1.30 million.
What's really going to blow you away is that I have 2000 copies
of those 1.3 million triangles in my scene. You do the math....
I have 1 gig of physical memory installed and a seperate partition I use
for the swap file that is 1.5 gigs in size. The current scene is using
a bit under 300 megs.
Ken Tyler
Date: 27 Apr 2003 18:25:47
Message: <3EAC58E7.7AE6A1B5@gmx.de>
No, they are available on the ftp server mentioned on that site:
ftp://gloria2-f.gsfc.nasa.gov/pub/stockli/
Well, you need a function to select whether the low or the high resolution
map is used at a certain position.  To avoid problems with the root finder
you will need to  create a smooth transit between the regions.
Date: 27 Apr 2003 18:32:20
Message: <3eac5a73@news.povray.org>
Ah, allright.
The meshes internally use refernece counting.
There is little overhead copying a mesh because they share the data.
Wolfgang
