POV-Ray : Newsgroups : povray.unofficial.patches : Density_file extention patch: a patch for 3D data Server Time
6 Oct 2024 10:51:38 EDT (-0400)
  Density_file extention patch: a patch for 3D data (Message 1 to 10 of 18)
Subject: Density_file extention patch: a patch for 3D data
Date: 29 Aug 2002 04:05:58
Message: <3d6dd5e6@news.povray.org>
As I promised in the message
  http://news.povray.org/3be6713e$1@news.povray.org,
I've uploaded a patch for 3D data at
  http://staff.aist.go.jp/r-suzuki/e/povray/iso/df_body.htm
Comments and suggestions are welcome.
R. Suzuki
Subject: Re: Density_file extention patch: a patch for 3D data
Date: 29 Aug 2002 04:22:01
Message: <n8mrmusor79q44peol7b0d4f5jse5n4fjf@4ax.com>
On Thu, 29 Aug 2002 17:07:54 +0900, "R. Suzuki" <r-s### [at] aistgojp> wrote:
I will add this to http://abx.art.pl/pov/patches/patches.php (with all patches
announced recently) as soon as possible.
ABX
Date: 29 Aug 2002 04:46:28
Message: <3D6DDF64.1627DB33@gmx.de>
Looks interesting and useful, the data file format seems somewhat strange
though, as i understand it you always have two files, the header and the
actual data file.  Wouldn't it be better to merge them, like in the ppm
image file format for example?
A macro for generating a density file from a function (using the file
writing routines) would be a useful addition.
BTW it would be very helpful if you could separate you changes with
'#ifdef DENSITY_PATCH' otherwise one will have to do a lot of searching to
find what you have changed.
Date: 29 Aug 2002 05:52:22
Message: <Xns9279797CC5021seed7@povray.org>
Don't think so, it would mean that one has to convert datasets to a format
readable by POV-Ray, now one can just "describe" the way the dataset is
put together in the sepparate header file and use it staight away.
Ingo
Date: 29 Aug 2002 05:56:24
Message: <3d6defc8@news.povray.org>
news:3D6DDF64.1627DB33@gmx.de...
It also allows one file if the filename of the data is not specified.
In this case, the data should be after the [data] line of the df file.
It would be useful.
OK.  I will add it in the next revision.
R. Suzuki
Date: 29 Aug 2002 06:10:06
Message: <6isrmu4o6nvn8hlcgel4vlg7mu2k74a6sb@4ax.com>
On Thu, 29 Aug 2002 18:58:20 +0900, "R. Suzuki" <r-s### [at] aistgojp> wrote:
> It would be useful.
That's what I tried for "really smooth" proximity/blur pattern: sample space,
write samples to file, load it and interpolate between.
ABX
Date: 29 Aug 2002 06:12:47
Message: <3D6DF39E.65DE83E@gmx.de>
I saw that after looking at the source code.  Some more documentation
about the header fields would be good, what does 'cyclic' mean for
example?
Date: 29 Aug 2002 06:13:02
Message: <gmsrmusgkrjpiajf5bk6ej8hnmntbbddvv@4ax.com>
On Thu, 29 Aug 2002 10:46:28 +0200, Christoph Hormann <chr### [at] gmxde>
What about
  function 100,100,100{...}
ABX
Date: 29 Aug 2002 06:17:38
Message: <3D6DF4C1.6381E31F@gmx.de>
> What about
Hmm, interesting, you mean for use in:
#declare DATA3D2= function {
  pattern{
    density_file function 100,100,100{...}
    interpolate 2
But a 'save_file' option would be good (for the 2D version this would be
useful too BTW)
Date: 29 Aug 2002 06:21:16
Message: <3d6df59c$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:n8mrmusor79q44peol7b0d4f5jse5n4fjf@4ax.com...
Thanks.  But I am still working on the coding.
The [Endian] option does not work at present.
And binary data formats in various platform should be added.
R. Suzuki
