POV-Ray : Newsgroups : povray.unofficial.patches : Bigtime MegaPov 0.7 CRASH! Server Time
27 Jul 2026 05:55:32 EDT (-0400)
  Bigtime MegaPov 0.7 CRASH! (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Bigtime MegaPov 0.7 CRASH!
Date: 16 May 2001 14:49:37
Message: <3b02cbc1@news.povray.org>
I'd be real interested in hearing of the result of that myself, in fact many
other people would probably be listening in too.
Bob H.
"Gail Shaw" <gsh### [at] monotixcoza> wrote in message
news:3b028e70@news.povray.org...
> I'll try it on a pentium2 and an athlon, see if it crashes on either.
Date: 16 May 2001 14:56:38
Message: <3b02cd66@news.povray.org>
Well, the system hits a peak at about 107 F., so I don't think that's it. I
was prepared to put a new 1.4Ghz proc. in when they are here, so I have
adequate cooling (I think).
I think Thorsten probably has the best answer, though I do not look forward
to a re-format reinstall. Gail, the entire scene comes in over 10Megs, so
I'll see if I can narrow it down. I will try to reinstall Windows on top of
what I have and see how that goes.
Additionally, I have a small file that is causing the official Pov 3.1g to
crash. It renders inside of MegaPov, which has me perplexed. I have been
away from rendering for a few months, so this has me scratching my head and
wondering if I have done something stupid. I will post the code (for the
latest scene) in binaries.scene-files and see if anyone else has this
problem.
If, it renders fine, we will know that it is my system, right? :)
TIA,
Grim
Date: 16 May 2001 15:00:02
Message: <3b02ce32$1@news.povray.org>
I'll get right on sorting out which files are needed, and see if I can limit
the models, etc. It may take a little while, but I'll get it off to you.
(SIGH) O.T., but I am going through a nasty divorce right now, and my
spirits are down. The ex is pestering me with harassing phone calls and
setting my nerves on edge. I'm not happy.
At least I have you all! :)
Grim
Date: 16 May 2001 15:09:06
Message: <3b02d052$1@news.povray.org>
Oops! :)
MBProbe gives a different picture then the BIOS reported.
The MB usually sits at about 101F, the CPU at about 89F, and the system (VIA
chipset) at about 75F. It doesn't seem critical to me, but what do I know?
Grim
Date: 16 May 2001 15:10:50
Message: <3b02d0ba$1@news.povray.org>
news:3b0291c4@news.povray.org...
>   Are you sure that you are not suffering from CPU temperature problems?
> This can be sometimes the cause for crashes with CPU-intensive programs
> (such as POV-Ray). The CPU gets warmer when it's very busy.
>   Watch the CPU temperature with a monitoring program such as
> http://web.bham.ac.uk/jst829/mbprobe/
Sure wish one of those utilities would monitor the motherboard and sensors I
have.  Ah ha! That one lists the i815EM!  Finally...  Thanks so much for
posting that URL!
Seems I read someplace that AMD's are run hotter than equivalent clockrate
Intel's, the Athlon anyway.  Same for Duron?  I couldn't say, not sure
anyhow.  My DELL notebook is a PIII at 800Mhz and I suspect it isn't wholly
stable, but a well-fanned tower case must be very different.
Bob H.
Date: 16 May 2001 15:22:41
Message: <3b02d381@news.povray.org>
"GrimDude" <gri### [at] netzerocom> wrote in message
news:3b02ce32$1@news.povray.org...
At least you have someone...  :'{
Heh,  sorry, I thought I might try cheering you up.
And that's a good thing, right?  Guess you can't get a better 50-50
relationship than that with fellow and fellowette POVers.  Where's a chapel
scene at?  Maybe Gail isn't married.
Bob H.
Date: 16 May 2001 15:27:42
Message: <3b02d4ae$1@news.povray.org>
news:3b02d052$1@news.povray.org...
(VIA
More than I do, it tells me water should freeze on it, 32 degrees F or 0 C.
I knew I was speaking to soon thinking it would finally be the monitoring
utility that could work on this thing.  I'm beginning to think DELL took all
the sensors out.
Bob H.
Date: 16 May 2001 22:43:27
Message: <3B033B6F.5BC2DE2D@pacbell.net>
> crash.
<snip>
It crashes on my system too. If you comment out "ambient_light 0" below
the scene will render ok. Sounds like a bug but I don't know where or
why.
global_settings { max_trace_level 11 assumed_gamma 1 ambient_light 0 }
Date: 16 May 2001 23:35:15
Message: <3b0346f3@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3B033B6F.5BC2DE2D@pacbell.net...
to
> > crash.
> why.
Strange, renders without a crash here.  You both have the Athlon chips eh?
Bob H.
Date: 17 May 2001 00:09:55
Message: <3B034FB2.E8BABAA8@pacbell.net>
If running 3.1g try rendering it a few times in succession and see if
that causes it to crash. I got it to render a couple of times but not
reliably.
Yes I have an Athlon.
Ken Tyler
