POV-Ray : Newsgroups : povray.unofficial.patches : Mouse3 iso problem Server Time
22 Mar 2026 14:41:31 EDT (-0400)
  Mouse3 iso problem (Message 1 to 9 of 9)
Subject: Mouse3 iso problem
Date: 10 Jun 2001 18:54:03
Message: <3b23fa8b@news.povray.org>
Re Mouse3 final(ish) in pbi
The mousetrap base in pbi is a box{} unioned with the metalwork. If I
replace it with an isosurface as shown below, the base vanishes in the
scene leaving the wire stuff. The union is OK on its own, or with the
isosurface floor removed. Moving the invisible base around the scene,
it will sometimes show a section of the lower surface "stuck" to the
floor. Neither syntax shown below seems to make a difference. All my
INCludes use #local except where the objects need to be #declared.
Can anyone suggest what I should be looking for?
I'm using DOS version megapov 0.7, Win98SE, celeron 500, and the scene
takes 74MB out of 128.
// Extract from my BASE.INC
#local SizeB = <2.8,0.15,1.5>;
#declare Base =
// isosurface{ function{ "rounded_box", <0.02, SizeB.x, SizeB.y,
SizeB.z> }
//             contained_by{ box{ -SizeB*1.05, SizeB*1.05 } }
isosurface{ function{ "rounded_box", <0.02>}
            contained_by{ box{ -SizeB, SizeB } }
            texture{ TWood13 }
            translate <0,-SizeB.y,0>
/*   // No problems with this.
box{ -1, 1 scale SizeB
    texture{ TWood13 }
Alf
http://www.peake42.freeserve.co.uk/
http://ourworld.compuserve.com/homepages/Alf_Peake/
gw3### [at] thersgbnet
Subject: Re: Mouse3 iso problem
Date: 11 Jun 2001 04:24:22
Message: <3b248036$1@news.povray.org>
In article <3b23fa8b@news.povray.org> , "Alf Peake"
The max_gradient documentation.
    Thorsten
Date: 11 Jun 2001 11:10:47
Message: <3b24df77@news.povray.org>
----- Original Message -----
From: "Alf Peake" <alf### [at] peake42freeservecouk>
[snip]
Just noticed my stats with the base as the *only* isosurface.
Base visible, complete trap OK, most other objects removed:
Ray->Shape Intersection          Tests       Succeeded  Percentage
Isosurface Bound                 15811            7873     49.79
Isosurface                        7703            7653     99.35
Isosurface Cache                  7580               0      0.00
Base missing, most permutations of objects in scene:
Isosurface Bound                 13618            7750     56.91
Isosurface                        7744               0      0.00
Isosurface Cache                  7743            7743    100.00
Alf
Date: 11 Jun 2001 19:09:00
Message: <3b254f8c$1@news.povray.org>
Yes, I did read megapov_07.html and played with the isosurface values
without much luck. For an input between 0.01 and 10, stats reports
eval max_gradient between 0.806 and 0.999
Later...
I have a bad feeling. I can alter the mousetrap base by changing
camera settings or declareing an unused texture. Pigment{checker}
within the iso can sometimes be bad but pigment{Red} will be OK.
I'm trying to make a simple file which shows the problem but it may
take a coupla days as I have around 15 INCs to play with :(
Alf
Date: 12 Jun 2001 10:02:44
Message: <3b262104$1@news.povray.org>
In article <3b254f8c$1@news.povray.org> , "Alf Peake"
You should use "eval" to find the best max_gradient.  Try method 2 with a
max_gradient of 1000 or more and see if it goes away...
     Thorsten
Date: 12 Jun 2001 19:06:55
Message: <3b26a08f@news.povray.org>
I've uploaded "isosurface problem" to p.b.s-f
Hopefully I've included all needed pieces. Ever tried to untangle a
ball of string? Includes were involved that I had forgotten about!
Running MAIN.POV should give a half-base image unless the error is
specific to my system.
Alf
Date: 12 Jun 2001 19:42:42
Message: <3b26a8f2@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3b262104$1@news.povray.org...
values
with a
Never occured to go that high. Tried with 10000, no luck.
Alf
Date: 12 Jun 2001 21:10:30
Message: <3b26bd86@news.povray.org>
Your files show it correctly (using Windows, don't know about with DOS).
Maybe you could try putting #version unofficial MegaPov 0.7; at the end of
your base.inc to be certain it takes.  There was some talk of some such
thing long ago anyhow.
Bob H.
"Alf Peake" <alf### [at] peake42freeservecouk> wrote in message
news:3b26a08f@news.povray.org...
Date: 13 Jun 2001 19:56:22
Message: <3b27fda6@news.povray.org>
"Bob H." <omn### [at] msncom> wrote in message
news:3b26bd86@news.povray.org...
DOS).
OK. Thanks for that. As you can see from the jpegs I have no problem
getting it to mis-behave. Guess I'll try an old 486 box here that
doesn't know about pov or Windows, just in case there's a file in my
path I've not noticed. Pov.ini, colors.inc and megapov7.exe should be
enuf.
end of
such
I'll try that. Peculiar thing tho', the floor in my p.b.i scene uses
rounded_box and previously I've used it to make floor patterns with
2:1 wood blocks. No problems noticed there.
Alf
