POV-Ray : Newsgroups : povray.unofficial.patches : I don't understand the slope pattern Server Time
29 Sep 2024 01:26:03 EDT (-0400)
  I don't understand the slope pattern (Message 1 to 10 of 25)
Subject: I don't understand the slope pattern
Date: 28 Apr 2001 14:14:52
Message: <3aeb089c@news.povray.org>
Can someone please explain this to me in simpler terms than those used in
the MegaPOV docs? I've been struggling to get this thing to work on
heightfields higher than 1 unit (in my case a heightfield 3.28 units high,
which will be changed later). Specifically the one with syntax: slope,
<x,y,z>,<x,y,z>,<u,v>,<u,v>. An example is greatly appreciated. TIA
Anthony Bennett
Subject: Re: I don't understand the slope pattern
Date: 30 Apr 2001 05:45:21
Message: <3aed3431@news.povray.org>
"Tony[B]" <ben### [at] catholicorg> wrote in message
news:3aeb089c@news.povray.org...
I may well be wrong here, but I've always assumed that slope (apart from the
simple "slope <slope>"usage) requires the hf to be only 1 unit high max.
Date: 30 Apr 2001 09:48:33
Message: <3aed6d31@news.povray.org>
I was afraid of that...
Date: 1 May 2001 07:18:12
Message: <3aee9b74@news.povray.org>
Tony[B] <ben### [at] catholicorg> wrote:
: I was afraid of that...
  Texture first, scale then. What's the problem?
#local D=array[6]{11117333955,7382340,3358,3900569407,970,4254934330}
#local I=0;#macro M()<mod(D[I],13)-6,mod(div(D[I],13),8)-3,10>#end
#while(I<6)cylinder{M()#local D[I]=div(D[I],104);M().1
pigment{rgb M()}}#local I=(D[I]>99?I:I+1);#end              /*- Warp -*/
Date: 1 May 2001 07:28:51
Message: <3aee9df3@news.povray.org>
news:3aee9b74@news.povray.org...
Perhaps his texture is distorted when scaled. Of course, he could scale his
texture inversely to account for this.
Date: 1 May 2001 07:53:34
Message: <3aeea3be@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote:
: Perhaps his texture is distorted when scaled.
  Well, he can do this:
heighfield
{ whatever
  scale <10, 1, 20>
  texture { whatever }
  scale <1, 2, 1>
Date: 1 May 2001 08:25:47
Message: <3aeeab4b$1@news.povray.org>
news:3aeea3be@news.povray.org...
> heighfield
> { whatever
>   scale <10, 1, 20>
>   scale <1, 2, 1>
Shouldn't that be:
 heighfield
 { whatever
   texture { whatever scale <1, 1/2, 1>}
   scale <1, 2, 1>
Date: 1 May 2001 09:09:56
Message: <chrishuff-1590B8.08072801052001@news.povray.org>
In article <3aeeab4b$1@news.povray.org>, "Tom Melly"
> Shouldn't that be:
>  heighfield
>  { whatever
>    scale <1, 2, 1>
#declare HFTrans = transform {...}
heighfield { whatever
    texture {whatever transform {HFTrans inverse}}
Christopher James Huff
Date: 1 May 2001 11:22:28
Message: <3aeed4b4@news.povray.org>
> terms than those used in the MegaPOV docs? I've
> heightfield 3.28 units high, which will be
> slope, <x,y,z>,<x,y,z>,<u,v>,<u,v>. An example is
          A       B      C     D
You have four vectors. Let's call them vector A, B, C and D. A and B are 3D
vectors. C and D look like 2D vectors in their syntax, but in fact they have
nothing to do with vectors.
A is a 3D vector controlling the which direction the slope pattern is based
on. As I'm sure you understand that one, I won't go into details.
C is used to give you better control over A. If you're using a heightfield
and A is set to be y you are not having any surfaces that are anti-parallel
to A (-y). Actually, even the most steep surfaces of the HF would be
perpendicular to the slope vector at most. That means the pattern only will
return values from 0.5 (perpendicular) to 1.0 (parallel). The part of your
color_map that uses values from 0.0 to 0.5 is sort of wasted, since it's
never used.
You can use C to specify that only a certain range of slopes are used. The u
part in C sets the lo-slope and the v part sets the hi-slope. For example,
if you set C to be <0.5,1.0> it means that the pattern value goes from 0
when the slope is perpendicular to A, to 1 when the slope is parallel to A.
That means that your entire color_map is used, even though only a certain
Let me know if it's clear so far!
To be continued...
In the next message I'll try to explain how to use the slope pattern with
heightfields higher than 1 unit! But maybe someone will beat me to it...
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated March 29)
/ Also visit http://www.povrayusers.org
Date: 1 May 2001 11:51:38
Message: <3AEEDBAE.C1F5024D@gmx.de>
>           A       B      C     D
That looks really good and understandable, just add some illustrating
pictures (and of course something on B and D) and you have an excellent
slope pattern tutorial.
