POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOV 1.0 bug ? Server Time
27 Jul 2026 00:51:35 EDT (-0400)
  MegaPOV 1.0 bug ? (Message 11 to 17 of 17)
Subject: Re: MegaPOV 1.0 bug ?
Date: 2 Jan 2003 13:14:59
Message: <3e1481a3@news.povray.org>
: The bug is smaller than I expected, it only wont work if I select a part with the
bottom line included !
"part-included" should I say.. O__o
Pierrick
http://pierrickz.free.fr/
Date: 3 Jan 2003 05:03:59
Message: <sqna1vglp5q945ii9hi46oi3qu7b6iq83i@4ax.com>
On Thu, 2 Jan 2003 19:13:44 +0100, "Pierrick" <nos### [at] hotmailcom>
So... it can be connected with End_Row addition by Micha Riser. Would you like
to test your selection rendering with options in command box instead of
selecting in rendering window ?
ABX
Date: 3 Jan 2003 09:30:07
Message: <web.3e159d22f0e8480d5020b6e80@news.povray.org>
ABX,
I think I am the culprit here, not Micha. I am on the road at the moment...
But, thinking about this off the top of my head, my guess would be the
windows GUI is using precentages to specify the window to be rendered.
Specifically it might be specifying 100% (1.0) or more for the end row if
the window includes the last row. If so, I think the quick fix would be to
drop the end row 'argument' from the windows gui any time it is >= 1.0 as
POV-Ray defaults to 100% if +ER or +EC is not specified. I admit without
source code in front of me, I am doing some guess work here...
I'll try and download the windows source off the POV-Ray download page later
today and take a look...
Regards, Bill P.
>ABX
Date: 3 Jan 2003 09:37:12
Message: <0u7b1v4mlm3ubkbsfojcj3tdv7uk7608k1@4ax.com>
On Fri,  3 Jan 2003 09:24:34 EST, "William Pokorny" <pokorny_attglobal_net>
wrote:
> ABX,
Yes, sorry, my memory failed becouse of other tasks ...
Good luck :-)
ABX
Date: 5 Jan 2003 13:25:04
Message: <web.3e1876f9f0e8480d5020b6e80@news.povray.org>
OK, I got some time today to look at this and here are my thoughts
and proposed changes. I am set up with a compiler only in the unix
environment. Further I won't be home for another 6 days so my
apologies for any typos.
The work around for the current Mega-POV 1.0 windows release
is to shift drag the window, copy to the command line and then
remove the string "+er1.000000" from the end of the text appended
to the command line BEFORE you start the render. Or of course
you can avoid including the last line in your partial renders....
First, on looking over this code again, I think we should add the
same +ER fix to the +EC flag. In povmsrec.cpp we should change:
   if(POVMSUtil_GetFloat(msg, kPOVAttrib_EndColumn, &f) == 0)
      if(f > 0.0 && f <= 1.0)
         opts.Last_Column = -1;
         opts.Last_Column_Percent = f;
      else
         opts.Last_Column = (int)f;
to:
      if(f > 0.0 && f
                             #ifdef END_ROW_1_PATCH
                             #else
                             #endif
                             1.0)
      else
To fix the windows partial render trouble when the last row
or column is included, in pvengine.c we should change:
sprintf (RegionStr," +sc%f +sr%f +ec%f +er%f",
          (float) x1 / (render_width - 1),
          (float) y1 / (render_height - 1),
          (float) x2 / (render_width - 1),
          (float) y2 / (render_height - 1)) ;
to:
sprintf (RegionStr," +sc%f +sr%f  %s %s",
          (((float) x2 / (render_width - 1)) < 1.0) ?
sprintf("+ec%f",((float) x2 / (render_width - 1))) : "",
          (((float) y2 / (render_height - 1)) < 1.0) ? sprintf("+er%f",
((float) y2 / (render_height - 1))) : "") ;
And the same change should be made to the sprintf just below which
begins with:
sprintf (TempRegionStr,
I think this all will get us to the place where the end row fix, fixes
what it is supposed to fix without breaking the ability to do partial
renders from the windows GUI.
Regards, Bill P.
>wrote:
>> ABX,
>Good luck :-)
>ABX
Date: 7 Jan 2003 08:47:31
Message: <85ml1vglc7tqdunruqjki2414vjnthjaqu@4ax.com>
On Sun,  5 Jan 2003 13:20:45 EST, "William Pokorny" <pokorny_attglobal_net>
Yes, this seems necessary to fix it either, but then I wonder about what did
you mean in the last sentence of
http://news.povray.org/3D75154C.9DCE81AF%40attglobal.net ?
After minor fixes in your code it works and will be fixed.
ABX
Date: 7 Jan 2003 09:40:03
Message: <web.3e1ae5c0f0e8480d5020b6e80@news.povray.org>
I had convinced myself at the time I wrote it that +EC1 was working. Perhaps
a typo when I tried "+SC1 +EC1" or - who knows. I was certainly confused at
the time because "+SC1 +EC1" does not render just the first column of the
image in any POV release I have with me.
Thanks ABX.
