POV-Ray : Newsgroups : povray.unofficial.patches : Something fresh - symetry operator patch Server Time
20 Jul 2024 23:31:59 EDT (-0400)
  Something fresh - symetry operator patch (Message 1 to 10 of 19)
Subject: Something fresh - symetry operator patch
Date: 10 May 2001 12:53:49
Message: <3afac79d@news.povray.org>
I've created simple addition to expressions - vector symmetry operator "@".
Syntax
  Vector @ SymmetryRefference
  SymmetryRefference : Vector | ox | oy | oz | xy | xz | yz
Instead of explanation just examples of usage and old equivalents
#local A=<7,3,4>;
#local B=A@xy; /* B=<A.x,A.y,-A.z> */
#local B=A@xz; /* B=<A.x,-A.y,A.z> */
#local B=A@yz; /* B=<-A.x,A.y,A.z> */
#local B=A@ox; /* B=<A.x,-A.y,-A.z> */
#local B=A@oy; /* B=<-A.x,A.y,-A.z> */
#local B=A@oz; /* B=<-A.x,-A.y,A.z> */
#local B=A@0; /* B=<-A.x,-A.y,-A.z> */
#local B=A@A; /* B=A */
#local B=A@(A-1) /* B=A-2 */
if there is any person interested in source to this patch I can upload it on
this news server.
#macro Sig(A,B,X)_(A,B)_(B,X)_(X,A)#end#macro _(A,B)cylinder{<A.x,A.y,3>,<B.u,
B.v,3>.1,9}#end global_settings{max_trace_level 9}light_source{0 1}camera{up y
*4right-3*x}blob{_(<3,1>,<1,-5>)_(<2,-2>,<4,-2>)Sig(x,<-1,1.5>,<1,3>)_(z-1,z-4
)pigment{rgb 1}}box{-3 3pigment{rgb 0}finish{reflection 1}hollow} // POV-Ray31
Subject: Re: Something fresh - symetry operator patch
Date: 10 May 2001 13:07:12
Message: <slrn9flim2.khs.ron.parker@fwi.com>
>Syntax
Why a patch and not a macro?
#macro VecSym(Vec, Sym)
  (vlength(Sym)?(2*vdot(Vec,Sym)/vlength(Sym)*Sym-Vec):(-Vec))
Then you give it x instead of ox, y instead of oy, etc. and
x+y instead of xy etc.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 11 May 2001 03:05:48
Message: <3afb8f4c$1@news.povray.org>
Ron Parker wrote in message ...
> >Syntax
> #end
x and x+y has meaning of vectors in POV (center of symetry)
ox is not <1,0,0> but axis x
xy is not <1,1,0> but plane contained axes x and y
and patch becouse now I'm adding support for plane{}
#local B=A@plane{y 1 rotate C translate z}
than perhaps I remove xy, xz and yz planes
of course all these things are posible with current syntax and macros but it was
inspired by my current work and short sigs it was just too much for me to type
<-A.x,A.y,A.z> to change sign only for one coordinate
perhaps AT_TOKEN is wrong but it is only one free I found
and I wanted avoid ambiguity
Date: 11 May 2001 06:43:21
Message: <3afbc248@news.povray.org>
> macros but it was inspired by my current work and short sigs it was
> just too much for me to type <-A.x,A.y,A.z> to change sign only for
> one coordinate
Why not A*<-1,1,1>? Or A-2*x*A?
Christopher James Huff - chr### [at] maccom
Home Page: http://homepage.mac.com/chrishuff/
POV-Ray TAG e-mail: chr### [at] povrayorg
POV-Ray TAG web site: http://tag.povray.org/
Date: 11 May 2001 07:32:59
Message: <3afbcdeb@news.povray.org>
Chris Huff wrote in message <3afbc248@news.povray.org>...
> > one coordinate
becouse it is longer than A@yz ;)
as I said I know all kind of symmetry are possible somehow
I just tried (succesfully) collect them to one way
A@0
A@B
A@xy
A@ox
A@plane{y 2 rotate z*30 translate 10}
I don't want pressure to use it. I just offered sharing if anybody find it
usefull.
If any person is also interested I've also added such extension
#local MyArray=array[4][4]{tranform{rotate 10*x translate z}}
which assigns matrix of transformation to array
Date: 11 May 2001 07:48:01
Message: <3afbd171@news.povray.org>
Modifying the POV-Ray source code and thus making a patch can be cool
(I have made that, I know what I'm talking about :) ), but it's important
to be aware of one thing:
  If the exact same functionality can be made with an include file (usually
implemented as a #macro) without noticeable resource penalty (time, memory,
etc) nor compromise in easy-to-use, then the #macro is definitely the
right choice.
  Why?
  If this kind of thing is made by modifying the source code, it will only
cause more trouble than it's worth. It will also limit the functionality of
the new idea a lot.
  Adding new patches to a patch collection (such as MegaPov) or even the
official povray is usually a maintenance nightmare and a lot of work.
  Also the functionality of a patch is extremely fixed, ie. unmodifiable
(at least without having to modify the source code itself).
  A #macro, however, is much more versatile. You not only can use it, but
you can look how it is done, learn from it, modify it for your specific
needs, make your own version of it and so on. A #macro is much easier to
take (just download the include file from a website to your include
directory); you don't have to wait for someone to include it in MegaPov or
whatever. A #macro is also much less likely to have bugs than a patch.
Date: 11 May 2001 08:06:51
Message: <3afbd5db@news.povray.org>
Warp wrote in message <3afbd171@news.povray.org>...
> [cut]
I know all adventages of using macros becouse I always carefully read your
posts. Althought I prepared this for myself not for community and just offered
sharing if anybody has the same problem (less typing) like me. I'm not uploaded
this without ask becouse I didn't want "bring noise" to community. Also I coded
this with respect to rules of adding patch learned from MegaPOV source and my
patch could be off by commenting of one #define. Anyway thanks for lesson.
Date: 11 May 2001 08:46:47
Message: <slrn9fnnps.m36.ron.parker@fwi.com>
But there's no difference.
Okay, this part is different.  That would need another macro
And that macro would happily do this part as well.
Date: 11 May 2001 08:48:14
Message: <slrn9fnnsj.m36.ron.parker@fwi.com>
Yeah, I thought about making patches to make it easier to make a really short
sig too, but where's the fun in that?  That's like giving in to the dark side
and using the $ operator.
Date: 11 May 2001 09:00:29
Message: <3afbe26d@news.povray.org>
for geometry symmetry it is difference
I wanted translate symmetry from math to syntax
A=<3,2,3> symetry by x (<1,0,0>) -> A'=<-2,-2,-3>
A=<4,2,3> symetry by axis ox -> A'=<4,-2,-3>
and it is as easy to understand and code ?
ABX
