POV-Ray : Newsgroups : povray.unofficial.patches : Direct Ray Tracing of Displacement Mapped Triangles Server Time
26 Jul 2026 23:19:09 EDT (-0400)
  Direct Ray Tracing of Displacement Mapped Triangles (Message 11 to 20 of 46)
Subject: Re: Direct Ray Tracing of Displacement Mapped Triangles
Date: 26 Apr 2003 17:01:15
Message: <3eaaf39b$1@news.povray.org>
In article <3eaa7ff7@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
wrote:
>> Well, then you better get system with a 64 bit processor,
> Oh, have one for me?
Sure, it costs only about 400 Euros more than an Aldi PC ;-)
<http://store.sun.com/catalog/doc/BrowsePage.jhtml?cid=85825&parentId=48612>
> But, I agree: The fact that a genuine mesh does not fit into RAM is
> not a POVRay bug because I see little chance to significantly reduce
> genuine mesh RAM consumption (after looking at the POV code).
Indeed, there is little that can be done about it.  And it already uses
"only" 32-bit floats...
    Thorsten
Date: 26 Apr 2003 17:35:25
Message: <3eaafb9d@news.povray.org>
Christopher James Huff wrote:
> In article <3eaadd08@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
> wrote:
> This seems to be the main advantage. Subdividing and displacing a big
> mesh could take a lot of CPU time, and limiting it to the needed areas
> would not be easy, so you would store more triangles than necessary. My
> main point is that memory use seems to be more of a side benefit, if it
> really can give a speed benefit. (time/CPU is much more costly than
> memory or storage)
There has to be a reason why the reyes algorithm is still used ;-)
The problem is that if you hit a memory limit there often is not much
you can do about it besides buying more memory, with time/CPU you can at
least wait. And it's not only the geometry that has big memory
requirements but also radiosity, photon mapping, etc..
Date: 26 Apr 2003 17:50:49
Message: <3eaaff38@news.povray.org>
:) Nice, but...
>The Sun Blade[tm] 150 workstation is an affordable, full-featured, 64-bit
>workstation with a 550/650-MHz UltraSPARC[R] IIi processor, up to 2 GB of
>memory
Oh, just up to 2 GB of RAM?
The issue was to be able to use more than 4 GB...
Wolfgang
Date: 26 Apr 2003 18:10:55
Message: <3eab03ee@news.povray.org>
>> Just tell my why I should use "intelligence" doing complicated
>> viewport and culling calculations (think of animations) which require
>> a separate mesh include file for each frame if the problem could be
>> delt with in an easier and (as I think) more elegant way?
> I never mentioned viewport calculations or culling. It doesn't require
> huge amounts of work...just don't use high resolution meshes where low
> res meshes are adequate.
The alternative is to use 100 million triangles.
95% will be useless but the foreground needs needs the fine grid.
Either smart "intelligent" mixed-resolution meshes with (at least
primitive) viewport culling or a very fine mesh is required.
OR, subdivision at render time.
Anything else?
>> > A binary mesh format would make loading
>> > high-res meshes faster.
>> ...and smaller on HD.
> Really, who cares about file size? It is only an issue when transferring
> files. I view it as simply a side effect of using a format more
> convenient for fast loading.
When rendering films, file size gets interesting, especially if you
need a separate mesh for each frame. And when rendering the film in
a distributed environment the issue is transferring the meshes.
But that's not the major issue we're talking about here.
>>   This means, if you use a very deep scene (fly along a valley),
>>   it would produce nice scenery from a low/med-resolution mesh
>>   with constant grid size.
> Which could be done just as well before rendering.
Which results in a 100 million triangle mesh.
Or requires some "intelligent" mixed-resolution mesh and triangle culling.
AND it requires knowledge of the camera position which means that a
separate mesh is needed for each frame.
Oh dear... we're back at the beginning.
I don't know if you never tried to put up a POV camera in a topography
mesh valley and looked at all the ugly triangles in the foreground.
Only solution (without patching POVRay) I see is doing some really
non-trivial calculations on the input topography data extracting a
mesh with fine grid in foreground and larger grid in the background.
Wolfgang
Date: 26 Apr 2003 19:11:32
Message: <cjameshuff-49BC15.19124526042003@netplex.aussie.org>
In article <3eaafb9d@news.povray.org>,
Not with raytracing. As far as I know, Reyes is limited to scanline only.
http://tag.povray.org/
Date: 27 Apr 2003 05:10:34
Message: <3eab9e8a@news.povray.org>
In article <3eaaff38@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
Since when is a system limited by the amount of physical memory? - It has a
40 GB harddisk in the standard configuration, so you can use 39 GB as swap
space!  Or do you expect they allow you to put 4000 Euros worth of RAM into
a entry level system? ;-)
If you want more RAM and have the necessary pocket money to spend, I would
recommend one of these systems:
<http://www-132.ibm.com/content/home/store_IBMPublicUSA/en_US/eServer/pSerie
s/pSeries.html>
<http://store.sun.com/catalog/doc/BrowsePage.jhtml?cid=48620&parentId=26829>
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Apr 2003 05:20:19
Message: <3eaba0d3$1@news.povray.org>
In article <3eab03ee@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
> Anything else?
Culling is of little use for ray-tracing, it is a typical scanline render
acceleration technique.
However, I recall a paper (in ACM TOG iirc) about an optimized level of
detail algorithm for terrain modeling that was suitable for ray-tracing.
And I am sure somebody has already invented a method for fitting huge meshes
such that they can be used by ray-tracing - RAM to store meshes of whole
planets has _not_ been affordable or available for a long time after all.
And the need to store those meshes has existed for a much longer time!
    Thorsten
Date: 27 Apr 2003 11:52:08
Message: <3eabfca7@news.povray.org>
I was talking about culling as a technique to keep the mesh include file
small. Because if you have a 100 million triangle mesh of a planet but
only see 5% of them, you can try and do viewport culling -- otherwise
the mesh will not fit into memory.
>meshes such that they can be used by ray-tracing
What about 1 byte per triangle?
It only works for planets with 2 byte height info with the height
info being the height difference to a sphere surface.
If I have time, maybe I'll implement that.
The general problem is that each vertex uses up at least 3*4 bytes.
The only way I could imagine saving space is a better triangle-to-vertex
mapping.
Or, in-memory compression...
Yes, one could do in-memory compression when using a hierarchy.
It will probably even be faster than using swap memory for the mesh.
Wolfgang
Date: 27 Apr 2003 12:16:18
Message: <cjameshuff-4BCEBD.12175427042003@netplex.aussie.org>
In article <3eabfca7@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
That's still holding 5 million triangles, and breaking things like
reflections. You don't seem to get it...that is an example of setting up
the scene wrong. You are using a much higher resolution mesh than you
need.
Date: 27 Apr 2003 12:27:47
Message: <3eac0502@news.povray.org>
> need.
Okay, then please give me your advice: How should I set up the scene
correctly? I'll do just that and we'll see if it looks nice.
I want to animate a space ship which flies to a planet, along a valley
in the topography and back up into space.
Wolfgang
