POV-Ray : Newsgroups : povray.unofficial.patches : pvmpovray35 release Server Time
27 Jul 2026 00:51:36 EDT (-0400)
  pvmpovray35 release (Message 11 to 14 of 14)
Subject: Re: pvmpovray35 release
Date: 12 Dec 2002 10:00:23
Message: <3DF8A486.A9637129@gmx.de>
Warp wrote:
>   One problem is that it takes almost 6 minutes to parse benchmark.pov
> regardless of the amount of computers, so the time will never go under
> that no matter how many sparcs I use (except if I use faster sparcs,
> of course).
Distributing the photons should be quite possible theoretically, of course
it would be quite some additional work to implement.
Last updated 07 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 12 Dec 2002 12:18:04
Message: <3df8c4cc@news.povray.org>
Maybe in C, in C++ your types and constants should have the scope of the
class or namespace they are defined in, thus only cluttering that namespace,
if you can even consider that clutter.
Mike
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3df8585a$1@news.povray.org...
> In article <3df7e833@news.povray.org> , "Apache"
> <apa### [at] yahoocom> wrote:
> > Peopla at university taught me this very thing: put types and constants
in
> > header file.
> Which is completely wrong:  Only put types and constants used in more than
> one source file into a header file.  Otherwise you just clutter the
> namespace, regardless of the language being used.
>     Thorsten
> ____________________________________________________
> Thorsten Froehlich, Duisburg, Germany
> e-mail: tho### [at] trfde
> Visit POV-Ray on the web: http://mac.povray.org
Date: 13 Dec 2002 03:52:54
Message: <3df99fe6@news.povray.org>
  Naturally, but even in C++ the same principle holds: Types and constants
used only inside the module should be defined in the .cpp file, not the
header file.
  Of course the exception to this in C++ are the definitions in the private
part of the (public) class, which must be declared in the same place as the
class itself (ie. in the header). Even though this is cumbersome, the reason
for this is purely technical: The compiler must know the size of the class
everywhere it's used, and member variables inside the class need to be known
in order to know this size (regardless of where they are inside the class).
  One thing which I don't like and don't agree is that in C++ you also must
declare all private methods and types in the same class definition as well.
There's no technical nor syntactical need for this. It would be perfectly
possible to declare private methods and types separately from the class
definition itself.
  For example, I don't see any problem in supporting something like this:
(In file.hh)
class Whatever
 public:
    void f();
 private:
    int a;
(In file.cc)
void Whatever::f() // Implementation of the public method f()
typedef double Whatever::D; // A private type declaration
void Whatever::g() // Declaration and implementation of a private method g()
Date: 13 Dec 2002 18:09:20
Message: <3dfa68a0$1@news.povray.org>
I changed classes :-)
