POV-Ray : Newsgroups : povray.unofficial.patches : Importance sampling of phong brdf Server Time
17 May 2026 01:03:26 EDT (-0400)
  Importance sampling of phong brdf (Message 1 to 10 of 15)
Subject: Importance sampling of phong brdf
Date: 14 Apr 2003 14:12:51
Message: <3e9afa23$1@news.povray.org>
Hello,
I've tried to write a patch to do importance sampling of the phong brdf (the
modified phong brdf actually). The patch uses the phong and phong_size of
finish{} to compute highlights even in radiosity lighted only parts of the
image (If there are real light sources then the highlight is the phong
contribution of those lights source + the contribution of the sampled phong
brdf)
Some images : http://195.221.122.126/radphong/rad_phong.html
M
Subject: Re: Importance sampling of phong brdf
Date: 14 Apr 2003 14:29:22
Message: <Xns935DD0DEA9BD2seed7@povray.org>
> brdf (the modified phong brdf actually).
From the images I'd say you succeeded. This looks very good!
Ingo
Date: 14 Apr 2003 15:18:23
Message: <3E9B097E.E468B245@gmx.de>
Mael wrote:
> Hello,
> brdf)
That looks very interesting, i have some troubles understanding how it
works though.  The phong model needs the light direction, how do you
determine it with radiosity lighting?
Concerning practical usage - it would be interesting to see a version with
reflective finish in comparison (which will also show highlights with
hdri).
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 14 Apr 2003 16:14:38
Message: <3e9b16ae@news.povray.org>
This sampling is independent of the radiosity inter-diffuse stuff. It occurs
at each intersection point if there is a non zero phong in the finish. An
adaptive number (calculated with phong_size and a global parameter rad_phong
(a kind of density)) of rays are shooted near the direction = incident ray
reflected (samples rays are choosed with an adequate probability density
function -see the images- that's why it's called importance sampling) and
light is gathered. Yes that sounds cpu consuming - and it is, but for high
phong_size the number of samples can be low.
> hdri).
you mean a comparison with finish with a small amount of blurred reflection
(this is what i've used in my irtc image..) ?
for high phong_size (small blur) the results should look quite similar, and
for lower phong_size (bigger blur) the uniform distribution of the sampling
resulting from the blurred reflection will probably introduce some
differences (and blurred reflections are more annoying to declare than
phong+phong_size ;)
M
Date: 14 Apr 2003 17:59:38
Message: <3e9b2f4a$1@news.povray.org>
Good!
Good way of faking blurred reflection too.
Date: 14 Apr 2003 19:58:01
Message: <3e9b4b09@news.povray.org>
"Mael" <mae### [at] hotmailcom> ha scritto nel messaggio
news:3e9afa23$1@news.povray.org...
> Hello,
(the
phong
> brdf)
> M
Hi Mael,
it's wonderful !
Where is the new version?
I want to download.
Thanks.
Ceggi.
Date: 15 Apr 2003 03:27:32
Message: <k1dn9vgjlrtc5lff6utgsmlaj5al99b0tv@4ax.com>
Brilliant!
(Or should I say, "Phongey!")
Peter Popov ICQ : 15002700
Date: 15 Apr 2003 10:44:36
Message: <3e9c1ad4@news.povray.org>
Mael, this is great! Thanks for all your ongoing contributions :)
George
"Mael" <mae### [at] hotmailcom> wrote in message
> Hello,
(the
phong
> brdf)
> M
Date: 15 Apr 2003 11:22:57
Message: <3E9C23D1.72C4B9C9@gmx.de>
Very clever.
But i guess it is really quite awfully slow.  It could be worth
considering some caching function but that will probably be less helpful
than with diffuse radiosity since the result varies much stronger with
position and surface normal.
How does it look with very low sample counts? Does it look mostly noisy or
are there other artefacts?
Date: 15 Apr 2003 13:47:20
Message: <3e9c45a8@news.povray.org>
> Very clever.
ehhm, to be honest this is really not rocket science and the patch is ~ 50
lines of C
well as slow as blurred reflection, or things like this. I would say slow
but not awfully slow :)
> It could be worth
I've not tried but i'm pretty sure caching is useless considering, as you
noted, the strong effect of normal and incident ray direction. A way to make
it faster would be to find another brdf which don't require a pow() call for
the distribution as it is quite cpu expensive (there are papers about such
brdf, see for example
http://dept-info.labri.u-bordeaux.fr/~schlick/DOC/eur2.html)
in the current implementation the position of samples is fixed so low sample
counts may give artifacts. I think adding a random rotation of the samples
would result in noise.
M
