POV-Ray : Newsgroups : povray.unofficial.patches : uv_mapping again - how to? Server Time
15 Jun 2026 18:44:27 EDT (-0400)
  uv_mapping again - how to? (Message 1 to 4 of 4)
Subject: uv_mapping again - how to?
Date: 17 Apr 2001 15:43:18
Message: <3adc9cd6@news.povray.org>
I give it up. I don't understand how to map an image on a union of
bezier_patches created in Hamapatch.
I exported a simple plane out of 32 patches an tried to map a png on it. The
union lies in the x/z-plane. As the image_map is in the x/y-plane, I rotated
it x*90.
The code I added to the union:
uv_mapping
 texture{pigment{rgb 1}}
 texture{ pigment {
    image_map{
      png "Flagge.png" // the file to read (iff/gif/tga/png/sys)
             map_type 0 // 0=planar, 1=spherical, 2=cylindrical, 5=torus
             interpolate 2 // 0=none, 1=linear, 2=bilinear, 4=normalized
distance
             once
           } // image_map
          rotate x*90          }
What is wrong? I only get stripes of my image, streched in the z-axis.
In addition, if I rotate the object, the texture does not rotate with it.
What is wrong?
Thanks in advance,
Marc-Hendrik
Subject: Re: uv_mapping again - how to?
Date: 17 Apr 2001 18:17:20
Message: <Xns90873450EBD1seed7@povray.org>
> on it. The union lies in the x/z-plane. As the image_map is in the
> x/y-plane, I rotated it x*90.
You don't need to rotate the image_map. The part of a texture that is
used for uv_mapping is the part in the xy-plane going from <0,0> to
<1,1>
You'll have to add uv_mapping and the texture to use to each patch, not
only to the union. Also you may need to add the uv_vectors. If you use
uv_vectors  <0,0>,<1,0>,<1,1>,<0,1>, this wil map the texture in the
above mentioned area to each patch. If you want to to map your image
over several patches yoou'll have to divide the uv_vectors to smaller
areas. See example below.
#version unofficial MegaPov 0.7
global_settings{assumed_gamma 1}
camera {location <0,0,-3> look_at 0}
light_source { <500,500,-500> rgb 1 }
#declare Bic_Tex=texture {
      wood
      frequency 4
      turbulence 0.1
      octaves 7
      lambda 0.5
      omega 0.5
      color_map {
         [0, rgb 0]
         [1, rgb 1]
   translate <0.25,0.5,0>
union{
bicubic_patch {
   type 1
   flatness 0
   u_steps 3
   v_steps 3
   <0,0   ,0>,<0.33,0   ,0>,<0.67,0   ,0>,<1,0   ,0>
   <0,0.33,0>,<0.33,0.33,0>,<0.67,0.33,0>,<1,0.33,0>
   <0,0.67,0>,<0.33,0.67,0>,<0.67,0.67,0>,<1,0.67,0>
   <0,1   ,0>,<0.33,1   ,0>,<0.67,1   ,0>,<1,1   ,0>
   //uv_vectors  <0,0>,<0.5,0>,<0.5,0.5>,<0,0.5>
   uv_mapping
   texture {Bic_Tex}
   translate <-1,-1,0>
bicubic_patch {
   type 1
   flatness 0
   u_steps 3
   v_steps 3
   uv_vectors <0.5,0>,<1,0>,<1,0.5>,<0.5,0.5>
   uv_mapping
   texture {Bic_Tex}
   translate <0,-1,0>
bicubic_patch {
   type 1
   flatness 0
   u_steps 3
   v_steps 3
   uv_vectors  <0,0.5>,<0.5,0.5>,<0.5,1>,<0,1>
   uv_mapping
   texture {Bic_Tex}
   translate <-1,0,0>
bicubic_patch {
   type 1
   flatness 0
   u_steps 3
   v_steps 3
   uv_vectors  <0.5,0.5>,<1,0.5>,<1,1>,<0.5,1>
   uv_mapping
   texture {Bic_Tex}
rotate <0,0,45>
Ingo
Date: 18 Apr 2001 03:24:26
Message: <3add412a@news.povray.org>
Uh oh, .... okay, I'll try that ....
I wonder, if this is really the supposed behaviour, because it is that
different from the rest of Pov. OTOH, how should Pov know which patch is
meant to have which uv-co-ordinates.
Thanks for your help,
Marc-Hendrik
Date: 18 Apr 2001 04:23:04
Message: <3add4ee8$1@news.povray.org>
The best way of uv mapping a image on a hamapatch object is to export as a
obj file and use uv mapper to create the image map. Gilles has written an
excellent tutorial on the subject which you should be able to find on his
site.
Mick
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:3adc9cd6@news.povray.org...
> Hi,
The
rotated
> it x*90.
> uv_mapping
>  texture{ pigment {
>     image_map{
> distance
>              once
>            } // image_map
>           rotate x*90          }
> What is wrong?
> Thanks in advance,
> Marc-Hendrik
