POV-Ray : Newsgroups : povray.unofficial.patches : Direct Ray Tracing of Displacement Mapped Triangles Server Time
27 Jul 2026 02:29:36 EDT (-0400)
  Direct Ray Tracing of Displacement Mapped Triangles (Message 17 to 26 of 46)
Subject: Re: Direct Ray Tracing of Displacement Mapped Triangles
Date: 27 Apr 2003 05:20:19
Message: <3eaba0d3$1@news.povray.org>
In article <3eab03ee@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
wrote:
> Either smart "intelligent" mixed-resolution meshes with (at least
> primitive) viewport culling or a very fine mesh is required.
> OR, subdivision at render time.
> Anything else?
Culling is of little use for ray-tracing, it is a typical scanline render
acceleration technique.
However, I recall a paper (in ACM TOG iirc) about an optimized level of
detail algorithm for terrain modeling that was suitable for ray-tracing.
And I am sure somebody has already invented a method for fitting huge meshes
such that they can be used by ray-tracing - RAM to store meshes of whole
planets has _not_ been affordable or available for a long time after all.
And the need to store those meshes has existed for a much longer time!
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Apr 2003 11:52:08
Message: <3eabfca7@news.povray.org>
I was talking about culling as a technique to keep the mesh include file
small. Because if you have a 100 million triangle mesh of a planet but
only see 5% of them, you can try and do viewport culling -- otherwise
the mesh will not fit into memory.
>meshes such that they can be used by ray-tracing
What about 1 byte per triangle?
It only works for planets with 2 byte height info with the height
info being the height difference to a sphere surface.
If I have time, maybe I'll implement that.
The general problem is that each vertex uses up at least 3*4 bytes.
The only way I could imagine saving space is a better triangle-to-vertex
mapping.
Or, in-memory compression...
Yes, one could do in-memory compression when using a hierarchy.
It will probably even be faster than using swap memory for the mesh.
Wolfgang
Date: 27 Apr 2003 12:16:18
Message: <cjameshuff-4BCEBD.12175427042003@netplex.aussie.org>
In article <3eabfca7@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
That's still holding 5 million triangles, and breaking things like
reflections. You don't seem to get it...that is an example of setting up
the scene wrong. You are using a much higher resolution mesh than you
need.
http://tag.povray.org/
Date: 27 Apr 2003 12:27:47
Message: <3eac0502@news.povray.org>
> need.
Okay, then please give me your advice: How should I set up the scene
correctly? I'll do just that and we'll see if it looks nice.
I want to animate a space ship which flies to a planet, along a valley
in the topography and back up into space.
Wolfgang
Date: 27 Apr 2003 12:43:40
Message: <cjameshuff-32D8F6.12451727042003@netplex.aussie.org>
In article <3eac0502@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
A sphere primitive for the planet. As you get closer, a mesh of the area
visible from the ship...a few hundred thousand triangles, maybe a
million. Once you get close to the canyon, switch to a high level of
detail mesh, the detail will probably require a million or so. Then back
through a medium LOD mesh (maybe the same as the one on incoming, maybe
different) and then switch to the sphere again. 2 or 3 meshes, none
having anything near 100 million triangles. You could set things up so
you have one bigger mesh with variable amounts of detail, highest in the
canyon...simpler but less efficient, but nowhere near as bad as your
idea of using a full-resolution mesh of an entire freaking planet.
*That* is just wasteful on current systems, even if you have the RAM for
it.
Date: 27 Apr 2003 12:46:37
Message: <3EAC096C.4F3B0866@gmx.de>
I recently showed some samples of high detail rendering of the earth with
variable level of detail.  See:
Subject: rendering the earth (71k+68k)
Date: Tue, 01 Apr 2003 22:57:55 +0200
Newsgroups: povray.binaries.images
The data the renders are based on would result in ~3.5 billion triangles
when rendered as a whole with a mesh.
You can apply the same method (i.e. rendering a planetary body with an
isosurface defined by image maps, using higher resolution data for the
foreground part and blending with the lower resolution basis using
functions) to any other planet.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 27 Apr 2003 12:52:49
Message: <3EAC0A9F.AC61318@pacbell.net>
> none having anything near 100 million triangles. You could set things up so
> it.
I'm rendering a scene right now that has over 130 million triangles and
the parse time for just the mesh include files is about 8 minutes on my
1 ghz machine. Add in texture computations, radiosity, area lighting,
the trace function and few other things, the total parse time is around
12 min. I would hate to do that for every frame of an animation...!
Ken Tyler
Date: 27 Apr 2003 14:31:01
Message: <3eac21e5@news.povray.org>
In article <3eabfca7@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
Why do you use a mesh if you want a height field???  You can already do what
you suggest easily with POV-Ray 3.5 using an isosurface and an image map
pattern!
    Thorsten
Date: 27 Apr 2003 14:49:53
Message: <3eac2650@news.povray.org>
  There's no way of knowing which parts of the mesh will not be visible
in the final image other than raytracing the image.
  Raytracing is more versatile than scanline-rendering: In scanline rendering
when a triangle is facing away or if it's located outside the viewing port,
you know that it will not be visible. However, raytracing is not that simple.
A triangle can be far behind the camera, yet be visible in the final image.
Date: 27 Apr 2003 18:05:59
Message: <3eac5446@news.povray.org>
> 1 ghz machine.
I cannot imagine that.
I have to wait >4 minutes to get 1 million triangles parsed
on a 1.4 GHz box.
Furthermore, you must have more than 4Gb of virtual memory.
Wolfgang
